Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Repair and Restoration Services Wanted
Repair and Restoration Services Wanted If you need someone to repair or restore equipment for you please post your request here.
Old 10th Jan 2018, 10:40 pm   #1
nikucry
New Member
Default Servicing Sansui 9090DB
Hello, I am looking for a person who can service my old Sansui 9090DB. It's all in original condition, works lovely but it's time to change all the caps, transistors, resistors, etc. I am in Norwich.
nikucry is offline
Old 10th Jan 2018, 10:55 pm   #2
Default Re: Servicing Sansui 9090DB
Hello and welcome to the forums.
I cannot help you with this, however there is NO reason why ALL caps, resistors and transistors should be changed. Apart from anything else it would be a mammoth task.
If it works satisfactorily just continue to enjoy it.
Keep the soldering iron hot.
Station X is online now
Old 10th Jan 2018, 11:44 pm   #3
sortedradio
sortedradio's Avatar
If it "works lovely" what makes you think all these components require changing? It's usually pretty noticeable if you have a faulty transistor! You could get the amp checked out to see whether it still meets the manufacturers spec and have the dust blown out etc, then take it from there. I tend to agree with Graham though, as disturbing these things unnecessarily is often when the problems begin.
sortedradio is offline
Old 11th Jan 2018, 9:09 am   #4
If you're determined to go ahead with this, try this company:-
http://vintagetvandwireless.com/
