13th May 2023, 10:08 am | #1 |
Revox B77 take up on play/rec
I was servicing a Revox B77 for someone yesterday. It needed mechanical work to the brakes and a good clean, but the main problem was in play or record.
When play is selected on these machines, the take up spool receives full power for around ½ second to help in accelerating the tape after the pinch roller has contacted the capstan. This wasn't happening. This pulse is achieved through C7. I had a spare transport board, so I tried that, but the results were the same. C7 doesn't have a value next to it, but a 10uF was fitted on both my spare board and the original board I checked all the wiring through the reel size switch but everything checked out okay. I then replaced C7 first with a 22uF which improved matters but didn't fully cure it, and then with a 100uF which did. Does anyone know why this should have occurred in the first place? |
13th May 2023, 3:13 pm | #2 |
Re: Revox B77 take up on play/rec
No idea Michael. How did the old cap measure?
13th May 2023, 6:40 pm | #3 |
I don't know the cct. in question at all, but maybe it is meant to be 100uF?
You can make a good guess by using: t (time in SECONDS) = R (in Megaohms) times C (in uF). This is based on a voltage drop to 63%. If there is an associated resistor with the capacitor, then you may be able to make some sort of approximation.
"Behind every crowd, there's a silver Moonshine" |
13th May 2023, 7:12 pm | #4 | ||
Cheers |
13th May 2023, 7:15 pm | #5 |
It say's C7 is 10uF in the manual I'm looking at.
EDIT: Post crossed. Lawrence. |
13th May 2023, 9:43 pm | #6 |
I checked the reel size switch and the resistors are correct. This is the HS version.
14th May 2023, 2:18 pm | #7 |
Second thoughts -deleted.
30th May 2023, 9:01 pm | #8 |
C7 is +5V decoupling? Perhaps have a look at comps around and including Q16 which form the 5V reg. ??
Edit: seem to be s/n variations: . Q18 in another version: BD139 Last edited by John_BS; 30th May 2023 at 9:09 pm. |
30th May 2023, 9:46 pm | #9 |
Interesting. My B77 has the opposite problem - despite the pinch roller arm being nice and free, it tends to 'snatch' the tape!
Regards, Ben. |
