Reply
Old 5th Apr 2012, 9:23 pm   #821
AC/HL
AC/HL's Avatar
Default Re: AVO Multimeter survey
Whilst finally getting near the end of reorganising my workshop, I have unearthed the box containing the AVOs.
An 8 MK3 I've had for years, but now has an o/c meter - 8xxxx (no letter) 768
An 8 with low amps readings and very low voltage readings - 3xxxx C 1254
An 8 which is accurate, but has terminal damage - 1xxxx C 453
The 1953 one has the bakelite cover with the prod storage, but by 1954 it has the aluminium one. Also the 54 one has terminals without sockets and needs the leads with the spade ends.
AC/HL is offline   Reply With Quote
Old 14th Apr 2012, 11:41 am   #822
brunel
brunel's Avatar
UNIVERSAL AVOMETER
MODEL 8X Mk. III (PANCLIMATIC)
MODEL 8 No. 56368 . 367
brunel is offline   Reply With Quote
Old 14th Apr 2012, 2:21 pm   #823
Andrewausfa
Andrewausfa's Avatar
Another AVO turned up a few days ago. AVO 8 Mk V I think from 1979, no labels just the instruction plate on the rear dated 6/79, in leather case.
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline   Reply With Quote
Old 14th Apr 2012, 3:42 pm   #824
phasedout
Hi another, Avo Universal Mk7---No 1830-A-148, i presume this is a 1948 model.....regards...Alan.
phasedout is offline   Reply With Quote
Old 14th Apr 2012, 6:30 pm   #825
pmmunro
Alan,
Your latest Avometer is from January 1948; this is around the time when the design changed from horseshoe to block magnet.
If you know which you have would you please let us know?
PMM.
pmmunro is offline   Reply With Quote
Old 14th Apr 2012, 9:13 pm   #826
nutteronthebus
nutteronthebus's Avatar
Hi, just dug out my old AVO from the Garage AVO 8 MKIII Sn 5707-1164.
I tried to clean it with foam cleaner and it stated to remove the paint from the rear panel luckily only a small patch.
ID:	65107   Click image for larger version
Any tool can be used as a hammer but a screwdriver makes the best chisel
nutteronthebus is offline   Reply With Quote
Old 14th Apr 2012, 9:35 pm   #827
Paul Adams
Hi Dave, (nutteronthebus)
Nice leather case you have there, I wonder where you had that from
Anyway another serial: 1487-B-548 (Model 40)
Paul.
Paul Adams is offline   Reply With Quote
Old 14th Apr 2012, 10:03 pm   #828
Phil G4SPZ
Phil G4SPZ's Avatar
I need a couple more leather cases, but they seem to command prices as high or higher than the meters themselves!
Phil
Phil G4SPZ is offline   Reply With Quote
Old 15th Apr 2012, 11:35 am   #829
Paul Adams
Phil,
I have sent you a PM.
Paul.
Old 21st Apr 2012, 10:02 am   #830
M0XNA Neil
I have just acquired my first AVO 9SX. Serial number 8673-15-765. Can anyone provide a copy of the handbook/manual please?
Neil
An engineer makes for a penny what a scientist makes for a pound!
M0XNA Neil is offline   Reply With Quote
Old 21st Apr 2012, 12:46 pm   #831
Refugee
Refugee's Avatar
One of the two i have has a black case that is made of something like the stuff that suit cases are made of not real leather.
The markings on it say:-
Test set n.o1 MK4
and shows the nato part number:-
6625-99-728-5965
Refugee is offline   Reply With Quote
Old 21st Apr 2012, 1:53 pm   #832
M0XNA Neil
I have some of those Eveready cases with my other AVOs. The TS1 Mk4 seems to be the AVO 8 MK6 as I have a NATO stamped one with the same case you have. My AVO 9SX came with a tan leather case.
Neil.
Old 21st Apr 2012, 2:16 pm   #833
stitch1
stitch1's Avatar
Another 2 for the list, picked up today for £8
AVO Model 7 MKII - 42178-A-653
AVO Model 8 MKV - 5270-049
ID:	65504   Click image for larger version
stitch1 is offline   Reply With Quote
Old 25th Apr 2012, 4:37 pm   #834
Testgear John
Smile Re: AVO Multimeter survey
Avo 8 Mk2, 3808 C 763D. Now restored with a model 8 Mk4 movement and scale.
John
Testgear John is offline   Reply With Quote
Old 25th Apr 2012, 8:16 pm   #835
Phil G4SPZ
Phil G4SPZ's Avatar
It looks more like a Mark 1 to me, with screw-down terminals. Mark IIs usually have "Mk II" in the button below the "Model 7" legend, too, but I may be mistaken. Sometimes cases get swopped by previous owners, so the instruction plate doesn't match the meter, and I have some Model 8s in this state.
But you got an original-type battery with it, you lucky chap! Quite a bargain for the pair, though, so well done.
Phil
Old 25th Apr 2012, 8:28 pm   #836
stitch1
stitch1's Avatar
No you are right Phil, also on the MKII the markings on the panel are engraved and white.
Yes the original battery but it was flat
It was just a guy selling junk at a market, he wanted £5 for the 7 and I couldn't walk away without the other so offered £8 for the two which he took.
Old 25th Apr 2012, 9:01 pm   #837
phasedout
Hi pmmunro,
It has the horseshoe shape magnet.
Regards,
Alan.
Old 25th Apr 2012, 10:57 pm   #838
pmmunro
Alan,
Thanks for the magnet in formation; it all adds to the information the survey provides.
PMM
Old 28th Apr 2012, 3:55 pm   #839
M0XNA Neil
My AVO 9SX (Serial number 8673-15-765) doesn't have a scale number (1 to 12), so I assume it was hand calibrated to the movement. Does anyone know when they started using 'best match' scales or are all the AVO9s calibrated to their movement?
Neil
Old 1st May 2012, 6:35 pm   #840
Nymrod121
Nymrod121's Avatar
AVO 8 Mk III here, but cannot find a serial number :-(
The scale plate says " MODEL 8. No. [nothing visible] " so, unless someone can suggest somewhere else for me to look?
Other threads on this forum very encouraging re. alternative to 15V battery pack.
Nymrod121 is offline   Reply With Quote
Reply
