14th May 2020, 12:17 am | #21 |
Re: Bush VHF64 - Help required please!
Have you looked at the small electrolytic mentioned above yet, or tried swapping the EABC80?
I had a regular light "pop" on a VHF61, (was simultaneously getting very low VHF reception although not dead, magic eye was showing strong signal even between stations on all bands) IIRC it was a damaged replacement cap that I'd not noticed, may have been in the AGC circuit but memory eludes me as to exactly which and where. |
14th May 2020, 9:04 am | #22 |
Look out for small capacitors which look similar to resistors with bullet shaped ends, 1000pf (brown black red) was a very common value, these can be as leaky as the brown Hunts caps.
Mike |
14th May 2020, 9:19 am | #23 | ||
In other news I just picked up a Bush VHF61 in superb unblemished condition for just £10! That will be the next project and also what to do with the other VHF64 donor chassis and cabinet? |
16th May 2020, 2:32 pm | #24 |
Swapped out each valve in turn and I think the popping/screeching noise issue was a dodgy EL84 valve. The pristine looking Pinnacle EL84 was replaced with a worn and blackened Mullard and the noise issue went away.
16th May 2020, 3:19 pm | #25 | |
16th May 2020, 4:55 pm | #26 |
Once you've established that there's HT getting to the ECC85 ( easiest to measure at the valve pins ) then you may have a 'dead' IF section. Whilst the IFT windings just be intact ( as MW/LW is working ) they could be seriously misaligned to the point where there's no IF output at all - maybe even a broken/missing slug. Can you inject 10.7 mHz into the IF strip to check ??
Andy |
24th Jun 2020, 5:04 pm | #27 |
After much tinkering and fettling I have somehow managed to get a perfect FM response from this set. The thing is I'm not exactly sure how I managed it? I swapped out various valves with the other donor set, changed a few more resistors and double checked all the Hunts caps were all replaced (they were) and checked as many soldered joints as I could to see if any were suspect. Now with a cheap FM antenna plugged into the aerial connections I get great FM coverage all across the band. MW is still ok and I imagine would be better with a decent aerial attached but for now the set has been bench tested over the last few weeks and sounds great. I still have a light intermittent pop/ticking sound on FM particularly when warmed up after an hour or more so I guess my tinkering is not complete but I'm getting closer to having a really good set. Magic eye is bright as you like and opens and closes well in tune with the sound signal. The other donor set I converted into a bluetooth speaker and having repaired the cracked and torn speakers with several light PVA coatings (which worked really well!) it also now sounds great. I picked up a bakelite VHF61 for a tenner recently and with my experience gained restoring the VHF64 it was a quick restorations and that too now operates well. I think I've caught the restoration/renovation bug now!!
