16th Apr 2021, 8:54 pm | #1 |
Location: Celbridge, County Kildare, Republic of Ireland.
Philips Radiogram FIF652A.
Hi Guys 🙌
Looking for some info on this Philips Radiogram I picked up yesterday. Turntable not connected - needs a bit of work I'd say. Havent dived into upcycling it yet. (Starting Monday) Radio is working but only picking up 2-3 channels (BBC, RTE & another one in French) I've searched everywhere for photos of this particular model as I'd really like to bring it back to life. The previous owner started as you can see - I'll definitely be sanding it back! Any information or tips on how to even get started on the upcycle process would be much appreciated! |
16th Apr 2021, 9:34 pm | #2 |
Re: Philips Radiogram FIF652A.
Radios with FIF prefixes were manufactured by Philips Electrical Ireland Limited in Dublin.
Some FIF units are listed on the Radio Museum website for example:- https://www.radiomuseum.org/r/philips_fif_660a.html You may have to search the picture on Radio Museum to find a similar British made unit. The circuit should be similar. Info on the Interphone AF7800 here:- https://www.vintage-radio.net/forum/...ad.php?t=58055 Useful restoration info here:- https://www.vintage-radio.com/repair...ion/index.html
16th Apr 2021, 10:49 pm | #3 |
I have never seen an Irish made radio from this era with VHF. RTÉ only started broadcasting a VHF/FM service in 1966, right at the end of the valve era. I suppose listeners in border regions and as far south as Dublin could receive BBC VHF services from NI or Holme Moss with the right aerial setup. These transmitters would have been available from the late 50s.
I wonder if the model number is a coincidence, and this isn't actually a Philips Ireland model. The tuning scale isn't easy to read in the photo, but it looks as if it may be for the UK. |
16th Apr 2021, 11:37 pm | #4 |
Hi LD,
Your radiogram looks rather like a slightly simpler version of the Philips 653A https://www.radiomuseum.org/r/philips_653a.html Peter |
17th Apr 2021, 9:38 am | #5 |
I only have a rough idea of what you mean by "upcycling" - do you mean you will strip out the internals and use the cabinet for some other purpose? However, if you intend to restore it back to being original, do be aware that the Autochanger is not complete and can never fully work as it is. And the mechanics on these are fiendishly difficult to repair. Please let us know your plans for this?
Edward. |
17th Apr 2021, 5:01 pm | #6 |
I think the only part of the autochanger that is not visible is the long centre spindle which is swapable with the short spindle if you just want to use it as a single player. As I remember it there was a little Terry clip somewhere to the side of the deck where the out of use spindle was stored. The Philips crystal pick-up will no doubt be dead and unobtainable.
Peter. |
