12th May 2020, 7:48 pm | #1 |
Dansette turntable fault query
Hello. I'm a newbie here.
I have a Dansette Bermuda Mk1. When I put a record on to play, the mechanism takes an eternity to get the record on to the turntable - the turntable barely moves. Once the record drops on to the playing surface, the speed seems to pick up, and the record plays (reasonably) well. Any tricks / tips / advice how to fix this fault would be appreciated. Details of a suitable repairer (Swansea / South Wales area) would also be greatly appreciated, as I'm keen to play my vinyl. Cheers |
12th May 2020, 10:16 pm | #2 |
Re: Dansette turntable fault query
Id say it needs a good ole clean up on the moving parts as the grease hardens with age another thing could be the inner rim on the platter/turntable needs a clean where the rubber idler wheel touches it, i tend to use Isopropyl Alcohol and clean the inner rim edge
Link below may be usefull https://www.vintage-radio.net/forum/...d.php?t=166690 |
13th May 2020, 12:50 am | #3 |
Read the sticky thread on restoring autochangers. I would first give the edge of the rubber idler wheel a going-over with an emery board to expose new rubber.
Regards, Ben. |
13th May 2020, 12:26 pm | #4 |
What Ben said - my own abilities, skills and knowledge have been considerably enhanced by working methodically through this sticky thread:-
https://www.vintage-radio.net/forum/...ad.php?t=75401 If you intend to play modern stereo records then come back to the Forum for advice when you reach the stage of restoring/replacing the cartridge!
BVWS Member |
21st May 2020, 7:09 am | #5 |
Great stuff. Thanks for the tips everyone
