22nd Oct 2014, 7:14 pm | #1 |
Black gettering on valve? Is this a sign of a problem?
One of the EF86's in the stereo amplifier I am repairing has a gettering that is very black. Forgive the dumb question but should I be worried? I haven't got a valve tester and so I've no means of knowing what state the valve is in. I am used to gettering on valves leaving a shiny silvered effect on the inside of the glass envelope. Is a black deposit inside the head of the valve a sign that there is a problem?
Should I be looking for someone with a valve tester to check it out? Should I throw another few pounds at the amplifier and replace the EF86's? |
22nd Oct 2014, 7:25 pm | #2 |
Re: Black gettering on valve? Is this a sign of a problem?
Black is good, milky bad. Try it anyway, it will either not work at all, glow blue, or work well.
22nd Oct 2014, 7:40 pm | #3 |
I believe that sometimes a black deposit can mean that a valve has led a hot, hard life, though may still be functional.
22nd Oct 2014, 8:00 pm | #4 |
If the valve is soft then the getter will be white or white at the edges and a blue glow when working. At the end of the day if it works normally then use it till it does pack up as there's nothing to lose!
22nd Oct 2014, 8:10 pm | #5 |
Dont know about black for a hard life but PL81,s used to have brown stains when old.
Pretty sure that EF86 will be fine as they dont normally run very hot anyway.
22nd Oct 2014, 9:18 pm | #6 |
The circuit in is a perfect tester for the valve. Just check the voltages on its electrodes against the service data for the amp, or against valve data at a pinch.
22nd Oct 2014, 10:36 pm | #7 |
The valve should be fine if the getter is either silver or black, the time to consider a new one is when the getter goes transparent, the valve can still work in this state.
When the getter turns white, there is air inside the valve, powering it up in this state is likely to result in internal fireworks. |
23rd Oct 2014, 11:34 am | #8 |
If the valve in question is a Mullard, or any of the Philips owned European manufacturers then a dark black getter is quite normal and can be seen on many of their NOS valves. It seems that they sometimes adopted a different getter material to the normal ones used by the other companies.
It is also true that a black getter can result from a long hot life for the valve but this only tends to occur in power valves (rectifiers and output devices) rather than the rather low power EF86. |
23rd Oct 2014, 11:55 am | #9 |
I think I read somewhere that a black getter can occur when the material deposits as fine particles instead of a continuous coat. Just as good, possibly better as it might have a greater surface area.
23rd Oct 2014, 12:41 pm | #10 |
Thanks one and all. I will try it and see in a few days time when the final batch of components arrive for me to complete the rebuild.
