Old 13th Apr 2021, 12:17 pm   #21
Richard_FM
Richard_FM's Avatar
Default Re: Plug adaptors of the past
Here we go:
https://www.flameport.com/electric_m...ndard_plug.cs4
http://www.plugsocketmuseum.nl/British2.html
Richard_FM is offline
Old 13th Apr 2021, 1:12 pm   #22
Heatercathodeshort
Heatercathodeshort's Avatar
As far as I can remember the Wandsworth plug was the same as the D&S plugs being described here. It had a W embossed into the Bakelite cover.
Yes I did encounter them in Prefabs situated next to the railway line in Hartfield Crescent Wimbledon. Strange how you remember silly details. My customer kept chickens running around in a large wired area in the garden The TV was a Ferguson 406T then around ten years old.
The Fitall plug was OK but useless when you encountered a socket mounted on the skirting board close to the floor. I got fed up with this and ended up with two bare wires that I used to carefully place in the socket and then secure them with a plug..Sleeved plugs put an end to that!
It was quite amazing the sockets you encountered. When I was first doing service calls at 16 [1964] , 13amp sockets were quite rare and in many houses/bedsits the BC adaptor still ruled!
I always thought a 15amp 3 pin plug was a much better arrangement and took the current from a 3000w appliance much better than a 13amp one. They just made better contact. John.
Heatercathodeshort is offline
Old 13th Apr 2021, 2:39 pm   #23
winston_1
So just a "normal" 13 amp plug with a different earth pin. I thought they predated that.
winston_1 is offline
Old 13th Apr 2021, 2:40 pm   #24
winston_1
Thanks John. So they are older than 13 amp plugs with a different earth pin!
Old 13th Apr 2021, 6:15 pm   #25
emeritus
A page from a catalogue showing a "Wandsworth" plug can be found in post #22 (amongst others) of this closed thread, which also has information on many types I was previously unaware of :
https://www.vintage-radio.net/forum/...t=71262&page=2
emeritus is offline
Old 13th Apr 2021, 10:29 pm   #26
Richard_FM
Richard_FM's Avatar
I was double checking the Wandsworth plugs & noticed there are two different earth pins, one having a round pin, and the other being almost square in section.
Old 14th Apr 2021, 7:16 am   #27
Bobdger
I used a Pargo plug with sliding pins for many years at Southern Rentals for my weller gun. These plugs worked with any socket even the MK logic range. I still have one of these plugs.
Bob
Name:	Pargo plug 001.jpg
ID:	231756   Click image for larger version
Name:	Pargo plug 002.jpg
ID:	231757   Click image for larger version
Name:	Pargo plug 003.jpg
Bob, BVWS member
Bobdger is offline
Old 14th Apr 2021, 10:17 am   #28
Richard_FM
Richard_FM's Avatar
I've seen a picture of a similar "universal" plug where the pins are attached so they swing through an arc rather than just sideways.
I did wonder how they coped with 3 pin sockets.
Old 14th Apr 2021, 11:24 am   #29
Richard_FM
Richard_FM's Avatar
This is the one
Old 14th Apr 2021, 3:01 pm   #30
Graham G3ZVT
Graham G3ZVT's Avatar
Bob
MK rumbled us, and deployed countermeasures
https://youtu.be/JSLuhwfDeXE
Graham.
G3ZVT
Graham G3ZVT is offline
Old 14th Apr 2021, 4:08 pm   #31
Refugee
Refugee's Avatar
The original sliding shutter sockets could be overridden by sort of walking the plug in.
The plain rotary shutter ones just let you push a 2-pin plug in.
The dimpled shutters soon followed making it much more difficult to get a two pin plug in.
Refugee is offline
Old 14th Apr 2021, 6:03 pm   #32
emeritus
When I joined the Patent Office, the subject matter dealt with in the training group I was assigned to, included plugs and sockets (officially known as "two-part couplings"), as well as cables and fuses. The relevant MK patents had already been granted by then, and copies were in the search files. The patent for the original design of rotatable shutter requiring simultaneous pin insertion, covered 2 pin sockets as well as three-pin. The later patented modification for 3 pin sockets was indeed designed specifically to defeat europlug insertion.
emeritus is offline
Old 16th Apr 2021, 11:04 am   #33
Heatercathodeshort
I discovered this version of the WANDSWORTH plug that differs from the ones I remember. I have some higher current ones in one of my junk plug boxes and may find them. If so I will post. [Why do we keep this junk?]
I guess it is older than the later D&S types as it does not have any form of fuse. Probably pre war.
John.
ID:	231894   Click image for larger version
ID:	231895   Click image for larger version
Old 16th Apr 2021, 12:50 pm   #34
emeritus
That's the type originally installed in the council houses of the Becontree estate in Essex in the 1920's, and still being used by my barber in the mid-1970's.
emeritus is offline
Old 17th Apr 2021, 9:49 pm   #35
Tom williams
Tom williams's Avatar
Quite an interesting thread this one!
Is there any way I can get hold of a fittall plug for my vintage plug collection? They are quite interesting to me and would fit quite nicely within the collection!
Tom
Tom williams is offline
Old 17th Apr 2021, 10:04 pm   #36
Richard_FM
Richard_FM's Avatar
There are usually some on the usual online auction sites, but probably more than at a swap meet.
Old 18th Apr 2021, 12:16 pm   #37
broadgage
They can indeed be found on ebay, but searching can be very tedious because most sellers dont give a very detailed description.
You may need to search for "vintage plug" and then look through vast numbers of listings.
broadgage is offline
Old 18th Apr 2021, 1:25 pm   #38
Cobaltblue
Cobaltblue's Avatar
Originally Posted by Tom williams View Post
Tom
Here's some I found earlier.
https://www.ebay.co.uk/itm/Vintage-W...MAAOSwAyBfh2F7
https://www.ebay.co.uk/itm/FITALL-vi...UAAOSw5eNdwdSU
https://www.ebay.co.uk/itm/Vintage-F...MAAOSweiZfxl0r
No connection with any of the sellers.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline
Old 18th Apr 2021, 6:35 pm   #39
Tractorfan
Tractorfan's Avatar
Smile Re: Plug adaptors of the past
Re: The Wandsworth plug in post no. 33.
My primary school had something similar, but much smaller and with a solid earth pin, for plugging a speaker into a socket in each classroom to hear schools broadcasts from a 'Grampian' receiver in the assembly hall.
I assume it was a 100 volt line system.
I also remember those Wandsworth mains sockets on Lewis's department store in Liverpool. There were two at the base of each column throughout the store.
Cheers, Pete.
Tractorfan is offline
