26th Nov 2017, 2:38 pm | #221 | |
Re: Radio Caroline to return on Medium Wave.
Hold down the Alarm/Man button while using the Tune up or down button, 9khz steps on MW. User manual and service manual on the Roberts Yahoo group, user manual in the photos section. https://groups.yahoo.com/neo/groups/...ums/1306887289
Frank |
26th Nov 2017, 3:01 pm | #222 | |
Stu |
26th Nov 2017, 3:03 pm | #223 |
Thanks for that Stu.
Lawrence. |
26th Nov 2017, 3:24 pm | #224 |
Hi
It's all a bit disjointed at the moment it seems to me, split into three services. Their 'main' internet stream, second 'flashback' stream, and then the monthly-ish 'Caroline North' programme, which is the one that appears on 1368, and is the one currently simulcast for testing 648. These broadcasts are the only ones that currently originate from the ship. I rather suspect some 'consolidation' will take place when their licenced service begins in earnest. It is after all a 'community' licence for the Suffolk area. This could end up in a 4th version of Caroline I suppose the most important bit is they are there. Their own website is probably the best source of info Being able to listen on two frequencies last night in the car, albeit with some deep fading was very reminiscent of the old days If you fancy a look at the big ampliphase transmitter on board, it's possible to visit the ship and well worth the effort! Regards Stu |
26th Nov 2017, 4:10 pm | #225 |
I'm sitting here eagerly waiting for sunset at some 16:15 when hopefully Caroline will appear again.
Is there a simple way that I can tell the skip distance for a given wavelength? The formulae I am looking at seems to need the brain of Einstein to work it out. https://tinyurl.com/y8glqys3 I am some 300 miles from the Manx 1368 transmitter and 185 miles from Mersea Island yet last night the Manx signal was far stronger than Mersea. I understand that the power outputs used are fairly similar. |
26th Nov 2017, 4:11 pm | #226 |
Picked it up here last night on a Sangean ATS-803 portable using the internal antenna about 2330 but it was fading quite a bit. Every few seconds I could quite clearly make out what was being said though. I must try an external antenna or maybe a loop to see if I can get a better signal. When Manx radio is broadcasting I can get a reasonable signal here "up north".
Alan. |
26th Nov 2017, 4:22 pm | #227 | |
Usually they will claim reception on a certain number of days in a particular month. Also too complicated for me but that’s the beauty of “DX”, never know what may turn up.
Frank |
26th Nov 2017, 4:36 pm | #228 |
Good signal strength and S/N ratio all day on 648 kHz here in Cambridge - strength comparable with BBC Radio Essex. Excellent on both Pye 39 J/H and PCR2 receivers. Big reduction in local QRM by using my Welbrook loop aerial. Can't find anything on 1368 KHz though. Will try again after dark for the sky wave.
Martin
BVWS Member |
26th Nov 2017, 4:39 pm | #229 |
The foreigners are just starting up at 15:40 so here's hoping
26th Nov 2017, 4:52 pm | #230 |
“ Simple” formula for Skip distance.
The problem is how do most of us find those values to put into the equation at any single point in time. The formula is simple if you have those values.
Frank |
26th Nov 2017, 5:07 pm | #231 |
26th Nov 2017, 5:50 pm | #232 |
Got it just fine here [648] on my Eddystone 840A and 60-odd-foot longwire.
26th Nov 2017, 6:02 pm | #233 | |
I'm most intrigued that the distant 1368 kHz signal from IoM arrives here all of 25 seconds before the closer 648 kHz signal from the East Coast. I guess that the internet must be involved in the transmission path of the latter? Or perhaps both? I wonder how long the signals dwell in cyberspace. Martin
BVWS Member |
26th Nov 2017, 7:55 pm | #234 |
Heard them testing on Saturday on 648 in paralel with the Manx radio 1368 relay the signal on 648 came in reasonable well when it faded in unfortunately the signal wasn't audible on a normal radio with ferrite rod areal but was ok on my wire into my FT817
26th Nov 2017, 9:31 pm | #235 |
Good old skywave! 1368 booming in on the Sony portable with the little loop and easily listenable with just the ferrite rod. Easily as good a signal as I used to get from RNI 1kHz lower.
648 OTOH now very poor - there but not listenable - weak with fast ionospheric disturbance. I don't listen to a lot of pop radio now - though I do get various stations inflicted on me at places where I work - and I have enjoyed today's programming with songs I haven't heard in years, nay decades, in some cases. A great change from the homogenised output of most stations these days. |
26th Nov 2017, 9:50 pm | #236 |
Just managed to pick Caroline up on 648 for a shortwhile before it faded out , that was with a RP30 not really listenable but i will keep trying.
26th Nov 2017, 9:54 pm | #237 |
Reception perfectly listenable here although weak (S2) at 2pm this afternoon on the Grundig portable. At 8.30pm this evening, however, it's audible but barely of entertainment quality. Rapid fading at ~4Hz and even my Bush VHF81 is struggling to make sense of it!
26th Nov 2017, 9:58 pm | #238 |
Not a peep on either frequency today
Looking up Radio Wiltshire I found that is also on 1368 but very weak and last night I was tuning slightly low for best reception definitely off RW center frequency and I could just tune in each station seperately on a DAC90A so Caroline (or the Beeb) might just be using an offset. I haven't got any test gear here so can't say for sure which one it is if I am correct. Last edited by Boom; 26th Nov 2017 at 10:03 pm. |
26th Nov 2017, 10:19 pm | #239 |
I took a 1958 Inscol to the coast, at Withernsea & the improvement in signal was remarkable. What had been barely audible had come up in strength to the point I could wander with the radio in my hand listening to Caroline.
There's a (outside) chance somebody else was doing exactly the same thing with this radio fifty-odd years ago. I dare say that if you lived in the Yorkshire Dales you might get the 1368 Khz Manx relay, but not in Holderness. |
26th Nov 2017, 11:08 pm | #240 |
The fading is very slow. At times you can listen fairly easily, but at it's worst the two stations that are in the background make it hard to tell what is on. Only because I already knew the tune did I realise they were playing Purple Haze by Jimi Hendrix.
This ground-wave/sky-wave interaction and thus fading. Is it always closely related to local sunrise & sunset? Just wondering, because it does seen that the competing stuff starts to intrude about sunset. |
