Old 14th Aug 2018, 12:24 am   #1
Jolly 7
Default Good MW reception conditions
Over the years I have always associated the winter months with the best MW DXing. However, recent experiments with a DIY amplifier loop antenna in the loft has brought me in some low power catches I had never heard in the summer till now. The first one is Vahon Hindustani radio on 1566 kHz from a 1 kHz transmitter in Holland. The second one is Radio Panj from Coventry with a listed power of only 0.04 KW. Both were heard around midnight tonight. I am using a Sangean ATS 909X for my DXing. Maybe the recent closure of some BBC LPTs has helped or maybe we are heading towards a solar cycle trough
Jolly 7 is offline
Old 14th Aug 2018, 7:23 am   #2
Jolly 7
Default Re: Good MW reception conditions
Apologies for the typo..I meant 1 KW, not kHz.
Jolly 7 is offline
Old 14th Aug 2018, 9:07 am   #3
Hybrid tellies
Hybrid tellies's Avatar
Hi, MW reception depends on your location including the local noise levels. Your DIY amplified loop is obviously working very well. I have found that the local noise levels from late evenings onwards can drop significantly allowing for some very conditions. I think its down to nosy plasma TV's, LED and CFL lamps being switched off.
Are you able to rotate your loop aerial whilst you are listening?
Simon
BVWS member
Hybrid tellies is offline
Old 14th Aug 2018, 12:38 pm   #4
Ian - G4JQT
Ian - G4JQT's Avatar
Medium wave is also slowly clearing of stations across Europe, leaving gaps though which DX stations can now be heard. But your loop antenna certainly helps!
Ian - G4JQT is offline
Old 14th Aug 2018, 1:35 pm   #5
Jolly 7
I am able to rotate my loop aerial in the attic from below by means of sending 9V DC up the coax downlead. I tried to isolate the DC from reaching the loop itself by a 0.01 uF polyester capacitor, but it seriously reduced the amplification of the antenna. So the motor is out of action and that means many trips up and down the loft ladder at present ! I am using a geared motor, but I don't have the option of using two or even twin downleads as this would involve very significant work. I am powering the motor and loop from downstairs but need to think of a solution to my current problem. I know that there are RF controls for stepper motors on eBay, but unsure if anything similar exists for geared ones.
Jolly 7 is offline
Old 14th Aug 2018, 2:09 pm   #6
ms660
ms660's Avatar
Were there RF chokes fitted with the DC up the coax and motor?
Lawrence.
ms660 is offline
Old 14th Aug 2018, 2:53 pm   #7
Jolly 7
No, I haven't fitted any RF chokes.
Jolly 7 is offline
Old 14th Aug 2018, 3:43 pm   #8
ms660
ms660's Avatar
Connecting a DC power supply across the coax will present a low impedance to the signal, ditto for a motor, hence the need for RF chokes (as well as a DC isolating capacitor for the loop antenna and also one for the receiver if needed) A problem might be the frequencies you're interested in, lower frequencies would need a higher inductance choke, that in turn might mean power dissipation or voltage drop problems for the DC circuit depending on the motors current draw.
Lawrence.
ms660 is offline
Old 15th Aug 2018, 9:11 am   #9
boxdoctor
I think ms660 has a circuit something like the attached in mind.
The main problem I came across when I constructed such an arrangement was motor noise on the signal when turning the loop. This was eventually resolved with lots of suppression at the motor end of the co-ax, on the motor supply.
A D.C. motor was used, and reversed by reversing the polarity of the supply.
Voltage drop in the R.F. chokes is easily dealt with by increasing the motor circuit D.C. supply voltage. Tony
boxdoctor is offline
Old 15th Aug 2018, 9:15 am   #10
Hybrid tellies
Totally agree, since they have switched off the power houses in Switzerland and Germany I can clearly pick up BBC R4 on 756 from the 2kw Redruth transmitter and can clearly hear BBC R Essex on 765 from the low powered transmitter at Chelmsford. Since the high powered transmitters in France closed down Pulse 2 from Bradford on 1278 is now a regular evening visitor whilst on 864 ERTU from Egypt can now be heard clearly late evenings.
Nowadays I find the best AM aerial to use is the radios built in rod aerial with its directional properties to null out local electrical interference as much as possible.
