Old 20th Dec 2009, 10:34 pm   #101
Default Re: Newb Stumped on a Derwent
OK. There is a 0.1uF capacitor from the anode of the previous stage (AF Amp) to the control grid of the 42.
It's called that capacitor because it always gives trouble and goes leaky. The reason for this is that it leads a hard life with the full HT across it.
Disconnect it at pin 4 of the 42, reconnect the 510K from chassis to pin 4, power up and check the 42 voltages again. If they're OK THAT capacitor is faulty.
Station X is offline
Old 20th Dec 2009, 10:35 pm   #102
Ed_Dinning
Hi Old TT, PM me if you are still stuck and the snow has subsided. You can then arrange to bring it over some time and I'll go through it with you.
Best regards, Ed
Ed_Dinning is offline
Old 20th Dec 2009, 10:37 pm   #103
PJL
Graham, the 75 cathode seems to be connected to the 42 cathode? I wonder if that's correct? Anyhow, the 50uF is goint to be important as any AC on the cathode would play havoc with detection and AGC.
PJL is offline
Old 20th Dec 2009, 10:37 pm   #104
oldticktock
Originally Posted by Station X View Post
OK. There is a 0.1uF capacitor form the anode of the previous stage (AF Amp) to the control grid of the 42.
Disconect it at pin 4 of the 42, power up and check the 42 voltages again. If they're OK THAT capacitor is faulty.
surely it won't be faulty its a new modern yellow one rated at 750v I only put that in replacing an old waxy one a couple of days ago.
oldticktock is offline
Old 20th Dec 2009, 10:43 pm   #105
MichaelR
MichaelR's Avatar
If it helps you find a service sheet from maybe some of the more knowlegeable of the 30's sets, the radio you have looks as though it could have been by Central Equipment Ltd.
The unit they released in 1935 was the Derwent "international five" , different looking model and a table top but the same aeroplane dial.
Just a suggestion to save your backside anymore damage
Mike
MichaelR is offline
Old 20th Dec 2009, 10:44 pm   #106
Steve_P
Steve_P's Avatar
Unlikely. If you have a signal source to hand, put it in at Pin 4 (Control Grid) of the 42.
Steve P.
Steve_P is offline
Old 20th Dec 2009, 10:45 pm   #107
oldticktock
Best regards, Ed
Cheers Ed, If I don't get anywhere I will take you up on that, as you say if the snow goes. We got it bad out in the sticks, Im about 3 miles from Tow Law and we always get hit
This investigation and assistance is fascinating a real education and baptism of fire if not also confusing, a real attack on the senses.
Old 20th Dec 2009, 10:46 pm   #108
The two cathodes are probably connected as the two valves share a common cathode resistor and bypass capacitor. This is however an unusual arrangement.
I'm faced with the problem of trying to explain why connecting a 510K grid leak resistor pulls down all the voltages. This can only happen if there's a voltage on pin 4 and the grid leak is pulling it down to chassis. I can't see how this can happen unless that capacitor is faulty. Try disconnecting it as I suggested and recheck the voltages on the 42.
We still have the problem of the cathode voltage of the 42 being rather high and the 42 apparently drawing excess anode and or screen current. It's possible there may be other faults. Disconecting THAT capacitor will effectively isolate the output stage and may help to track down the fault
Old 20th Dec 2009, 10:48 pm   #109
oldticktock
Steve P.
Tried that, hope i was doing it right. Used the lead you talked me through making last night. Earth end on chassis and other end on pin.Nothing doing
Old 20th Dec 2009, 10:57 pm   #110
stitch1
stitch1's Avatar
Sorry I can't help but this an interesting and active thread so don't give up I want to know how its fixed, but if you wait for thaw in Tow Low we'll be here until July
stitch1 is offline
Old 20th Dec 2009, 10:58 pm   #111
oldticktock
Interesting disconnecting the 0.1 cap i found buried inside a heat shrink another 510k which would have been wired to chassis except we had cut that end. But as we had snipped the chassis end previously it will not help us but does show a component error was there.
I'm worried now i'm not getting DC readings at all AC on one side of the RECT 80S on DC on the other has the 80S now given up or what .................... I think I'm going to call this a day soon and start with a fresh head.
Old 20th Dec 2009, 11:05 pm   #112
electrogram
could another 510k be the grid leak for the 75
electrogram is online now
Old 20th Dec 2009, 11:12 pm   #113
electrogram
maybe not, a prvious post said grid cap is connected to vol pot
Old 20th Dec 2009, 11:24 pm   #114
oldticktock
Ok i'm shutting down for the night, somethings not right no DC at all now, not even on the rect, or i've stuffed my avo on dc.
head fried ass kicked need to go and mope
Old 20th Dec 2009, 11:54 pm   #115
oldticktock
Ok I lied, im hooked I canna give it up i'm official a radio geek bed who needs it.
Ok the AVO seems to hate DC now what I did I don't know. Went to my test equip cupboard and pulled out my mains powered Cossor instrument reads AC DC-DC+ and OHMs
42 readings
pin 1 cannot get a reading
pin 2 250
pin 3 270
pin 4 0
pin 5 23
pin 6 cannot get a reading
anyone know why the avo 7 gave uo on dc? still reads ac and ohms
Old 20th Dec 2009, 11:59 pm   #116
Steve_P
Steve_P's Avatar
Still high is the Cathode voltage. The valve should be lit or there wouldn't be a cathode voltage.
With the set OFF, remove the 42 and measure to deck - Pin 4 and Pin 5. Post the readings.
Steve P.
Steve_P is offline
Old 21st Dec 2009, 12:01 am   #117
42 readings
pin 2 250
pin 3 270
pin 4 0
pin 5 23
Looks good. What voltage do you measure between pins 4 and 5?
I assume the 50uF is back in its correct position ie negative end to chassis and positive end to pin 5 (cathode) of both valves?
Where did the unearthed end of the other 510K go to?
Old 21st Dec 2009, 12:09 am   #118
oldticktock
yup 50uf back as stated
not sure what you mean" between" pins 4 & 5
the additional 510k would have been to chassis right at the start of this thread but mid way we cut that end so it would have been negated
Old 21st Dec 2009, 12:09 am   #119
Steve P.
The 75 is a triode and two diodes in the same envelope. They have a common cathode. Therefore the cathode current of all four valves (42 and 75) will flow through the cathode resistor. I'm wondering if it should be a lower value than 500ohms? It might be a body, tip spot type of 450 ohms.
Old 21st Dec 2009, 12:12 am   #120
One lead of the meter to pin 4 and the other to pin 5.
Yes, but where did the end which is not connected to chassis go to? I'm trying to establish what its function was/is
