30th Jun 2020, 3:49 pm | #1 |
1960 green magic eye
Hi everyone, I'm restoring a 1963 valve tape recorder, the green magic lamp is working fine but my question is this:
The lamp has some red tape in the centre of the valve which must donate maximum input levels, this tape has come off, can you buy this tape or what type of replacement tape should i use as i reckon it must be heat resistant. Thanks Trev |
30th Jun 2020, 8:54 pm | #2 |
Re: 1960 green magic eye
I have only seen tape on a Magic Eye valve once before, not sure if it was an original fit or something that someone had added as a level indicator.
Could you get by with not replacing the tape ? David |
30th Jun 2020, 9:14 pm | #3 |
There were quite a few with a strip of red tape around the magic eye to show if the recording level was too high. Any red transparent tape, sweet wrapping, or similar will do. Not critical if you remember not to let the two beams get too close to joining.
30th Jun 2020, 11:58 pm | #4 |
Kapton tape would withstand the heat and be transparent and durable, but I have never seen it in red colour
Could you consider a thin coat of red varnish carefully applied using masking tape (removed before varnish sets) to get a clean edge Best Regards Chris |
1st Jul 2020, 8:49 am | #5 |
You can get transparent red gels for theatre lighting that will withstand the heat from the magic eye.
1st Jul 2020, 3:37 pm | #6 | |
Thanks, Trev |
1st Jul 2020, 3:38 pm | #7 |
Hi, ive got red tape but what about the heat generated by the valve? Could it be a fire risk.
1st Jul 2020, 3:40 pm | #8 | |
Trev |
1st Jul 2020, 5:11 pm | #9 |
There is very little heat in a magic eye (EM84?) . Risk of fire with any kind of tape must be miniscule. Different matter if it was round a thrashed EL84! Yes, I've seen tape on a M.E. long time ago, no idea what sort of tape though.
1st Jul 2020, 8:42 pm | #10 |
Hi, try a band of red nail varnish
Ed |
1st Jul 2020, 9:06 pm | #11 |
Hi!
This any good? https://www.ebay.co.uk/itm/273601434333 I'm not sure how heat resistant it is, but indicator valves only take very low cathode–currents with a typical anode dissipation of typically 0.25–0.5W, and don't run more than luke–warm in my experience! Chris Williams
It's an enigma, that's what it is! This thing's not fixed because it doesn't want to be fixed! Last edited by Chris55000; 1st Jul 2020 at 9:20 pm. |
1st Jul 2020, 9:59 pm | #12 |
Yes, this valve only gets warm rather than hot.
2nd Jul 2020, 5:58 am | #13 |
If I recall correctly, the EM84 valve when connected as suggested by the manufacturer has no overlap between the green segments at maximum input level, whereas the slightly later EM87 does. However, by juggling the resistor values - I think by placing a resistor in the connection between the target and B+, it's possible to get overlap also on the EM84, and some manufacturers such as Grundig did just that, whereas others, notably Philips, tended to opt for a red band.
The problem I feel with the red band is that it tends to cut down the light quite a bit, so rather than glowing bright red to indicate overload, one just sees the green segments disappear into the red area, so I the visual impact of just having two overlapping green segments is better. |
2nd Jul 2020, 9:36 pm | #14 | |
Much appreciated. Trev |
2nd Jul 2020, 9:37 pm | #15 |
2nd Jul 2020, 9:39 pm | #16 | |
Trev |
2nd Jul 2020, 9:42 pm | #17 | |
Thanks for your input. Trev |
3rd Jul 2020, 7:42 pm | #18 |
I used a Piece of red leader from one of my tapes.... formed it in a loop round the valve and stuck it with a bit of glue!!
It's still quite see through enough to see the beams // Regards Paul |
3rd Jul 2020, 8:27 pm | #19 | |
Checking a typical Grundig that uses the EM84 they use the same anode load resistor of 470k on pin 9 as the Elizabethan but whereas on the Elizabethan where the Target (pin 6) is connected to the top end of the anode load resistor/HT supply, the Grundig fit a 100k resistor between pin 6 and the top end of the anode resistor. Note on the Elizabethan the anode via the resistor is connected to a lower HT of around 160 volts (i.e. not the full/main HT) whereas on a typical Grundig the anode via its resistor is taken to the main HT of around 260 volts. Sometime out of interest I will link out the 100k resistor to see the operational effect. David |
3rd Jul 2020, 10:09 pm | #20 |
Hi!
The Robuk RK3/RK4 range of machines fit a 100k resistor between the target–anode pin 6 and the h t. supply lead – the Robuks tended to use a higher value of h.t. than was customary in most such machines, the Robuks I came across had a smoothed h.t. of 275–280V. (None of the Robuk Service Data I came across gave any component–values, valve types, operating–voltages, etc., on it) Chris Williams