Simon
BVWS member
Old 15th Aug 2018, 10:51 am   #11
dave walsh
I'm not sure if this relates to the issues discussed here or should be on a "Pirate" Thread. My friend Pat [ex Electronics Tech and Street "Furniture" ie Lighting etc supremo] has returned to Bury from Leeds. Last Saturday he heard Radio Caroline North on 1368k Broadcasting from the Ross Revenge parked in Ramsey Bay. He says he listened for a long time and it was 1964 all over again!
Apologies if this is already known to retro Medium Wavers
Dave W
There is a list of outings on http://www.offshoreradiomuseum.co.uk/page1022.html
dave walsh is offline
Old 15th Aug 2018, 5:42 pm   #12
Jolly 7
Thanks for the above and the diagram. I hadn't considered suppressing motor noise on the RF signal till now, so I will bear that in mind. Here is an example of motor noise suppression using a 473Z capacitor across the motor leads with one lead also connected to the motor case. This is a surplus motor I bought recently, so I might steal the cap for my loop antenna motor
Jolly 7 is offline
Old 15th Aug 2018, 6:52 pm   #13
boxdoctor
Looks the right style of cap for the job.
You will need, I think, at least one across the motor terminals (Assuming its a similar type of construction to the one you show), then a small ferrite choke in each lead, followed by another cap of the same type across the leads on the other side of the chokes, and good motor terminal screening, connected to the braid of the co-ax cable, too. The caps should be at least 100nf in value. Tony.
Old 15th Aug 2018, 10:07 pm   #14
Jolly 7
I finally solved the problem of isolating the loop from the motor by connecting a 474K cap from one end of the loop to the central conductor of the downlead. I found out by trial and error that this value does not cause any attenuation of MW signals in my amplifier circuit before they reach my radio. Here are some photos of the loop and the controller unit, which I purchased from eBay. My next steps will be to try and fit both controller unit and amplifier in one box. I am able to control both the geared motor speed and direction.
ID:	167610   Click image for larger version
Jolly 7 is offline
Old 17th Aug 2018, 1:58 am   #15
Jolly 7
Here is a fresh DX catch from tonight using my loop antenna without any signal amplification. Betar Bangla on 1503 kHz from London was heard with fair to good signals for around 5 mins around 0145 BST in Southampton. Normally this channel is almost always occupied by BBC Radio Stoke or a Spanish station. I heard this station only once before on a 10m longwire antenna for a few seconds. The transmitter is only 100 W.
Jolly 7 is offline
Old 18th Aug 2018, 12:20 am   #16
Jolly 7
I think Radio Caroline on 1368 kHz uses Manx Radio's transmitter. Right now I am listening to Radio Caroline on 648 kHz, but it is suffering from deep fading. A mixture of Richard Marx, Don Henley and Slovenian music from Radio Murski, also on 648 kHz, is making most interesting listening !
Jolly 7 is offline
Old 18th Aug 2018, 9:04 am   #17
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
Jolly 7, you are correct. Manx Radio turns it's 1368kHz transmitter over to R. Caroline, I think, every four weeks at weekends. The programs are broadcast from the Ross Revenge, presumably via either an internet or satellite link. Schedules and other info. should be on both the R. Caroline and Manx Radio websites (I haven't checked recently, or yet been able to receive Manx R. here in N. Oxfordshire.)
'LIVEWIRE?' is offline
Old 18th Aug 2018, 8:11 pm   #18
MotorBikeLes
Over the next two weeks, Manx Radio's MW transmission prioritises the "Festival of Motorcycling", a mix of the traditional Manx Gran Prix and a Classic TT. Practice was on from shortly after 5:00pm, but appears to have finished early tonight (Mist on mountain probably)
Definitely better listening!
Les (who may be a wee bit biassed)
Last edited by MotorBikeLes; 18th Aug 2018 at 8:13 pm. Reason: Changed "is" to prioritised.
MotorBikeLes is offline
Old 23rd Aug 2018, 9:22 am   #19
Hybrid tellies
Here is an interesting one for you to try during the daytime. BBC Radio Hereford and Worcester is transmitted from the Worcester transmitter on 738Khz but it only uses a power of 37w. It comes in well here near Bath and I wonder if it makes it to Southampton.
I am just amazed at its coverage for such little power, it must be a good transmitter aerial and/or site.
Simon
BVWS member
Old 23rd Aug 2018, 3:30 pm   #20
m0cemdave
That quoted figure of 37W is going to be the ERP (or EMRP), i.e. the radiated power after feeder losses and aerial efficiency have been taken into account. The actual transmitter will be producing more power, probably a few hundred watts. But yes, it's surprising how little radiated power is required for a radio signal to provide good coverage.
m0cemdave is offline
