Old 26th Apr 2018, 10:34 pm   #1
TowerRadio
Default Wolf Saphire drill rectifier blown
I have two of these drills ,the one I bought in 1975 blew the dual speed rectifier and shortly after the switch packed up. This one I use at fixed high speed with a foot switch and a Wolf drill column. The other one has also blown its speed rectifier with a loud crack. I know from the first drill that this rectifier is a very small thing, about the size of a 1N4001. Any ideas what I could replace it with? (The Rifa 0.1 250volt PMX 2003 had blown up before I obtained this drill so that needs to be changed also)
TowerRadio is offline
Old 26th Apr 2018, 11:56 pm   #2
Refugee
Refugee's Avatar
Default Re: Wolf Saphire drill rectifier blown
The capacitor fails first and due to the spikes the diode fails later.
I would use another 800V diode of any make and a new mains rated capacitor.
You can go bigger with the diode such as 1N5407.
http://uk.farnell.com/c/semiconducto...ctifier-diodes
A pulse capacitor of the type found doing flyback duty in an old CRT screen can be used.
The value is not too critical but make it more than about 0.01uf.
We will need to know the package type for the capacitor.
Refugee is offline
Old 27th Apr 2018, 8:19 am   #3
barrymagrec
Not quite on topic but I have a 35 year old Wolf Saphire 4 inch angle grinder and a couple of weeks ago while using it the supressor cap exploded and sent a lump of molten innards out of the vent and burnt the side of my face - the grinder carried on unperturbed.
barrymagrec is offline
Old 27th Apr 2018, 10:45 am   #4
Boater Sam
I was going to offer free Rifa caps to replace these, I had 40+ of them, new, but thought better of it as I would not be popular when they blew.
Some of them were already cracked!
1N4007 would do but 1N5407 is better, as has been said.
Boater Sam is offline
Old 27th Apr 2018, 11:27 am   #5
TowerRadio
Thanks for the replies, I have a 33nF 1100v cap I shall use(courtesy of whiskas) and somewhere I have a 1000 volt 3 amp rectifier which will probably fit outside the switch.Les
