10th Aug 2007, 6:16 pm | #1 |
Defiant transistor radio - model ? battery ?
Hello,
I have almost finished restoring the case on an old Defiant transistor set (see pic) but can't progress further without service data and its power requirement. Does anyone recognise this Defiant set ? It's quite an early set as its complement of transistors is OC44, 2x OC45, OC81D and 2x OC81. Also, it has a battery clip (see pic) that I've not encountered before with 4 pins, does anyone know what battery once fitted this ? Thanks, Howard |
10th Aug 2007, 6:43 pm | #2 |
Re: Defiant transistor radio - model ? battery ?
Hi Howard
looks like an A55 - later version (not sure what the earlier version was!) - it supposedly took 2 x 4.5volt batteries - but that doesn't seem right with your battery plug. I've got one of these somewhere (which I haven't played with yet) and I'm sure mine has been altered to take a 9 volt battery. Paul has the trader sheet Cheers Andy |
10th Aug 2007, 6:46 pm | #3 |
A55 sounds right.
You need a PP11 to run it--it's a dual 4.5 volt battery.
Just playing with high voltage.... |
10th Aug 2007, 10:32 pm | #4 |
PP11 sets have the speaker connected between the battery centre tap and the (otherwise normal) output stage centre point, thus saving a capacitor. When PP11s became obsolete the standard mod was to replace the connector with press studs for 0v and 9v & use a PP9, which is the same size. This powered the radio as before. The centre tap was disconnected & removed, and the speaker connected via a suitably polarised 100mFd capacitor to 0v or 9V. Note the term mod, not bodge, as such mods have been an essential part of everyday radio maintenance from the early days.
10th Aug 2007, 10:45 pm | #5 |
Hello again,
Thanks all for identifying this set as a 1963 Defiant A55 and its PP11 2x 4.5v battery. I have now got a copy of Trader sheet 1607 for the set and as PP11 batteries are long gone I shall convert it for PP9 use as described by Bill. It's come up really nice, and it's not unlike a Perdio Fanfare in construction and no doubt will soon appear in Success Stories. Howard |
10th Aug 2007, 10:46 pm | #6 |
Howard
Can you post a picture of the circuit board? From the layout of the controls, tuning scale and wavechange switch it looks as if internally it might be the same as my Contessa Mk 111 kit radio. Ron |
10th Aug 2007, 10:51 pm | #7 |
That sounds very likely - an earlier Defiant here (A5, I think) is much the same as an earlier Contessa I have.
Paul |
10th Aug 2007, 11:05 pm | #8 |
Hello Ron,
Here's the inside of the Defiant. Howard |
10th Aug 2007, 11:16 pm | #9 |
Howard / Paul
Yes, the internals are the same as the Contessa Mk III. The only differences are that my Contessa did not have an earphone socket and that piece of cardboard attached to the right-hand end of the ferrite rod was missing. I wonder if surplus stock was sold off by Defiant when production ceased and Henry's Radio and Electrovalue bought it all up and incorporated it in a new case. Ron Ron Last edited by ronbryan; 10th Aug 2007 at 11:34 pm. |
11th Aug 2007, 9:52 am | #10 |
I think it's a Plessey design that was sold to pretty much whoever wanted to market it in any form, with kit sets being released not far behind those from recognised brands. This one's a Magnavox 300TR table model, probably a little earlier in view of the Ediswan transistors, and no doubt with a few component changes at least to allow for the six volt 996 batteries that the bigger cabinet lets it use. As I recall the earlier Defiant and Contessa models use a very similar board again, though with different presentation (oversized round perspex tuning control in TR82 fashion): and there's an Alba clone of those around too....
Paul Last edited by Paul_RK; 11th Aug 2007 at 9:59 am. |
19th Jul 2023, 7:56 pm | #11 |
Thread reopened for more information on use of this chassis.
Cheers Mike T
19th Jul 2023, 9:54 pm | #12 |
This Amplion has been in my loft for 20+ years, opening it up it has basically the same Plessey chassis as the Contessa III and the Defiant A55.
The PP11 connector is missing but I intend to get it working on +/- 4.5V then do the capacitor mod to use a PP9. I can't find it in the Radio Museum site but could this be the last gasp of the Amplion marque? I've got a busy weekend but I'll try to get it up and running next week. Watch this space. Bob. I've just found another thread from 2013 that I'll try to link in to, otherwise search 'Amplion'!
I was so upset that I cried all the way to the chip shop. Last edited by Bob_Moss; 19th Jul 2023 at 10:02 pm. Reason: More information |
19th Jul 2023, 11:11 pm | #13 | |
https://www.radiomuseum.org/r/co_op_defiant_a5a.html came before those like the A55 with horizontal scale. I've certainly never seen a pocket Amplion, but wouldn't be at all surprised if it's a clone of the Defiant A4, https://www.radiomuseum.org/r/co_op_defiant_a4.html Paul |
20th Jul 2023, 9:47 am | #14 |
Thanks for the info Paul, I did look in Radio! Radio but you must have the third edition.
I was so upset that I cried all the way to the chip shop. |
21st Jul 2023, 12:55 pm | #15 |
In my Sonneclair 4 touches I did find this battery arrangement: looks like yours, but this is just 2 batteries in series.
22nd Jul 2023, 9:40 am | #16 |
This type of battery arrangement was very common in France in the so-called "transistors" of the late 50s and 60s because two 4,5V batteries were much cheaper than one 9V "special radio" battery.
31st Jul 2023, 7:50 pm | #17 |
Amplion now up and working, powered by 2 x 4.5V supplies the fault was found to be an intermittent pole on the on/off switch (now bypassed). Modified to run off a 9V battery I got it to work to listen to the last three balls of the last ever Test Match broadcast on LW.
It sounds very pleasant - basically the same as my Defiant! Thanks for the Forum members for their input.
1st Aug 2023, 10:21 am | #18 |
Bravo!
I will not regret the disappearance of sports on BBC4. However I will miss the longwave 198KHz very much. It is tragic that one doesn't see the historic value of the old transmitters. Reception of BBC4 was always good here in the Netherlands - and I like the programs, except sports obviously... |
