#1 |
Really strange 'timed' fault on this one :
After being left on for anything up to 2 hours, in quiescent state, the left channel starts to crackle moderately at first and then becomes louder which builds quickly into a loud 'crashing and banging' and much movement of the test speaker cone. Due to volume of said noise, it becomes necessary to hit the off switch fairly quickly! After a few seconds at 'off', if switched on again the noise returns at full tilt ! If the amp is left to cool, all is well again and a gentle hiss (from the disc channel ) shows the amp is still working, no smoke or blown fuses. Clearly a thermal problem, (which takes an age to manifest itself ) I played a heatshrink gun around the output transistors , LS coupling cap, PSU caps and the LH driver board. Not a peep ! Amp is still a happy chappy ... Measuring with the ESR meter , the LS coupling electrolytic on the LH channel all seems fine. Ditto the electrolytics on the driver board ( albeit measured when 'cool' ) I then swapped the driver boards between LH and RH and left the amp idling again. Sure enough, after a couple of hours the problem repeats but this time it's on the RH channel. This I would take to indicate the problem is on the LH driver board ( now in the RH channel slot ) It would also seem to absolve the O/P transistors and the LS coupling cap on the LH channel. On the driver board There is an ancient looking preset which for good measure I will replace, as well as the 4 electrolytics and 2 'tropical fish' caps for starters. Of course it could be anything on the board !!( no dry joints or broken tracks in evidence ) so any suggestions most welcome. Andy |
#2 |
The 'tropical fish' caps generally don't give problems. I would be more suspicious of the ancient electrolytics breaking down. There's an outside chance it might be one of the driver transistors....I had a BC143 fail but that went short and was an easy trace. There is also the possibility of a resistor becoming noisy but that would probably show up as a rustling noise that varies in volume.
The pot sets up the quiescent current which you adjust by putting a meter in series with the collector of the 'top' output transistor....think it's 30mA.
On Spike Milligan's headstone......I told you I was ill... |
#3 |
I had this is a Delta 70, think a Lockfit transistor was responsible. I found it with freezer spray.
#4 | |
![]() Quote:
Ahh yes....good thinking! If it's got BC147/8/9 lockfits in place of BC107/8/9 then they could well be the source of the trouble. Lockfits are almost 'replace on sight' if there are intermittent faults present.
#5 |
"Almost"....?
#6 |
Here’s a pic of what’s on the driver board - no lockfits as far as I can tell.
First stop will be to change the 220R bias preset, and the four electrolytics Following the comment on the tropical fish caps I will leave those for now A. |
#7 |
Have you tried tapping the skeleton pre-set pot?
Alan G6PUB, BVWS |
#8 |
Andy, have you removed any heatsinks from the metal cased transistors?
These work at a high-ish voltage and power dissipation in the Leak 70. The driver transistors are fitted with heatsinks but sometimes fail. The Leak 30 Plus works at a lower voltage and may not need them. |
#9 |
Those resistors fitted with end caps can go intermittent. Worth tapping around them.
Don't think the 30 has the heatsinks
#10 | |
![]() Quote:
A. |
#11 |
