23rd May 2018, 1:48 pm | #1 |
Calling on knowledge for a Ferguson 3425 record player.
Hello
I need some advice/help on a ferguson unit. I have a few issues.. firstly regardless of which speaker I plug in the left channel is a lot lower in volume than than the right. the radio only picks up bbc4 When you try to use the turntable there is an awful loud noise that doesn't stop I have attached an image of the underside of the deck and there seems to be a wire loose which I'm guessing what earths it and which is why there is the noise? Here is a video of the 'noise' problem. https://youtu.be/gtFSPY4ZB74 and lastly there is a random loose spring (also attached a picture) I have fixed smaller portable record players before - but this unit is far more complex than anything I have worked on - so I'm looking for advice before I even start ti tackle it. |
23rd May 2018, 2:02 pm | #2 |
Re: calling on knowleged for a ferguson record player
The mains power cable in the first photo looks lethal, attend to safety before anything else.
Frank |
23rd May 2018, 2:06 pm | #3 |
...or is that an old bit of mains cable being used as the signal cable?!
More pictures, please. |
23rd May 2018, 2:09 pm | #4 | |
Does look like one or more of those connections is dodgy though. Martin
BVWS Member |
23rd May 2018, 2:11 pm | #5 |
Re: Calling on knowlege for a Ferguson record player.
That wiring is an absolutely appalling mess. Look at the way the white wire is routed round the others.
Looks like old mains cable is being used to carry low level signals. Replace it, preferably with some screened stuff. Attend to the obvious things first. What's the model number or name?
23rd May 2018, 2:25 pm | #6 |
Sounds like there is some RF breakthrough as well. Plugging in different speakers is unlikely to restore volume to the LH channel, it is liable to be an amplifier fault. In the meantime, how experienced are you in troubleshooting and measuring voltages and values?
Edward. |
23rd May 2018, 2:46 pm | #7 |
agreed - the wiring is shocking and in very bad shape
I have attached some more images of the underside I cant see a model of the actual record player it just says 'ferguson unit audio fm stereo' on the badge the actual record deck is a Garrard SP25MKII thanks for all the replies so far! |
23rd May 2018, 3:21 pm | #8 |
Must admit I thought it was the mains wiring but yes I can see it likely is for signal.
Still two mains cables coming out of the unit, the other for the motor, the wrong one could easily be connected by someone not conversant with it.
Frank |
23rd May 2018, 4:31 pm | #9 |
A photo of the complete Fergusn unit would greatly assist in identifying it. In addition, Ferguson usually printed the model number on the back cover, and a small white rectangular plastic label, visible from the outside. The model numbers for their “Unit Audio” range usually have four digits, beginning with 34xx.
24th May 2018, 1:16 am | #10 |
Re: Calling on knowledge for a Ferguson record player.
In the name of all that is holy...in three and a half decades collecting and repairing this kit, I've never seen wiring that bad! How on earth do you mangle something that much?!
If you don't have any suitable cable to hand, just get a RCA-RCA lead from a pound shop and cut the plugs off one end. Strip and solder the wires to the tag strip (all the 'earth' shielding can probably be connected to the inner three tags as at present).
Regards, Ben. |
24th May 2018, 7:19 am | #11 |
Ye gods! I haven't seen anything like that since the Studer somebody attacked with a gas poker...
24th May 2018, 8:40 am | #12 |
As Ben has mentioned, obtain some screened cable & replace the rotten lead on the turntables audio output tag strip, plus a general tidy-up of the original tag strip tone arm wiring.
Sounds like some switch cleaner is needed on the switchbank & potentiometers to stop the crackling. The amplifier being quieter in one channel than the other, most likely the negative feedback electrolytic (could also be dirty switches or pots). Replace both left & right negative feedback capacitors, if ones going, the other won't be far behind. Check the input & interstage decouplers too. If you have a 'scope & sig-genny, it'll make life a bit easier. Mark |
24th May 2018, 9:04 am | #13 |
Someone who knows nothing and uses a poker as a soldering iron (soldering in the loosest possible term)!!
24th May 2018, 9:16 am | #14 |
Looks like the eponymous DPO has been at it big time.
(D****d Previous Owner)
24th May 2018, 9:46 am | #15 |
Either he or the Phantom Bodger so beloved of Radiophile!
24th May 2018, 12:31 pm | #16 | |
there are a lot of circuit boards - this thing is a beast also I can not find any model number (i did look the first time) Please see attached for new images of full unit and here is a short video of all the boards https://youtu.be/anH7tYi_c_0 |
24th May 2018, 12:35 pm | #17 |
Simple things first!
Fix the wiring to the arm. Work the balance control back and forth, applying Servisol if possible. Swop over the channels at the cartridge to see if the low output fault moves to the other channel which would indicate a cartridge or stylus fault.
24th May 2018, 12:39 pm | #18 |
For the model number it might be Ferguson 3425.
Lawrence. |
24th May 2018, 12:42 pm | #19 |
There is a white piece of paper near the loudspeaker sockets with the model and serial number, the serial number is in big numbers, cannot quite read the model but should be clear when looking at it in front of you.
Looks like it’s 34xx , Lawrence is probably correct.
Frank |
24th May 2018, 12:57 pm | #20 | |
Re: Calling on knowledge for a Ferguson 3425 record player.
Also Lawrence you are right with the model number.... i don't know how I missed that! >< |
