11th Jan 2018, 2:50 pm | #1 |
Help please with Unitra ZRK Goplana.
Hi, need some help please. I know nothing about electronics.
I bought this radio, it's in very good condition. The problem I have is I turn it on it warms up and I get sound. However after a minute the sound fades away to nothing. Turn the radio off, leave it for 20 seconds, turn it back on get sound again. It warm up and the sound goes again. Has anyone please got any ideas please? I would be most grateful if someone can help. Last edited by Station X; 11th Jan 2018 at 3:14 pm. Reason: Readability. |
11th Jan 2018, 8:10 pm | #2 |
Re: Hi. Help please with Goplana.
Details of the radio model would help us.
Mike |
11th Jan 2018, 8:44 pm | #3 |
Unitra (ZRK) Goplana.
Steve P did one here: https://www.vintage-radio.net/forum/...ad.php?t=30483 I have also repaired one and found lots of leaky capacitors. |
11th Jan 2018, 8:46 pm | #4 |
Looks a nice set!
11th Jan 2018, 9:01 pm | #5 |
Hi, the model I think is a ZRK Goplana. That is what on the back, where else would I look? Thank you.
11th Jan 2018, 9:02 pm | #6 |
Hi Sprit, it looks as if it could be leaky capacitors, please read some of the threads that refer to "THAT" capacitor. It would be unwise to switch it on again until you get it sorted as you could cause expensive damage on an otherwise nice set.
Ed |
11th Jan 2018, 9:30 pm | #7 |
Re: Help please with Unitra ZRK Goplana.
As you are discovering, you can't buy an unrestored 50 year old valve radio and expect it to just work. You could learn how to restore it yourself, or pay somebody to repair or fully restore it for you. There is a forum section for commercial repair requests: https://www.vintage-radio.net/forum/...play.php?f=145
If you have no electronics expertise at all there will be a lot to learn if you want to do it yourself, but it's perfectly possible if you are genuinely interested. Forum members here are very supportive of beginners and can provide lots of advice and guidance. |
11th Jan 2018, 9:54 pm | #8 |
Hi. I've taken a picture of the valves. Have they blown please?
11th Jan 2018, 10:35 pm | #9 |
Valves don't 'blow'. They are rarely responsible for radio faults. There is no shortcut here - you're going to have to teach yourself how valve radios work, or take it to somebody with the right skills.
11th Jan 2018, 11:44 pm | #10 |
If you've had sound out the set, it's highly unlikely the valves have blown..... yet.
Valves can be mechanically fragile, but electrically they're generally very robust.
11th Jan 2018, 11:49 pm | #11 |
Thank you.
12th Jan 2018, 1:36 pm | #12 |
Hi took a picture of this. What is this? Plus the beige capacitor is getting very very hot 155 deg C. Is this normal please?
12th Jan 2018, 2:13 pm | #13 |
There is no image attached to your post. Try again. It helps to use the "Preview Post" button.
12th Jan 2018, 3:49 pm | #14 |
Hi all thank you everyone for your help.
Luckily I've found someone locally that can repair it. Fingers crossed it won't be expensive, thank you all again. |
12th Jan 2018, 4:22 pm | #15 |
A wise choice I'd say.
20th Jan 2018, 2:32 pm | #16 |
Re: How to shorten a ferrite slug?
hi brought other just for spares however this one work expected the MW.what component in the radio that get MW . i know the silver things in that does the frequencies.however li LW and SW and FM work ok . but not MW is there a resistor or a capacitor has blown or something like that . or is a valve that does this. getting a white noise but no stations please
20th Jan 2018, 3:00 pm | #17 |
Any chance of plain English? Context?
20th Jan 2018, 9:10 pm | #18 | |
Attempt at rendering into English:-
20th Jan 2018, 9:11 pm | #19 |
The most likely culprit is the wave change switch. Try cleaning it's electrical contacts with Servisol.
24th Jan 2018, 4:04 pm | #20 |
Re: Pye PTC4001 Tulip microphone
hi i fix the radio its was the valves ebf 89 and ehc 82 . like to thank you of all your help . thank you
