Old 25th Nov 2019, 12:16 pm   #21
ms660
ms660's Avatar
Default Re: Dansette Conquest Auto
-ve on the rectifier is AC in, +ve is +DC out.
EDIT: Post crossed.
Lawrence.
ms660 is offline
Old 25th Nov 2019, 12:52 pm   #22
DonaldStott
DonaldStott's Avatar
Originally Posted by Station X View Post
You need to measure the DC HT voltage across the reservoir and smoothing capacitors.
I'm measuring 255V, 162V and 10V respectively on the reservoir and smoothing capacitors.
Looks like I need to unbolt the mains transformer to get at the valve pins and the main board?
BVWS Member
DonaldStott is offline
Old 25th Nov 2019, 12:55 pm   #23
Station X
Station X's Avatar
I'd say those readings were OK. The first is the reservoir cap voltage, the second the smoothing cap voltage and the third will be the voltage on the cathode of the output valve, which will be the same as the grid bias.
Graham. Forum Moderator
Station X is offline
Old 25th Nov 2019, 1:12 pm   #24
ms660
ms660's Avatar
Just to note, the component values look similar to those used in the Monarch, which suggests that it's a Conquest Auto MKII, eg: it's not the D/T amplifier that's listed for the Conquest Auto in the R&TV servicing books.
The Conquest Auto MKII schematic can be found in the instruction book here:
https://elektrotanya.com/dansette_pr...wnload.html#dl
Lawrence.
ms660 is offline
Old 25th Nov 2019, 1:27 pm   #25
Station X
Station X's Avatar
Yup. That circuit even quotes voltages.
There's a fourth electrolytic cap which should have 1 Volt DC across it.
Old 25th Nov 2019, 1:54 pm   #26
crackle
Is that a mustard cap on the circuit board? If it is then it won't need to be changed.
Mike
crackle is offline
Old 25th Nov 2019, 3:09 pm   #27
DonaldStott
Thanks Lawrence for that information and the link.
I've downloaded the schematic - I know it's free but a better scan would really have helped as I'm struggling to read some of the values.
Normally I would agree Mike but it is the 0.01μF audio coupling capacitor!
At this stage though I'm minded not to replace anything although ...
I may be measuring this incorrectly but across that blue electrolytic I'm only getting 0.18V DC??
BVWS Member
Old 25th Nov 2019, 3:21 pm   #28
ms660
ms660's Avatar
The values shown in the Monarch schematic are the same and clearer, I posted the link to the MKII schematic to show that there was indeed a MKII version....whicheverways I'll do a component ID list and I'll post it up in a bit.
Lawrence.
ms660 is offline
Old 25th Nov 2019, 3:29 pm   #29
Station X
Station X's Avatar
Check the 2.2k cathode resistor and 220k anode resistor of the triode section.
Old 25th Nov 2019, 3:31 pm   #30
DonaldStott
I'm measuring between the +ve end of the blue electrolytic and ground/chassis?
BVWS Member
Old 25th Nov 2019, 3:36 pm   #31
Station X
Station X's Avatar
That's the correct way of measuring. "Across" amounts to the same thing.
Old 25th Nov 2019, 3:45 pm   #32
DonaldStott
The 2.2k cathode resistor is measuring 2.31kΩ
The 220k anode resistor is measuring 1.85MΩ - WOW!
BVWS Member
Old 25th Nov 2019, 3:47 pm   #33
ms660
ms660's Avatar
Dansette Conquest Auto MKII (also Monarch) component values as per the manufactures schematic:
VR1...1 meg
VR2...1 meg
VR3...250k
R1...330k
R2...56k
R3...22K
R4...56 ohms
R5...2.2k
R6...220k
R7...680 ohms
R8...680k
R9...56k
R10...18k
R11...390 ohms
C1...200pF
C2...200pF
C3...64uF
C4...0.01uF
C5...32uF
C6...25uF
C7...32uF
Any errors then guilty as charged.
Lawrence.
ms660 is offline
Old 25th Nov 2019, 3:51 pm   #34
Station X
Station X's Avatar
High value resistors have a habit of drifting even higher. This high value resistor could well be the cause of the low voltage across the blue electrolytic cap.
Old 25th Nov 2019, 6:27 pm   #35
DonaldStott
Thanks Lawrence, much appreciated.
BVWS Member
Old 26th Nov 2019, 12:01 pm   #36
DonaldStott
I have five resistors that are measuring more than 20% over their stated value and will be replaced.
I never know what type of resistor to choose for restoration projects and which is right for this type of project - metal film, metal oxide or carbon film? I do favour 2W resistors due to their size which don't look too out of place in vintage equipment?
And what about that mustard cap - what's the consensus given that it is the audio coupling capacitor! For peace of mind I'd be inclined to replace it?
BVWS Member
Old 26th Nov 2019, 5:39 pm   #37
Station X
Station X's Avatar
I use 2W flameproof resistors for valve gear, but everyone has their own preferences.
Mullard Mustard capacitors have a very good reputation for reliability. I've never found a faulty one. If you're determined to change it though, nothing I can say will stop you. Make sure there's no positive voltage on the control grid of the ECL82's pentode section.
Old 26th Nov 2019, 6:20 pm   #38
DonaldStott
Thanks Graham, you just have ... subject to the test below of course!
Will do.
BVWS Member
Old 26th Nov 2019, 10:01 pm   #39
DonaldStott
I'm 95% of the way through updating the text on the manufactures schematic to make things clearer - thanks to Lawrence for the figures in Post #33 above.
Having a bit of difficulty with some of the voltage figures although so far I have ascertained 56V just above V.R.2., 10V just above R5 and 10V just above R11.
Can't really make out the main voltage coming out of T.2, the voltage and amps to the left of the FC.116 and the voltage to the left of R10 - don't want to guess for obvious reasons.
I'll Post the updated schematic as a PDF once it is complete.
BVWS Member
Old 26th Nov 2019, 10:12 pm   #40
Station X
Station X's Avatar
It's 1.0V above R5.
