Old 5th Jun 2018, 3:57 pm   #1
boombox
Default So I've bought a pair of red BT intercom phones...
"A rare pair of fab retro 60's intercom phones. These came from my step dads old pub and one used to be behind the bar and the other one was in their upstairs function room. They had a super long cable to join them but it [the cable] was no longer usable after being taken out, it had been painted over for years etc so i threw it out. One gets plugged in as normal and the other has a battery. They just need a long lead to join them. I saw them being used years ago and requested them when they left the pub. I'm not very electrical so i never got a lead but i used to have the non battery one plugged in at home. I think the bells were silenced in it though as i had more than one retro phone plugged in at the same time and one ringer was enough! My brother in law did it and i can't remember exactly what he did."
They've not arrived yet but just wondering if there's any literature anywhere I could begin reading on these to hopefully get them pressed into service again. Bells and all would be ideal!
Also if anyone knows how they worked - i.e. was it like a hotline where you lifted one handset and the other end rang or...?
Thanks!
boombox is offline
Old 5th Jun 2018, 4:10 pm   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: So I've bought a pair of red BT intercom phones...
These look like normal, GPO 706 type phones which someone's rigged up to run on a battery to make their own intercom.
The "intercom" labelling is not original, albeit nicely done.
We can't really tell you much more until we see inside them, but they look really smart, don't they? I think the red 706s are a really appealing design.
Nick.
Nickthedentist is offline
Old 5th Jun 2018, 4:11 pm   #3
Dave Moll
Dave Moll's Avatar
If they're simply standard 706s wired to operate as an intercom, a picture of the wiring when they arrive should be a good start.
Dave Moll is offline
Old 5th Jun 2018, 4:22 pm   #4
Nickthedentist
Yes. I hope the conversion, if that's what it is, hasn't involved removing any crucial parts.
Old 5th Jun 2018, 5:27 pm   #5
Pellseinydd
I beg to differ - see attached phones which appear to be a pair of similar phones. Produced by the BT Factory at Cwmcarn in South Wales in the early 1980's.
The 'Intercom' label looks to be the same style. If you look under the handset on the L/Hand red 706, you can see the same black 'addition' as in the R/H photo below.
Ian
ID:	164111   Click image for larger version
ID:	164112   Click image for larger version
ID:	164113   Click image for larger version
ID:	164114   Click image for larger version
Pellseinydd is offline
Old 5th Jun 2018, 9:19 pm   #6
boombox
These look very familiar!
Still unclear to me how they worked. I'll take some pics of their innards when they arrive.
boombox is offline
Old 5th Jun 2018, 9:22 pm   #7
OscarFoxtrot
OscarFoxtrot's Avatar
Very nice.
I've got one in grey but I incomplete.
It's a 4-wire connection, and turning the dial in one causes the dial-off-normal springs to make a circuit sounding the DC buzzer in the other.
Hopefully they haven't been further modified so just joining the line cords matching colour to colour will get it working.
Mine has a jack on the back to connect an external 9v power supply. Sadly mine is disconnected from the PCB so I don't know where the battery connects in the circuit.
The bellmotor in mine is missing. And no internal diagram.
OscarFoxtrot is offline
Old 5th Jun 2018, 9:36 pm   #8
OscarFoxtrot
A grey set that sold in April:
Picture attached.
ID:	164122   Click image for larger version
Old 5th Jun 2018, 9:58 pm   #9
OscarFoxtrot
They only buzz as intercoms, because they work off a 9 volt DC battery - no AC ringing supply to ring a magneto bell.
I'm not sure what's in the rather sticky sleeved part, it may be some extra resistor(s).
Name:	706 intercom.jpg
Old 6th Jun 2018, 2:30 pm   #10
boombox
Picture attached.
Wonderful pic - is the original slightly higher res? Struggling to read some of the text. Thank you for posting it!
boombox is offline
Old 11th Jun 2018, 1:50 pm   #11
boombox
Pics attached!
Couple more to follow.
Looks like the buzzers have been pinched.
ID:	164398   Click image for larger version
ID:	164399   Click image for larger version
ID:	164400   Click image for larger version
ID:	164401   Click image for larger version
boombox is offline
Old 11th Jun 2018, 1:51 pm   #12
boombox
The last couple of pics as promised
ID:	164404   Click image for larger version
boombox is offline
Old 11th Jun 2018, 5:23 pm   #13
OscarFoxtrot
The buzzers are easily replaceable with 9 volt buzzers.
Unfortunately without a wiring diagram we'll have to work it out from first principles.
Old 11th Jun 2018, 8:49 pm   #14
boombox
I'm wondering at this stage if it might be better to use a VoIP adaptor configured for ringdown/intercom working - a) because I would prefer to use the mechanical bells to indicate an incoming call rather than a buzzer and b) because I'd rather not have to use the dial to initiate a call.
boombox is offline
Old 11th Jun 2018, 10:17 pm   #15
OscarFoxtrot
These days, the VoIP adaptor configured as a ringdown circuit is probably the cheapest and easiest way of doing it. If you want to build your own
https://www.vintage-radio.net/forum/...9&d=1485945957
Not completely sure, but I think you have a missing regulator board in your 706. It plugged into the ABCDE contacts.
Refer
http://www.samhallas.co.uk/repositor.../0000/N806.pdf
which suggests that the phone should work de-regulated if BCD are connected together.
You also appear to be missing your bellmotors. Bell unmounted 59B ?
Old 12th Jun 2018, 4:55 am   #16
TonyDuell
Given that 'normal' telephones 706 (and 746, which to J-random-public look much the same) are relatively common and intercom-modified ones are not, I would suggest buying a normal 706 if you want one to use on a VOIP adapter with a normal bell and restoring this pair as intercom sets (or selling them on).
TonyDuell is offline
Old 12th Jun 2018, 9:15 am   #17
boombox
I'm beginning to think you're right, Tony, if I'm missing all sorts of other bits. Shall I post them for sale on the forum?
boombox is offline
