Old 21st Mar 2018, 12:19 pm   #1
boombox
Default 4T receiver
Just looking into getting a new 4T receiver, seen on Telephone Lines he does a modern replacement - but the connections are different. Will this mean replacing the spade terminals on the wires in the handset with a female connector?
Thanks!
boombox is offline
Old 21st Mar 2018, 12:39 pm   #2
G6Tanuki
G6Tanuki's Avatar
Default Re: 4T receiver
The one in thta link looks to have 'mini blade' connectors so yes you'll need to replace the spades you already have.
G6Tanuki is offline
Old 21st Mar 2018, 12:44 pm   #3
Nickthedentist
Nickthedentist's Avatar
I suspect those were out of a Statesman or similar.
If you're adept with an iron (and lucky!), you might be able to tack the right style of push-on connector onto the existing tags, then cover everything with heatshrink.
The tinsel wire in curly handset cords are nightmare to re-terminate so I'd try to preserve the spade terminals rather than chop them off.
Alternatively, have you tried requesting a normal 4T here? There are loads about, I'm sure.
Nick.
Nickthedentist is online now
Old 21st Mar 2018, 7:39 pm   #4
Sparks
Unless I'm mistaken, these 'other' 4T inserts look to have an impedance of 600 ohms. I don't know if that is significant technically.
Sparks is online now
Old 21st Mar 2018, 7:57 pm   #5
G6Tanuki
G6Tanuki's Avatar
"Mini blade" push-on connectors are available easily: your local Halfords will have them. In your situation I'd get a set of mini-blades, then cut the actual spade-part off your eisting tags, leaving the crimp-part of the old spades still attached to the cable [so preserving the existing contact with the 'tinsel']
This is essentially using the crimped part of the old spades as a 'bootlace ferrule' to fit into the mini-blade connectors where the cable would usually go. Then push the crimped-part of the old spade-tags-on-the-ends-of-the-wires into the mini-blade, and crimp. Job done!
G6Tanuki is offline
Old 21st Mar 2018, 8:56 pm   #6
Nickthedentist
I like that idea, G6T.
Old 21st Mar 2018, 10:22 pm   #7
russell_w_b
russell_w_b's Avatar
Originally Posted by Sparks View Post
'...these 'other' 4T inserts look to have an impedance of 600 ohms. I don't know if that is significant technically.'
I tried a 'new' plastic 4T from a BT Ambassador against a 'traditional' 4T as used in a 700 series instrument.
* Old receiver: 61.6 Ohms Z @ 1kHz.
* New receiver: 462 Ohms Z @ 1kHz.
The sound of the newer receiver is faint compared to the original in a 746 instrument, where the impedances of the sidetone network are optimised for the original 4T impedance, but is still audible.
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
