Old 29th Nov 2019, 2:08 pm   #1
Luxman1050
Luxman1050's Avatar
Default Any ideas on what this would used on
Hi all
anybody got any ideas on what this 240vac current test plug would be used on and how it's supposed to work.
Stumped me! Like to try it out.
Cheers Chris
ID:	194602   Click image for larger version
Luxman1050 is offline
Old 29th Nov 2019, 2:14 pm   #2
Peter.N.
Default Re: Any ideas on what this would used on
Looks like one of those things that service departments would give apprentices to plug in.
Is there actually anything inside the sleeving or are the ends just connected together?
Peter
Peter.N. is offline
Old 29th Nov 2019, 2:46 pm   #3
Herald1360
Herald1360's Avatar
Looks like a " Little Wonder" fuse tester to me.
Dyeing trousers, perhaps?
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 29th Nov 2019, 3:20 pm   #4
newlite4
newlite4's Avatar
Perhaps it plugs into a test panel and a current clamp meter is fed through the loop.
Neil
preserving the recent past, for the distant future.
newlite4 is offline
Old 29th Nov 2019, 3:21 pm   #5
Luxman1050
Luxman1050's Avatar
No it's just connected in a loop and just says on bit paper stuck on wires to test ac current 240v. Not sure what the grey bit for as there is no wire exposed as I thought maybe you put a clip on it or something.
Old 29th Nov 2019, 4:24 pm   #6
G6Tanuki
G6Tanuki's Avatar
I've seen similar things used as a primitive safety-interlock: the matching socket would be wired in series with the live side of the supply to a piece of gear/installation/panel. The plug acts as a shorting-link; you remove it and take it with you when you need to do work on the panel. Using an obscure plug/socket in such applications reduces the chance of someone-else kludging together a bypass - the US 2-flat-pin plugs/sockets are rather handy for this sort of thing.
G6Tanuki is offline
Old 29th Nov 2019, 4:39 pm   #7
Luxman1050
Luxman1050's Avatar
So is it used on valve gear and why would you need to create a short circuit? Or is it that you bypass the mains on piece of equipment so you can work on different parts components.
When you say panel do you mean the chassis?
Dumb questions which I think you answered.
Cheers Chris
Old 29th Nov 2019, 5:54 pm   #8
G6Tanuki
G6Tanuki's Avatar
It'd be wired in series with the [mains] power-supply to a piece of equipment; with the plug/link in-place, power is applied to the equipment. Remove the plug/link and the power is cut off, and you can take the link away with you to prevent anyone else restoring the power while you're working on the equipment (as could happen with a simple switch).
[If an isolating switch is used then it should have some mechanism for a padlock-and-tag to be fitted to prevent anyone unauthorised from re-applying power]
By "panel" I mean something like an industrial control-panel or the contactors/switchgear in something like a lift or heavy machinery.
G6Tanuki is offline
Old 29th Nov 2019, 7:54 pm   #9
Luxman1050
Luxman1050's Avatar
Ah I see simple but effective.
Thanks for that.
Much appreciated Chris
Old 29th Nov 2019, 9:08 pm   #10
Station X
Station X's Avatar
Why would a shorting link require such a long length of wire attached to it?
Graham. Forum Moderator
Station X is offline
Old 29th Nov 2019, 9:19 pm   #11
sortedradio
sortedradio's Avatar
I would tend to agree with Neil that it's for a clamp meter, especially as the label states "to test ac current 240v". The grey plastic is probably to prevent the wire being damaged accidentally by the clamp.
Martin
BVWS member
GQRP Club
sortedradio is offline
Old 29th Nov 2019, 9:26 pm   #12
Station X
Station X's Avatar
That makes sense.
Old 29th Nov 2019, 10:00 pm   #13
G6Tanuki
G6Tanuki's Avatar
To make it easier to hook to your belt before walking away. When I dealt with such things you always had to physically-attach the disabler to your person. A short loop could be inconvenient for this.
[The same sort-of approach is used in the 'kill-switch' lanyards on powerboarts/jetskis which kill the engine if you fall off]
G6Tanuki is offline
Old 30th Nov 2019, 11:37 am   #14
Peter.N.
Its got an exceedingly old 2 pin 5a plug on it so I would think its dated to the '50s if not the '40s.
Peter
Peter.N. is offline
Old 30th Nov 2019, 12:15 pm   #15
Luxman1050
Luxman1050's Avatar
Thanks for replies guys in effect it's just a safety feature as far as I can make out from replies it is connected in series with mains and if removed renders the equipment non usable if you tried to plug it in that's what I can make out. I'm not sure I'll get round to use it as it was obviously for an electrical engineer as mentioned from 40s 50s. Just interesting when you come across gear like this having no idea what it was used for.
Cheers Chris
Old 30th Nov 2019, 1:56 pm   #16
stuarth
The long wire may be just to get the clamp meter in a more convenient place. There may have been a much shorter wire, or even a shorting plug to avoid having the long wire dangling about in normal operation.
Stuart
stuarth is offline
