13th May 2020, 9:02 pm | #1 |
Home made Wartime transmitter /receiver
Looking for pictures and brief circuit description of the above. Most likely CW only that could have been used from the UK to contact Europe. Circa 1940's from scrounged parts.
Thank you
13th May 2020, 9:10 pm | #2 |
Re: Home made Wartime transmitter /receiver
Wouldn't something like that have attracted the attention of the security services?
13th May 2020, 9:18 pm | #3 |
I think you could look for the sets built in the Channel Islands to use during German occupation. Very ingenious.
13th May 2020, 10:08 pm | #4 |
Thank you Bill and Jon. Indeed it would have been very unsafe but I am after details for a novel being written, so just fiction.
Been around German museum years ago in Jersey and saw the home made receivers but I cannot remember any transmitters.
13th May 2020, 10:16 pm | #5 |
I can have a look in "Wireless For The Warrior Volume 4 Clandestine Sets" for you.
What's the context though? Who would have constructed this set and whom would they be communicating with? A professional spy or agent would have factory built set and wouldn't have needed to construct one unless he found himself stranded in enemy territory without one.
14th May 2020, 12:35 am | #6 |
There were things like adaptors, to go between the audio output valve and its socket to convert an ordinary radio/radiogram into a clandestine transmitter.
14th May 2020, 7:08 am | #7 | |
I have a copy of a memo written just pre-WW2 where the military in the UK were concerned about the possibility of enemy agents simply going into one of big ham radio shops and buying a station off the shelf. The memo mentions a American-made set that could be used fixed or portable in a car and although the maker and type are not given in the memo, a search of adverts of around that time threw up the Harvey-Wells UHX-10 as a likely candidate. 73 Roger/G3VKM |
14th May 2020, 7:17 am | #8 |
Would a paraset qualify? If so, maybe there is a circuit diagram in the VMARS archive.
Cheers Aub
14th May 2020, 10:16 am | #9 |
Yes please Graham I would be grateful for that. As mentioned it is for a novel that is being written, enclosed is the extract.
Annike's father (Amsterdam) owned a radio store, so she's 1940's tech-savvy. A friendly Southampton 'wireless & gramophone' store owner, whose store was bombed, has been helping her scavenge whatever parts are available. She might just have Morse to begin with, but I'm aiming for a happy moment when a friendly Royal Signals radioman makes his gear available so she can talk to her parents. Annike's radio "just happens" to pick up transmissions (voice? Morse? I don't know) from villains in Southampton trying to inform the Nazis about the where and when of Operation Overlord. Adventures ensue. Most likely I think using CW. PS I am trying to help this person in my capacity as BVWS Archivist
14th May 2020, 10:37 am | #10 |
I'll see what I can do.
The use of speech by agents would have been very unlikely. As far as I know it was only used by the British in the S Phone, a 200mW AM transmitter operating around 337 MHz. It was used to communicate with an aircraft or submarine. The Germans may have had something similar, but accidently receiving the transmissions on domestic or even amateur gear would have been unlikely. Morse on HF would have been much more likely. Might not Annike have built a transmitter to a design taken from the RSGB Bulletin (Bull)? The suggestion of using the O/P valve of a short wave equipped domestic radio receiver with a suitable adaptor is a good one. I believe the radio's IF stages were set to be unstable, acting as a BFO to enable CW reception.
14th May 2020, 10:48 am | #11 |
Thank you again Graham, I am afraid that is the only information I have on the story.
14th May 2020, 11:37 am | #12 |
I found my photograph of the Guernsey one if it helps at all. Beside it was a newspaper article showing an OM holding the crystal microphone so we can assume it was a phone transmitter and one of the two large valves is the modulator and the other one the RF PA.
14th May 2020, 11:48 am | #13 |
Thank you Jon,looks like two PX4,s (worth mega money).
14th May 2020, 1:53 pm | #14 |
The newspaper article also made it to my photo collection. I won't post that since it could have copyright issues. It does say the unit was tested and proven to work (causing interference to local radio reception and a bit of a security scare) but it was never used in anger. It was seen as something to keep for last resort and very few knew about it.
The most useful technical part says the dynamotor to the right of the picture was 400V output and driven from a car battery. |
14th May 2020, 2:04 pm | #15 |
Considering the receiver part of this, the one used to receive the villians' transmissions and presumably transmissions from Holland.
The radio shop owner might have been a radio amateur in which case he'd already have a suitable HF receiver. Transmitters had to be handed in at the start of the war, I'm not so sure about receivers. If he was a amateur he might have been a Y service operator who would intercept enemy transmissions for the government. Otherwise a domestic receiver with short waves could have been used. I believe some domestic sets had BFO's? A TRF receiver on the point of oscillation could have been used, or a receiver which had been damaged in a air raid causing the IF stages to go unstable. Just a few ideas to kick around. Still considering the transmitter and looking at 1939 RSGB Bulls.
14th May 2020, 2:43 pm | #16 |
Thank you Graham, not sure about domestic sets having a BFO though, I have never seen one.
TRF receiver I would think was being used, so that just needs a simple CW Tx. Possibly 807 output and an oscillator. Or of course could have been a pretty domestic valve line up.
14th May 2020, 2:44 pm | #17 |
I think they're likely to PX25s.
I've got a military branded balloon style PX25, and it's even got a special label attached to it stating that it's "for ground use only", or something to that effect, so not to be used up in an aircraft, I guess. I've got a few of these large valves marked as such. I've also got a 'Dynamotor' almost identical to the one shown in that picture. |
14th May 2020, 5:04 pm | #18 | ||
Ref BFOs in domestic sets, I wonder if they were needed, as marine comms at the low end of the Medium wave would have been on MCW. Unsure about aircraft comms, could be either CW or MCW I suppose. Cheers Roger/G3VKM |
14th May 2020, 6:46 pm | #19 |
PX25,s oh well they will not be worth much!!Thank you I must dig out the old R/Bygones.
14th May 2020, 11:26 pm | #20 |
There were plenty of transmitter designs, and detailed construction plans, in various textbooks of the period.
Try the 1st edition of the RSGB Handbook from 1939, or the 2nd edition (1941) which was reprinted in large quantities as an aid to training radio mechanics in the Services. Somewhat better are the pre-WW2 ARRL and Jones radio handbooks which would have been available as imports from the USA. |
