Old 21st Apr 2020, 10:03 am   #181
real0real
Default Re: Kolster Brandes 666 Valve radio restoration.
Hi
Have ordered a new C1 Capicitor i believe is a major one and could caused serious damage if this had failed ,
Would fit new larger resistors that look more in sittue with the set closer matching the large ones fitted if i new which be best ones to order plus any other capicitors if you think could possibily be required , would be most gratefull if anyone could help with which i am likely to need (complie a list) and possibly link to order all in one go would be most be helpfull , or could buy individualy on ebay ones that would likely be needed
clive
real0real is offline
Old 21st Apr 2020, 12:14 pm   #182
davebms
hello al,l I think post #154 gives you the list of caps ?, resistors I use
2 watt carbon film as they are quite big
dave
davebms is offline
Old 21st Apr 2020, 12:42 pm   #183
Station X
Station X's Avatar
Let me try. The = symbol denotes equivalent to.
0.0001uF = 0.1nF = 100pF
0.0002uF = 0.00022uF = 0.22nF = 220pF
0.0005uF = 0.00047uF = 0.47nF = 470pF
0.001uF = 1nF
0.006uF = 0.0068uF = 6.8nF
0.01uF = 10nF
0.02uF = 0.022uF = 22nF
0.05uF = 0.047uF = 47nF
0.5uF = 0.47uF = 470nF
8uF =10uF
25uF = 22uF
Voltage to be greater than or equal to that of the existing component.
Most resistor values are the same, but you may have to replace 250k with 270k and 2M with 2.2M.
Power rating to be greater than or equal to that of the existing component.
Graham. Forum Moderator
Station X is online now
Old 21st Apr 2020, 1:22 pm   #184
real0real
Hi Graham
Thank you for list
Will try emailing few suppliers today , are these all resistors or capicitors aswell ? ,as not familiar with type numbers , plus wondering would a supplier understand from the list of items needed will mention prefere larger types if have for vintage radio
Clive
Old 21st Apr 2020, 1:48 pm   #185
real0real
Have had another look for R29 where suppose to be , but not appears to be fitted
have attached picture
Old 21st Apr 2020, 2:01 pm   #186
real0real
Have recently purchased original service manual for KB 666 arrived in post today , the info same as the down-loadable version but still nice thing to have with radio , picture attached
Old 21st Apr 2020, 10:00 pm   #187
Station X
Station X's Avatar
Originally Posted by real0real View Post
Hi Graham
Thank you for list
Clive
Capacitors are given the designation 'C' in circuit diagrams and have values expressed in uF (microfarads), nF (nanofarads) or pF (picofards). You'll also have to specify the working voltage.
Resistors are given the designation 'R' in circuit diagrams and have values expressed in ohms, kilohms (kohms) or Megaohms (Mohms). You'll also have to specify the power rating in Watts.
Old 22nd Apr 2020, 10:33 am   #188
real0real
Hi Graham
Thank you for explaining a little , interesting and learning a bit , have been searching on the internet for suppliers emailed one already awaiting reply , will do some more browsing today for suppliers
Old 22nd Apr 2020, 10:45 am   #189
poppydog
RS Components are pretty good and very quick but in the last few months prices on some components have doubled. They sell mostly good quality branded components.
https://uk.rs-online.com/web/general...E&gclsrc=aw.ds
poppydog is offline
Old 22nd Apr 2020, 11:03 am   #190
real0real
Hi Graham
maybe a stupid question but , Just one thought with Wattage of compiled list that are required , i can see most of capicitors/resistors are rated at 1/2 watt in workshop manual ,but just a couple are rated at different wattage are any in this list compilled need to be different to 1/2 watt rating, as not sure 100% sure which of capicitors required in list of be ordered and would i need to specify a different wattage when ordering
Old 22nd Apr 2020, 11:06 am   #191
real0real
poppydog ,
Thanks for link of to RS , Will look at
Old 22nd Apr 2020, 11:28 am   #192
crackle
I would recommend only replace the capacitors at this stage.
Then you can try the radio safely, it may even work at that stage. Take more voltage measurements, determine which resistors need replacing to improve the performance of the radio and buy them in one batch. I have found that only a few resistors need changing in these KB radios, whereas most if not all of the capacitors will need to be changed.
Regarding Voltage and Wattage specifications. Capacitors have the value, in micro farads (uF) and the working voltage, in volts. (V). They also come in a variety of different styles, you cant go too far wrong if you buy "axial" types, e.g. a wire at each end like the original capacitors.
Whereas resistors have their value, measured in ohms, and the power they can take measured in watts (W). When it comes to vintage radios most people go for the 2 watt types as they are bigger and look more in place in the radio. Sometimes you may need a larger wattage. But dont replace any resistors until you have unsoldered one end and checked the actual measured value.
Mike
crackle is offline
Old 22nd Apr 2020, 11:31 am   #193
Station X
Station X's Avatar
Hi Graham
We're going round in circles here.
All capacitors will need to be replaced ultimately. Capacitors don't have a wattage rating. They have a voltage rating.
The resistors I suggested changing were:-
R1 100k 1/2 Watt.
R7 250k 1/2 Watt. If 250k not available use 270k.
R12 25k 1 Watt.
R23 2M 1/2 watt. If 2M not available use 2.2M
R24 500k 1/2 watt. If 500k not available use 470k. ***
*** I'm suspicious of the fact you measured this as 40k. It's wired across L4 secondary so should measure around 57 ohms when in circuit.
At the risk of complicating things you could use 2 watt resistors as replacements. They'll do the job just as well and being physically larger will look better in a set of this age.
Old 22nd Apr 2020, 1:33 pm   #194
real0real
Will email the list to couple of suppliers and hopefully will understand the requirements and where applicable 2 watt for the resistors , will explain for restoration of a vintage radio and hopefully have ordered asap
Old 22nd Apr 2020, 1:38 pm   #195
HamishBoxer
HamishBoxer's Avatar
I would never use less than 2 Watt reses as others have stated and they certainly look better.
HamishBoxer is offline
Old 22nd Apr 2020, 11:42 pm   #196
Silicon
Resistors have voltage ratings but some sellers don't mention it.
The smaller ones are only rated for 250V.
The 2W resistors are often 350V or even 500V.
The 2W resistors generally have longer and thicker leadout wires which can make installation easier.
Silicon is offline
Old 25th Apr 2020, 6:18 pm   #197
real0real
Still at moment trying to find capacitors , plus Resistors at 2 watt, lot of resistors at 1/2 watt but smaller in size
Have cleaned chassis up a little plus put some heat shrink aound valve tube as was little loose in its socket base housing
ID:	203955   Click image for larger version
Old 25th Apr 2020, 6:31 pm   #198
ms660
ms660's Avatar
Have you tried here?:
https://www.cricklewoodelectronics.com/
Lawrence.
ms660 is offline
Old 25th Apr 2020, 6:54 pm   #199
real0real
Hi Lawrence , thanks for sugesting will look at ,
Have found 1 so far on ebay , R1 100k at 2watt , and ordered
If anyone sees any in list required be very gratefull if could post link to so can buy
Old 25th Apr 2020, 10:05 pm   #200
Station X
Station X's Avatar
On eBay:-
https://www.ebay.co.uk/itm/Axial-Pol...re3WIIxs9s6IwQ
Rather then buy from multiple eBay sellers you might do better to get everything from a big supplier like RS.
Capacitors for example:-
https://uk.rs-online.com/web/c/passi...led%22:true%7D
There's also Just Radios in Canada:-
https://justradios.com/
https://www.justradios.com/cart.html
