Old 20th May 2023, 8:09 am   #1
Smith3535
Smith3535's Avatar
Default Vintage Thermistors
The Thermistor shown below I removed from a transistorised Tripletone amplifier which I'm reverse engineering, i believe these were made by Mullard, if anyone can correct me. It measures 1.3k ohms across the pins and this seems to tally up against a resistor colour chart and he resistance also decreases in value after warming slightly so obviously a NTC, where as this one appears in good condition that is not the same to be said for the other channel where it has swollen and split.
Smith3535 is offline
Old 20th May 2023, 8:50 am   #2
Craig Sawyers
Craig Sawyers's Avatar
Default Re: Vintage Thermistors
The Mullard colour codes are a mysterious thing.
The zero power resistance is read from the bottom. So brown orange red - which is 1300 ohm at 25C and there is a +/-20% tolerance. It is a negative temperature coefficient - so resistance goes down as it gets hotter.
The temperature characteristic is described by its use as a temperature sensor, or in a self heating mode.
All this stuff, and how to interpret the data is in the Mullard Technical Handbook Book 3 (Components, materials and assemblies) part 1 (Capacitors, Resistors), 1980.
I have no idea where I downloaded all this stuff, but give me your email address by PM and I'll send it (it is 11MB of pdf)
Craig
Doomed for a certain term to walk the night
Craig Sawyers is offline
Old 20th May 2023, 9:38 am   #3
Ed_Dinning
Hi Craig, would it be worth asking one of the mods to put on the forum as a sticky?
Ed
Ed_Dinning is offline
Old 20th May 2023, 9:49 am   #4
Craig Sawyers
Found them! https://worldradiohistory.com/Archiv...Suppliers/MNO/
All the Mullard Technical Handbooks are there.
Craig
Old 20th May 2023, 10:35 am   #5
ms660
ms660's Avatar
The one in the photo looks like a VA1038:
http://www.electrojumble.org.uk/DATA...o%20VA1040.pdf
Lawrence.
ms660 is offline
Old 20th May 2023, 10:36 am   #6
radiomobile
Probably a Mullard VA1077 which is used for AC128/AC176 and AD161/AD162 complementary pairs
radiomobile is offline
Old 20th May 2023, 10:49 am   #7
Smith3535
Smith3535's Avatar
Thanks, hopefully then i should find a suitable replacement
Peter
Old 20th May 2023, 11:45 am   #8
dazzlevision
VA1077s are rectangular, not round.
It’s definitely a VA1038 (red, orange, brown stripes).
dazzlevision is offline
