Old 7th Nov 2019, 10:45 am   #21
Heatercathodeshort
Heatercathodeshort's Avatar
Default Re: Here's a challenge for you guys...
Thanks DAZ. I handled quite a few of the GEC models but not a single Thorn! Surprising considering the massive number of Thorn receivers around London and the South East. The various UK regions had different customer tastes. Some receivers were very rare say in the North but hardly seen in London, and the reverse of course. John.
Heatercathodeshort is offline
Old 7th Nov 2019, 1:06 pm   #22
Restoration73
Restoration73's Avatar
Also Ultra 6629, 900 chassis, with L, T, H on the turret, with channels 6 & 7 absent !
23" twin panel tube.
Restoration73 is offline
Old 7th Nov 2019, 1:12 pm   #23
Pilot Mariner
Pilot Mariner's Avatar
Location: Burntwood, Staffordshire, UK or Kabaty in Warsaw Poland.
I'm still trying to find the model number of my childhood TV. I know it was a Baird from the early 60s which had a vertical channel selector scale with motorised clunking tuner. It had VHF radio built in, stations of which were selected by the vertical channel selector. I think it was rented from Radio Rentals.
Pilot Mariner is offline
Old 7th Nov 2019, 4:21 pm   #24
volte-face
No Longer a Member
You can see a nice picture of an Ultra 6627 - 19" Dual Standard with VHF radio (900 chassis) - HERE
Note the three position system switch - Radio | 405 | 625
The VHF Turret Tuner then has positions for Light, Home and Third
There was definitely a rental version of this set. I had a near identical set as a teenager, but re-branded for "Robinson Rentals". It had the same control panel layout but, if I recall correctly, it was a burgundy colour, with the CRT being protected by flat plate glass. I obtained it from the small TV shop repair I was was working in at the time in lieu of some wages. The boss was shrewd enough to know that he would have difficulty selling such a dated looking set secondhand at that time (1976) as everybody wanted push through and squared off tubes by then, so offered it to me. It served me well as a bedroom set though.
As far as I recall, when the system switch was in the radio position the HT was cut off from the Line and Frame output stages and the heater chain was also altered to place a wire wound resistor in circuit to compensate for the unwanted valve heaters (so not much actual power saving in radio mode!). The LOPT was of the previous 850's pitch overwind type with EY86 rectifier, rather than the later "jellypot" tripler combination - no flywheel sync board, of course.
Unfortunately, I've never managed to find an example to transport me back to my youth. Another case of, "if only I had kept it"!
A bit more info on the Ultra 6627 can be found in this older thread - HERE
volte-face is offline
Old 23rd Aug 2020, 7:35 pm   #25
brianbelfast
Default Here's a challenge for you guys...Version 2
Hi all. Wow, I can't believe it's almost a year since I posted the thread trying to ID an old telly my parents had. Some of you may remember it had an in-built radio as well as being dual standard. I was going to try to draw, from memory, what it looked like. Well I can go one better than that. I've stumbled across an old family photo which has the TV clearly visible. That's my uncle Alex Henderson with his girlfriend Ann Bell. Christmas drinks by the look of it. Happy times. Now what is that TV ? I can still remember how good it was. It produced an absolutely outstanding 625 line UHF picture. Rock solid.
brianbelfast is offline
