Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Reply
Old 19th Aug 2018, 6:24 pm   #1
yestertech
yestertech's Avatar
Default Socket half of this connector needed
I have a piece of home brew gear to test which has this connector for HT/LT supplies. Does anyone have a mating socket available ?
Thanks
Andy
Name:	7 way plug lbl.jpg
ID:	167857   Click image for larger version
Name:	7 way plug.jpg
yestertech is offline   Reply With Quote
Old 19th Aug 2018, 8:19 pm   #2
robinshack
Default Re: socket half of this connector needed
Hi Andy,
A cable mounted socket (like your plug) or a chassis mount flat paxolin type?
Rob
I am also interested in and collect 00 model railway.
robinshack is online now   Reply With Quote
Old 19th Aug 2018, 8:27 pm   #3
Pamphonica
Pamphonica's Avatar
Hi Andy,
Isn't that similar to the Belling-Lee O-Z series, as in this previous thread?
https://www.vintage-radio.net/forum/...d.php?t=136804
Sorry I have checked stocks and Pamphonic used the 5-pin variant, not the 7-pin.
I'll keep an eye out..
all best
Jeremy
Jeremy, G8MLK, BVWS Member, BVWTVM Friend.
www.pamphonic.co.uk
Pamphonica is offline   Reply With Quote
Old 19th Aug 2018, 9:02 pm   #4
yestertech
yestertech's Avatar
Thanks Jeremy, Yes I found a 5 pin one in my stock too !
Rob, Either would suffice, although the cable mounted socket would be the most ideal as it won't need a ton of PVC tape wrapped around it !
A,
Old 21st Aug 2018, 8:38 am   #5
robinshack
Default Re: Socket half of this connector needed
I have a paxolin chassis mount one.
I have never seen a MATCHING cable mount type, like I suggested previously!
Yes, there is a 7 pin cable female, but it has the centre spigot just like the male, so no way can they connect. That is what confused me in my previous post.
If it is any use, pm me your name and address and I will post it to you.
Unless you are at St Neots rally, which is a long way for you!
Rob
Old 21st Aug 2018, 10:48 am   #6
yestertech
yestertech's Avatar
PM sent !
A
Old 21st Aug 2018, 4:18 pm   #7
M0FYA Andy
I agree with Rob, there is a 7-pin free socket, Socket Type 105, 10H/256, but it has a central spigot.
It may be that the fixed part, made of paxolin, always has the central hole, whereas the free part, made of bakelite, always has the spigot.
If anyone finds a free part with hole, or a fixed part with spigot, it would be interesting to see a picture.
Andy
M0FYA Andy is online now   Reply With Quote
Old 21st Aug 2018, 5:14 pm   #8
robinshack
PM has not arrived yet. Please resend..
This has happened more than once before for some reason or other.
Even sinewave had a recent reply that disappeared from my offered post!
Rob
Old 23rd Aug 2018, 9:30 am   #9
robinshack
Would a moderator please contact OP as I don't get his pm and I sent one yesterday but no response.
Thanks, Rob
Old 23rd Aug 2018, 9:54 am   #10
Pamphonica
Pamphonica's Avatar
I know Andy - I've rung him.
He will email you. If that fails, PM me and I'll pass on his details.
Jeremy
www.pamphonic.co.uk
Old 23rd Aug 2018, 9:54 am   #11
Station X
Station X's Avatar
Thanks, Rob
OP hasn't been here since 21 August, so he won't have seen your PM
Graham. Forum Moderator
Keep the soldering iron hot.
Station X is online now   Reply With Quote
Old 23rd Aug 2018, 10:08 am   #12
ronbryan
There also seem to be two types of Belling-Lee O-Z chassis mounting sockets - one with insulated pins and the other with exposed pins.
Ron
ronbryan is offline   Reply With Quote
Old 23rd Aug 2018, 10:17 am   #13
robinshack
Ok, Thanks for checking, Graham
Rob
Old 23rd Aug 2018, 10:58 am   #14
yestertech
yestertech's Avatar
Sorry Rob - not sure what happened there ? details re-sent !
thanks
A.
Reply
