14th Dec 2019, 7:49 pm | #1 |
Question on "rails"
I see many accounts of fault checking on, for example, an amplifier and the "rails" are often measured. What are the rails? What is their function? I am of course a complete beginner, so any help with the vocabulary would be most welcome.
Many thanks from Bill. |
14th Dec 2019, 8:00 pm | #2 |
Re: Question on "rails"
The power rails, or supply lines.
On British valve circuit diagrams the positive HT (High Tension) rail generally runs horizontally across the top of the page and the negative HT line across the bottom of the page. Equipment needing more than one voltage may have several supply rails. +24V, 0V and -24V by way of example.
14th Dec 2019, 8:07 pm | #3 |
In valve circuitry, the "rails" - are often known as:
A+ or A rail - the supply to the valve heaters. B+ or B rail - the high-voltage HT supply to the valve anodes. In some instances you may come across a C-supply, which is a separate negative-bias supply generally fed to the output valve(s). |
14th Dec 2019, 8:15 pm | #4 |
Cheers thanks for clearing that up guys
Bill |
14th Dec 2019, 8:49 pm | #5 | |
Andy |
