Reply
Old 29th Apr 2023, 8:31 pm   #3181
Superscope
Default Re: AVO Multimeter survey
Hi Phil,
Drop me a PM with your address and I'll put a few in the post for you.
Ian
Superscope is offline   Reply With Quote
Old 29th Apr 2023, 8:36 pm   #3182
Phil G4SPZ
Phil G4SPZ's Avatar
Very kind of you, Ian, many thanks! PM sent.
Phil
“The place where optimism most flourishes is the lunatic asylum” - Henry Havelock Ellis
Phil G4SPZ is offline   Reply With Quote
Old 29th Apr 2023, 9:10 pm   #3183
The Philpott
The Philpott's Avatar
Well done Ian -A bit of a black art then! With my Model D i plonked the Nd on the actual concentrator. I'll locate the photo. It was so close to the moving parts that i felt it should be glued. It's time that i checked whether accuracy and linearity are still good.
Dave
The Philpott is offline   Reply With Quote
Old 1st May 2023, 12:34 pm   #3184
The Philpott
Viz:-
I think this is close to the methodology recommended by a Japanese gentleman, whose name long since escapes me. I suppose that the philosophy is that getting your booster onto the concentrator makes best use of the extra flux.
Note that the magnetic shunt is blocked from moving in this meter, but it turned out that it was not an issue- calibration was achieved by shuffling the magnet around and re-checking.
Dave
ID:	277594   Click image for larger version
ID:	277595   Click image for larger version
Old 1st May 2023, 1:50 pm   #3185
The Philpott
Just re-checked the accuracy of the Model D in Post No.3184 on DC volts.
Inputs at intervals from 7% to 83% of FSD, most readings slightly high but by no more than 0.66% of FSD on the given range.
Worst results as regards %age of INPUT is 10v reads as 10.2v on the 30v scale, and 7.5v reads as 7.6v on the 15v scale.
These last two result correspond to around 33% and 50% of full scale, so might indicate a bit of non-linearity at these points. I was pleased enough with this though! This was in a meter which on arrival was reading short by 6 to 7% of input values.
Dave
Old 1st May 2023, 2:36 pm   #3186
Phil G4SPZ
Phil G4SPZ's Avatar
That’s not bad at all, Dave. Considering you’ve got a single Neodymium magnet fixed on one side of the concentrator, some non-linearity of the flux within the air gap is almost to be expected.
If you wanted to be really pedantic, you could draw up a calibration graph. Mind you, how many of us use our Avos in circumstances where a 1% reading error is crucial? In my case I still use a Model 7 for vintage radio work, and readings are either “pretty close”, which is okay, or “miles out” - and you’ve found a fault.
Phil
Old 2nd May 2023, 2:40 pm   #3187
The Philpott
Taken in conjunction with Ian's pictures it does give a good idea of roughly how much boost is required for a given loss of flux. Small powerful magnets close to the action are definitely the way to go. I've seen it done with large, traditional, less powerful magnets glued at various points around the horseshoe, which looks tedious.
Model D-
Input as %age of FSD..........Error as %age of FSD
7...........................................+0.02
33.........................................+0.66
50.........................................+0.66
66.........................................+0.33
83.........................................+0.066
Old 2nd May 2023, 2:43 pm   #3188
Phil G4SPZ
Phil G4SPZ's Avatar
Interesting, Dave. Slightly stronger flux mid-scale. Still bloomin’ good for a WWII-era meter though!
Phil
Old 5th May 2023, 9:32 am   #3189
Superscope
I can't test the performance of the Movement I worked on yet, as it's just
too sticky to be useful.
But now that the Flux has been restored, it means it's at least now worth striping
down and cleaning it up.
Once it's all back together, I will test the Linearity with respect to the original
Scaleplate and post the results.
Ian
Old 6th May 2023, 1:25 pm   #3190
Phil G4SPZ
Phil G4SPZ's Avatar
Thanks for the magnets, Ian! They arrived this morning. I’ve popped a note on the “Thanks Thread” too. Now to find a free hour to play…!
