Old 5th Nov 2018, 11:30 pm   #1
Phil G4SPZ
Phil G4SPZ's Avatar
Default Smiths ‘Bijou’ synchronous clock motor
I’ve had some experience and success with a number of Ferranti electric clocks, but my first attempt to repair a 1950s Smiths model CA alarm clock fitted with a Bijou motor has been a bit of a disaster.
A friend asked me to fit a new flex to his clock, but on test the motor would not self-start and seemed to lack torque when running. This motor is the later type with the external flywheel and hairspring. I measured the coil’s DC resistance at about 3.5 kilohms, which I think is rather too low as I’ve read that these are normally around 11k, so I suspected shorted turns. I attempted to gently part the two halves of the motor casing, whereupon the coil former fell apart. It looks like it had cooked and become completely brittle through overheating.
“No matter”, I thought, “I can rob the motor from that other Smiths clock in the to-do pile.” After a spot of lubrication, this second motor self-starts reliably and its stator coil measures 11.5k. But its pinion has 8 leaves instead of 12...
Hence I’m now looking for someone with the capability of creating a brand-new coil from scratch, or trying to find a working Bijou motor with a 12-leaved pinion. My friend who owns the clock would probably be happy with a quartz movement, but personally I’d prefer to keep the clock original if I can.
Attached are some pics of the sorry mess. Any advice from one of the Smiths electric clock experts would be welcome!
Phil
ID:	172286   Click image for larger version
ID:	172287   Click image for larger version
Phil
Phil G4SPZ is offline
Old 6th Nov 2018, 4:09 pm   #2
julie_m
Default Re: Smiths ‘Bijou’ synchronous clock motor
Is there a reason why you can't just transfer the armature with the 12-leaf pinion into the good stator coil?
julie_m is offline
Old 6th Nov 2018, 5:36 pm   #3
Phil G4SPZ
Phil G4SPZ's Avatar
I’d thought of that, but wasn’t sure that they’d be completely interchangeable. The rotor shaft has to be driven out through the hairspring collet. I don’t want to cause any more damage, although I could practice removing the rotor from the duff motor to start with.
I’m keeping an eye out for a donor clock of the same type. Incidentally, there’s an excellent exploded diagram and plenty of descriptive information on these motors in T R Robinson’s ‘Modern Clocks’ but it doesn’t mention the different pinions.
Phil
Old 6th Nov 2018, 6:36 pm   #4
Phil G4SPZ
Phil G4SPZ's Avatar
Originally Posted by Phil G4SPZ View Post
I’m keeping an eye out for a donor clock...
One has just been secured at a reasonable price. I’ll keep you posted!
Phil
Old 10th Nov 2018, 2:02 am   #5
Phil G4SPZ
Phil G4SPZ's Avatar
Result! The donor clock had been bodged before, but the motor was a good ’un and measures well over 10 Megohms insulation resistance.
Phil
Phil
Old 10th Nov 2018, 12:16 pm   #6
Lloyd 1985
Lloyd 1985's Avatar
I’ve just got myself a clock like that! Mine has the marbled case rather than brown. It worked well, but the wiring was horrific and it had been ‘oiled’ with WD40 all over it... it looks like it was never designed to come apart after it had been assembled, so cleaning it is going to be fun! The motor is good in mine too
Regards
Lloyd
Lloyd 1985 is online now
Old 10th Nov 2018, 2:54 pm   #7
Phil G4SPZ
Phil G4SPZ's Avatar
It might be worth trying to wash the excess oil away from the movement, perhaps using a solvent like petrol or lighter fluid on a modellers’ paintbrush. Once thoroughly dry, try sparingly lubricating with light oil like 3-in-1. These movements have only two arbors and these are slow moving. Where the oil is needed is along the common shafts where several wheels and pinions run. Getting oil into there might be tricky, as there is very little end shake or gaps. A hypodermic would be ideal if you can find one. Normally no oil is needed on the teeth, other than on the first fibre gearwheel that meshes with the motor pinion.
If you do decide that complete dismantling is necessary, T R Robinson’s book ‘Modern Clocks’ contains a page and a half of very detailed instructions and I could scan it and e-mail it to you if you drop me a PM. But it requires some specialist tools and is not for the faint-hearted!
Phil
Old 10th Nov 2018, 2:57 pm   #8
Nickthedentist
Nickthedentist's Avatar
Well done, Phil.
There are countless variations and improvements of the Bijou to be found over its 20-odd year production run, meaning that interchangeability of parts is not as easy as it might seem.
Originally Posted by Lloyd 1985 View Post
...it looks like it was never designed to come apart after it had been assembled...
I can't believe that, Loyd, unless it uses one of the later Smiths movements.
Some early cheapies, particularly American-derived ones, seemed to be riveted together, but most of the pre-1960 Smiths stuff is eas easy to work on as any other clock.
Could you post some pics in a new thread, please?
Nick.
Nickthedentist is online now
Old 10th Nov 2018, 5:16 pm   #9
Phil G4SPZ
Phil G4SPZ's Avatar
Thanks, Nick.
I confess I much prefer the Ferranti movement to the Smiths, although in fairness to both manufacturers, their clocks survive in healthy numbers eighty years on, so we can hardly complain about the occasional duff motor!
Phil
Old 12th Nov 2018, 12:32 pm   #10
Lloyd 1985
Lloyd 1985's Avatar
Nick.
Hi Nick,
Just started a new thread here
Regards,
Lloyd
