27th Jul 2020, 10:43 pm | #1 |
Analogue Comark thermocouple thermometers
I have come by a couple of analogue K type thermocouple Comark thermometers. I remember using such things them when I was a research student at Uni in the 70s.
The ones I have are models 1602 and 1604. If anyone has any service information on either or both of these I'd love a copy. The 1602 which reads from 0-100 on the meter scale, is dead on accurate. It reads from -120 to +1000C in several ranges. The 1604, which has a scale of 0-10 and reads from -60 to +500C, is way off. On ice it reads +5C. There are pots inside, presumably for calibration. I may be able to deduce what they do (base and slope?) by noting their current settings then adjusting them to see what they do. Any information would be appreciated. Charles |
27th Jul 2020, 11:11 pm | #2 |
Re: Analogue Comark thermocouple thermometers
Not sure if this is any help - circuit of a Model 1905.
I've owned mine for some time, and it did fail at one stage due to a particular resistor going, which was a "known issue" B
28th Jul 2020, 12:38 am | #3 |
Thanks for the pdf Bazz4CQJ, but sadly there is not much similarity with the innards of either thermometer. They are quite different from eachother too, the 1602 and the 1604.
Like all Comark kit of that era, they are well made and have lovely big meters. I use digital stuff all the time, but I have a very soft spot for moving coil based test equipment. When ever I can, I use either my AVO 8 MK II or one of my Taylor multimeters |
28th Jul 2020, 1:24 am | #4 |
The 1604 has one large internal pot, sealed with a dash of white paint. It looks like its a multi-turn pot, so I put an additional mark on it to identify the original setting. The white paint on it instantly flew off when I turned the pot a bit. With the thermocouple on ice in a dewar, I observed the effect on the reading when I adjusted the pot. Sure enough, the needle could easily be set to zero, corresponding to the known temperature in melting ice.
Once I remove the probe from the ice and let it dry off and warm up, the reading is much more reasonable. next I'll check it at 100C in boiling water. If its reasonable I'll be well satisfied. If not, I presume one of the other sealed pots (there are two) are the "slope". K-type thermocouples are more or less linear from 0 upwards. Careful adjusting of that and re-adjusting to 0 on ice should give me a reasonable result. I suspect the second "slope" pot may be for values below the internal reference (less then 0). |
28th Jul 2020, 8:23 am | #5 |
possibly CJC calibration
Kevin |
28th Jul 2020, 3:28 pm | #6 |
Yes most probably it adjusts the cold junction reference voltage. I'll do some more tests today, also take some photos of it.
The case of the 1604 was damaged, cracked in one corner. I repaired that using a piece of angled aluminum bonded in with epoxy resin. Both the aluminum and the plastic case were roughened before bonding. The case has a handle at the top that pulls out and the plastic bushes that it slides in were missing. I made a couple of bushes out of brass on my lathe and just bonded them in with epoxy. The meter had some dirt on the scale, so I took it apart to clean it. In doing that I found one of the supports had fractured off so that too had to be bonded back. Its looking quite nice now. |
5th Aug 2020, 3:38 pm | #7 |
Comark 1600 series Analogue thermocouple thermometers.
A most useful range. I use one for checking transistor case temperatures and soldering iron, and lend it to my wife for jam and marmelade making. Late 1960's to early 1970's. Made up of modules based upon an extraordinarily versatile chopper based millivolt amplifier. Then a whole range of modules for diffrent temperature ranges and thermocouple materials. This makes the manuals very scrappy and you will have to read and select what applies for your model. The 1604 model has ranges covering -60C to 170C in 10degree spans. The other models cover 100degree spans and full range. I use my 1601 covering 100degree the most useful, as my other model 1642 fussy to use. I attach a catalogue details showing what the various model variants are. Not the best copy, but it was coloured paper and made thirty years ago. Also details of the thermocouples. And finally the manuals giving circuit and board layouts for the DC chopper amplifier, the DC power supply and the calibration resistors to obtain the ranges. And the various add-on for temperature trips and AC mains power. supply etc. The calibration procedures are also given, though the descriptions of purpose of the adjustment is a bit confusing as it varies with each variant of the basic modules. The cold couple thermistor is the STC G14, glass bead, 2mW/C, with 10k ohm at 20C. Not over critical (compared with the STC A14 glass tube used in so many AF oscillators of that period). It seems suitable alternatives are available from Vishay / Philips, GE (USA) and Murata. The thermocouples usually seen are K type, Ni-Cr/Ni-Al, which are pretty linear with temperature. The meter is a very nice taught band 500ua with a fine 5" scale. I have never seen any information upon these meters elsewhere, so I hope these attachments will be helpful, even though they do not cover all the variants. They will need studying to find what applies to your variant. I also posted details of the Comark 1905 insulation tester back in Aug 2009. Bazz4CQJ has posted it again several times more recently in response to enquiries from others, thus saving me the task of re-posting it. I had someone selling a rare manual which I had provided at a handsome price without acknowledgement. Not quite the spirit of this Forum, so now I water mark everything. I see KevinFScott was asking about the chopper amplifier in 2011, and never came back when I offered the information then. If he is still around, this posting will provide the circuits. This the same amplifier was used in the Comark 1305 multimeter and probably the FET Tester, both raised in on this Forum in the past. wme_bill |
14th Aug 2020, 5:40 pm | #8 |
Thanks WME_bill very much for the service and calibration information for the Comark thermocouple meters.
I've taken a photo of each of the ones I have, a 1604 and a 1602. Charles |
16th Aug 2020, 9:56 am | #9 |
Thanks also for including the other models in the range. If anyone has a manual for the digital Comark types 1300 - 1301 I would be very grateful for a scan of the specs and cal procedure sections.
I looked out both my instruments to check if they have the correct thermocouple type: looking at thermocouple.info I was alarmed at first, until I realised that there are 6 different codes in use according to country. The workplace had standardised on K-type, which were always brown/blue
- Julian It's good here |