Phil
Old 8th May 2023, 1:27 pm   #3191
Superscope
Originally Posted by Phil G4SPZ View Post
It would only have made sense for Avo to do this if they could use all the standard multipliers and shunts from the Type D, so they must have adapted the 1mA movement to read 2.5mA FSD whilst exhibiting the correct overall resistance for the Type D, by inserting specially-made series and shunt resistances.
Phil,
I haven't confirmed this on the Meter yet, as I've not had a lot of time to look at it, but looking at the Schematics for the Model 7 and the Type D, it looks like the
conversion is probably quite straightforward.
The Movement resistance for the Type D is 20 Ohms @ 2.5mA FSD, and for the Model 7 the Movement resistance is 50 Ohms @ 1 mA FSD.
Conveniently, 50 Ohms is 2.5x the resistance of 20 Ohms, so all other things being equal in the Meter circuits there will be 2.5x less current available for the 1mA Movement, which
of course is 1 mA. Bingo! Job done.
So, the only component changes other than the Movement itself, would be the Series and Shunt resistances required for the different K1 and K2 sensitivities.
Unless I am missing something.
I will confirm this for sure when I get a chance to inspect the Components, but this would make the most sense.
I suspect, that the Model 7 Front Panel was probably deliberate in order to highlight a 1mA Movement being fitted.
I guess they ran short of 2.5mA Movements, as these were unique (as far as I know) to the Type D.
Excellent, glad they arrived , and didn't as you said "get stuck in the post" , well the Ferrous
parts of the Postal system that is
Ian
Old 5th Jun 2023, 11:07 pm   #3192
ScottBouch
ScottBouch's Avatar
1)
I have a "Universal AvoMeter" Model 8 Mk. II
No. 139309-*-462
* The letter is either a "G" or "O" as it's been partially scratched.
It came form Rugby College (as was), thoroughly student abused over the decades, I don't think any of the current shunts are still intact!
2)
I also have a much later Model 8 Mk. V, serial No on a sticker on the side, and also in battery compartment:
GC No. 0042954
8V
(Also rescued from the old Rugby College, but survived student abuse).
This one also carries a sticker: Supplied by Universal Instruments, Leire, Leicestershire, dated: 31/01/1983
Coincidentally, I live just 10 minutes drive from the village of Leire!
Cheers, Scott.
www.scottbouch.com
ScottBouch is offline   Reply With Quote
Old 8th Jun 2023, 5:34 pm   #3193
Max Power
Afternoon All,
Hope this is the right place to ask; I picked-up a nice AVO8 locally, everything seems to work ok, battery compartment is nice and clean; however, the front of the meter is rather dull, and many of the white engraved markings are missing their paint (?)
Please can you AVO experts advise the best course of action for a) restoring the shine, and b) touching-up the range markings.
I've given it a gentle wipe with a slightly damp cloth, and surprisingly, it wasn't that dirty; the leather case it came with (although very tatty) has done its job well; it's just a bit dull.
Many thanks!
Max Power is offline   Reply With Quote
Old 8th Jun 2023, 6:22 pm   #3194
Phil G4SPZ
Phil G4SPZ's Avatar
Hi Max and welcome to Avo ownership!
This thread is probably the wrong place to ask. Yes, most Avo enthusiasts are here, but this thread is mainly a survey of what Avos survive. There are also likely to be several alternative suggestions and responses to the questions you ask, and there would probably be more space if you were to post a new thread in the Vintage Test Gear section.
I have restored many Avometers and have my own methods of cosmetic restoration - feel free to send me a PM and I’ll happily reply in greater detail.
Phil
Old 7th Jul 2023, 11:52 am   #3195
WaveyDipole
WaveyDipole's Avatar
This one may already be on the database as I obtained it from another member on here a few months ago and it has been sitting on the 'round-tuit' shelf. Its an AVO Model 7 MkII with a serial number of 77500-A-1058. It has some resemblance to the Model 40 MkII as it has the two PF sockets.
