17th Apr 2021, 5:33 pm | #1 |
ID this cartridge/ stylus.
I need to order a new stylus for this cartridge, no make or numbers on it , Mick.
17th Apr 2021, 6:25 pm | #2 |
Re: ID this cartridge/ stylus.
no picture
17th Apr 2021, 7:18 pm | #3 |
I wonder where that went ! Its from an Ariston RD80 deck made in Scotland . Mick.
17th Apr 2021, 7:30 pm | #4 |
Moving (induced) magnet, and an overall outer screening can. Reminds me of Pickering and Stanton, but there were also several like this out of Japan. Does the turntable give any clues?
17th Apr 2021, 8:12 pm | #5 |
I have just removed the cartridge it does say Japan on it , Mick.
17th Apr 2021, 9:36 pm | #6 |
what is the make of the pickup arm the headshell looks like an ADC
Your pickup is definitely not a Stanton or Pickering It looks like one of the general generic Jape units For me I would tend to fit an Audio Technica there are many models available Trev |
17th Apr 2021, 10:10 pm | #7 |
Full cartridges aren't much more expensive than their styli, so if you change the full cartridge, then you know the styus fits.
Yes, the stantons and pickerings were quite a bit wider. This in the photo is narrow-bodied. The AT cartridges have average output and compliance and should just work fine. David
17th Apr 2021, 10:54 pm | #8 |
Done a bit of Googling and I think you may have an OEM Yamaha CG-6800 cartridge. There's also a Sanyo OEM version too it appears. They seem to be re-branded versions of the Audio Technica AT750.
17th Apr 2021, 11:14 pm | #9 |
An AT-95 would be the obvious choice as a replacement. I'll guess the arm as being a Linn LVV.... just based on what would have been available and recommended by hi fi dealers etc at the time the RD-80 was new and had a standard (SME type) removable headshell. ADC LMF-1 replacement headshell was a common "upgrade" at the time.
18th Apr 2021, 9:15 am | #10 |
Thanks for the info , question ! how would you rate the deck /is it worth keeping I don't think it would be a lot of money , it came with a lot of six items for me to repair, his complaint was the deck keeps throwing the belt off ,the platter was riding high , when I turned the deck up side down a load of oil come out of the bearing , now the platter sit's down ok , is there a procedure for oiling these, Mick.
18th Apr 2021, 9:28 am | #11 |
What model Ariston ? They were in my time high end along with the Linn Sondeck etc.
Well worth sorting ! Sounds like it has been over-oiled and may have been hydraulicly locked as regards to level I sold a large no of these at the time RD11 |
18th Apr 2021, 9:41 am | #12 |
Hi Trevor it is an RD 80 ,ref to the amount of oil I wonder if there is a measurement guide as to the height of the platter. Mick.
18th Apr 2021, 12:11 pm | #13 |
So Sorry I have no personal knowledge of the RD80 it came on the market at the same time that i left the trade !
looks to me as if they were after the Rega market Trev |
