18th Nov 2004, 8:06 am | #1 |
6 Volt vibrator receivers
What do you guys normally do with 6 volt battery receivers? I have one in my possession, a Philips 697VN, problem is that I would like to fully get it playing. As the set is no great collectable piece could one replace the vibrator pack with a modified mains tranformer and rectifier?
One couldn't really get a replacement battery as most car's now only run of 12V and the drain (propably around a 2-3 amps) would be far to great for small batteries. Is it normal practice to disconect the vibrator, leaving this in place, rewiring the filament leads and running the set of an extrenal HT, LT source? Have thought of using an extrenal 6 Volt source, such as mains transformer, but the problem of high current and the introduction of different frequencies and slight AC ripple might, in my opinion to something to the vibrator. Don't know if I'm wrong! Any suggestions? Andrew |
18th Nov 2004, 8:49 am | #2 |
Re: 6 Volt vibrator receivers
Andrew
Excuse the lateral thinking, but you could get a 6-volt car to put it in - early Beetle, Deuche, et al.
Mike. |
18th Nov 2004, 8:58 am | #3 |
Hi Andrew, 6 volt lead acids are still available from the likes of RS, but a power supply would also be OK.
If the vibrator is shot it is possible to get replacements sometimes, or it can be dismantled and the contacts cleaned. I have also run 12V vibrators with FETs as drivers, using the contacts only to operate the gates of the FETS. This would not work well at 6V due to the FET gate threshold voltage, you may however get away with bi-polars. Alternatively you may be able to re-wire for 12V operation. Ed |
18th Nov 2004, 9:38 am | #4 | |
18th Nov 2004, 11:28 am | #5 | |||
Last edited by Paul Stenning; 26th Dec 2004 at 7:26 pm. Reason: Fix link or code for vBulletin |
18th Nov 2004, 12:47 pm | #6 |
Location: World Heritage Village of Saltaire, Shipley, West Riding of Yorkshire.
What about using a Alkaline 'Lantern' battery. Energizer produce one 6V 24Ah.
Paul E |
18th Nov 2004, 2:50 pm | #7 | |
Reminds me of a colleague who, in the 1970s, rewired the heaters on a Bush TV53 and made an inverter so he could use it in his car!! Worked, as well Are you reading this, Ian Wrethman?
Mike. Last edited by Paul Stenning; 26th Dec 2004 at 7:27 pm. Reason: Fix link or code for vBulletin |
18th Nov 2004, 4:12 pm | #8 |
Andrew,
In my limited experience of vibrator PSUs they're nothing but a nuisance, being unreliable and throwing out a lot of RF noise. Opening and repairing vibrator packs is a challenge, but not one I've ever enjoyed. I think if you want to have the set as it was in the 50s, and working, but only used occasionally, leave the vibrator and power it from a mains 6V PSU or battery. If you want to use the set regularly, the vibrator is likely to prove painful, and you'd be better off taking it out of circuit and powering the set from a separate mains PSU. Pete. |
18th Nov 2004, 5:04 pm | #9 |
Most people using vibrator power supplies will replace the vibrator with a solid state multivibrator. You could hide the solid state components in the vibrator can if you wanted to, though obviously this is more work. You only need a couple of silicon power transistors scavenged from a PSU, scrap TV etc. The original transformer can be retained in most cases.
HTH, Paul |
18th Nov 2004, 7:30 pm | #10 | |
With it running of 12 volts it would still be far more portable than 6 volts - most car batteries being 12 : A pity though that NOTHING broadcasts in the MW band during the day Andrew Last edited by Paul Stenning; 26th Dec 2004 at 7:28 pm. Reason: Fix link or code for vBulletin |
18th Nov 2004, 8:25 pm | #11 |
6 volt s/s vibrators are available from Antique Electronic Supply in the States, so you shouldn't need to convert to 12 volts other than to make the set usable with a car battery!
