6th Jan 2016, 9:45 am | #1 |
Cossor 494AC Tone correction capacitor.
Hi all,
I have a Cossor 494AC that I am hoping to get up and running. I plan first off to change the AF coupling capacitor, then also the tone correction capacitor which is listed as C20 on trader sheet 924. My question relates to the latter. I have three versions of the circuit diagram in total which show that the required capacitance is 0.005uF, however, whilst two don't specify the voltage rating one says it should be 1kV. If I order 0.0047uF 630v capacitors will these be suitable please? Regards, Gary |
6th Jan 2016, 9:54 am | #2 |
Re: Cossor 494AC Tone correction capacitor.
630v will probably be OK but 1kV are available so why not get the right one.
http://uk.farnell.com/lcr-components...ial/dp/9520309 |
6th Jan 2016, 9:56 am | #3 |
630V should be fine. Most capacitors in tone correction circuits were rated at 500V. It's only rated that high because there is a chance of high level AF signals appearing across it superimposed on any DC voltage. Modern 630V polyesters should be fine.
6th Jan 2016, 9:58 am | #4 |
6th Jan 2016, 10:00 am | #5 |
Trader expected people in the business to know what was acceptable rating in a given location would be my guess.
Cheers Mike T
6th Jan 2016, 10:07 am | #6 |
Hi Mike,
That's what I thought, but why are the voltage ratings specified for some caps and not others? Presumably because something unusual was being used for a given location? Do you have a Cossor 494 in your collection Mike? Regards, Gary |
6th Jan 2016, 10:48 am | #7 |
Hi Gary
Yes I have a few of the these no time to do much with them however Yes it does seem hit or miss if there is a voltage rating or not on the Trader sheets. I have a pretty good collection of post war Cossors (And Pre-War Cossors as well ) 464's seem to breed by themselves I must have 5 or 6 of the little devils. Cheers Mike T
6th Jan 2016, 10:58 am | #8 |
Thanks Mike, very interesting.
Gary |
6th Jan 2016, 11:38 am | #9 |
There are not many if any domestic radios that 630Volt caps won't suffice or 400 Volts for that matter. Possibly excluding electrolytics in certain cases.
6th Jan 2016, 11:49 am | #10 |
Thanks for the advice, I appreciate it.
6th Jan 2016, 11:51 am | #11 |
Tone correction caps were normally 1kV devices because if they failed following a voltage spike they would fail short circuit, with possibly disastrous results. Modern plastic film caps will usually self heal after a spike so don't need to be rated so conservatively.
That said, it's good practice for any replacement cap to at least equal the voltage rating of the original. |
6th Jan 2016, 12:00 pm | #12 |
Hi Paul,
Many thanks for the advice, I have ordered some 1kV caps, so will fit one of those. Gary |
6th Jan 2016, 12:11 pm | #13 |
I stand corrected Paul.
6th Jan 2016, 12:23 pm | #14 |
I think that was sort of semi-corrected actually, if I interpreted the message correctly
Looks like the consensus is 630V is probably okay, but fit the 1kV anyway as it's available. Sounds like good advice to me, so that's what I intend to do. Cheers ... |