WaveyDipole is offline   Reply With Quote
Old 7th Jul 2023, 12:59 pm   #3196
The Philpott
The letter 'A' denotes a slight change in the circuitry (possibly inclusion of the PF facility?) The circuit diagram in my (Feb 1952) manual applies to meters with 'A' in the serial number.
I did notice that both of my early Model 7's are not good for measuring low DC current/s that are being pushed by low voltage/s. I also sussed that a break in the transformer windings disabled ALL AC ranges, not just AC current!
I think that the 7 at the start of the serial denotes Model 7, with it being instrument number 7500 from October 1958. Ian/Peter/Phil can confirm.
Dave
Old 8th Jul 2023, 10:50 am   #3197
Superscope
That's a New Number to the Survey. It hasn't been reported before.
In this particular case, the leading 7 doesn't actually mean "Model 7".
This Meter just happens to fall within the 5 Digit 70k Serial Number
range which covered early 1957 until early 1959.
The Leading 7 found on the original model 7's up until 1947 did actually signify
that the Model was a 7. The Format used at that time was:
7 (Date Code) - (Serial Number).
Regarding the "A" in the middle, it has been suggested that this might have meant
an Alnico Magnet Movement installed.
Although I have no proof of this, the "A" did appear in Serial Numbers for the first time
around late 1947 when the Horseshoe Magnet Movements were being phased out and
replaced by the Alnico 1mA Movements.
I did ask some time back if anybody with a 1947 Avo Model 7 could report what type of
Movement it had, in order to try and determine if it was the "A" or the Serial No Format change
(Both happened in 1947) that signified the change of Movement.
Sadly, there was no response.
At the same time, the Model 40's started to appear with "B" in the Serial Numbers,
so it is possible the "B" meant Alnico 3mA Movements but that is pure speculation
at this time.
Regarding the PF sockets, these seem to have appeared around 1951, although
that is always subject to change if earlier PF Meters turn up.
Ian
Old 8th Jul 2023, 5:11 pm   #3198
WaveyDipole
It doesn't have a horseshoe magnet. I don't see Alnico written on the dial or movement anywhere but hopefully someone will recognize it from the photos. The dial has a part number: 10945 -19.A which may be a clue. Not sure whether the .A is significant or not.
ID:	281037   Click image for larger version
Old 8th Jul 2023, 5:43 pm   #3199
Superscope
Your Meter won't have a Horseshoe Movement, it's far too late for that.
As mentioned, the Horseshoe Movements were phased out in 1947.
The Photo shows what I would expect for a 1958 Meter.
The "A" is consistent with a Meter of that age.
Alnico refers to the Magnetic Material type, not the Manufacturer.
You won't find Alnico printed or mentioned on the Movement, unless by
some chance the "A" is indeed a reference to the new Magnet type.
(New being relative to the Time of course).
I don't have the info handy at the moment, but as I remember, Avo later
moved onto Alcomax Magnets and they weren't painted.
I think PMM knows more about this area than I do.
Ian
Old 16th Jul 2023, 8:04 pm   #3200
Pamphonica
Pamphonica's Avatar
A dirty but restorable Model 2 (later model, fused, smooth panel) from the Reading McMichael rally today for £12!
Serial number 1627 (not already on register).
Can someone (Peter M?) tell me what the fuse should be? It's blown, and was rattling around inside. The circuit just shows it as "4 ohms"!
One broken connection inside, now mended. A cracked meter glass, but replaceable. Rheostat completely missing. And a lovely original "Size T" battery inside, not leaking, and still showing 1.3V! The meter coil shows continuity and the coil moves when my DMM ohms range is applied correctly. So all is promising for a restoration to cleanliness and function in due course!
all best
Jeremy
(who does not need yet another Model 2, but who's counting!)
Jeremy, G8MLK, BVWTVM Friend, VMARS, BVWS Secretary.
www.pamphonic.co.uk www.bttt.org.uk
Pamphonica is offline   Reply With Quote
Reply
