25th Jan 2019, 11:28 pm | #1 |
Diamond stylus DSC 1052 philips GP215
Hi All can someone tell me if the dsc 1052 philips gp 215 stylus is safe to use on my records. It say it should be set at a weight of 5 gram but should I go less. I recently got an old philips 3 band stereo record player back working. This is the stylus it takes as far as I know. Was told I should up grade the speakers but would have to be three pin and 8 ohms. Any advice on what type I should go for.
Thanks David |
26th Jan 2019, 11:18 am | #2 |
Re: Diamond stylus DSC 1052 philips GP215
Speakers were usually the weakest link in a typical 1970s stereo seperates system.
You say any replacement speakers wound need to be 8 ohm, well most are anyway, and "3 Pin" - what this 3 pin? All speakers are 2 pin.
Edward. |
26th Jan 2019, 5:31 pm | #3 | ||
As the system uses a ceramic cartridge it is unlikely to be particularly high quality or high power so any improvement from better speakers will be limited. |
26th Jan 2019, 8:16 pm | #4 |
the GP215 is sold as a complete ceramic stylus-cartridge assembly. It is stereo so safe to use. Tracking weight is as you said, 5g is towards the heavier end, but I would not go lower than 4 for the reasons James mentions.
If you post pictures of the speaker connectors we can advise.
Regards, Ben. |
