#21 |
I use the rivet-type turret-tags along with a piece of non-copperclad FR4 to make up little panels as replacements for the bathtub capacitors. Mounted using the original bathtub-holes, and with 2mm brass tubular spacers to keep the back-sides of the turret-tags clear of the chassis, then yellow Vishay capacitors.
In times-past I went to the effort of etching a single-sided piece of FR4 to have little islands of copper round the turret-tags, and flood-soldering round the base of the turrets to secure them but that's just too much hassle; a small brass drift to 'peen' the back over works just as well and takes much less time.
"Mister Slater's Parrot says ~Hello!~" -The Bonzos. |
#22 |
And FR4 is much more stable and tougher than Paxolin.
#23 |
#24 | |
![]() Quote:
#25 |
Since there seem to be a number of people who know the AR88 well, I was wondering if anyone could help with these holes in the front panel near the phone socket. It's clear what goes in the hole marked phone but the other two are more of a mystery. They have been added very carefully as if a workshop modification, not like the typical amateur addition of a BFO or S-meter to some sets which I have seen.
On size grounds one looks like it could be a fuse holder (although the AR88 design philosophy seems to be "fuse holders are for wimps" or maybe the HT chokes double as fuses). Not sure about the other, a power lamp seems gratuitously unnecessary since the scales light up. |
#26 |
Toggle on/off switch because the ones integrated with the mode switch weren't considered reliable. There was also an added second phones jack so a second person could listen. No Idea whether that would have been a wandering supervisor, or a trainee.
The switch mod also allows the receIver to be powered up/down without crossing the 'trans' position which breaks the HT. This allows the HT stress to surge. Never use the 'trans' switch position. Have a look on the back panel, is there a 2-pole bakelite connector mounted sideways on the outside face? The switch and the added phone jack were common mods when rebuilt in the early 1950s The added socket on the back (along with a big REF coax antenna connector) was for conversion to R1556 specification. If you're really lucky, you may have a PVC wiring harness that was also sometimes fitted. David
#27 | |
![]() Quote:
When these receivers were returned to civilian duty, the RAF removed the front-panel mods, fitting steel machined bungs to blank the big holes. The smaller holes, and the coax-socket on the rear drop were left in place.
#28 | ||
![]() Quote:
The bus-bar and under-board wiring was invisible.
#29 |
Here is one of my AR88's done in my typical fashion of using terminal strips (US wording) and solder lugs for replacing the capacitors. No soldering to the chassis.
Tom W3TA |
#30 | |
![]() Quote:
https://www.vintage-radio.net/forum/...ad.php?t=50017
#31 |
This sounds very likely. On the back panel there are clear signs of a five hole drilling pattern which I'd assumed had been for an N connector or one of those shielded 4mm jack plugs which seem to appear on transceivers, but actually it is rather larger.
The on-off switch seems a good idea, but I think given the general leakiness of the capacitors in the set that using the hi-Z phone socket doesn't appeal to me...unless it was for an annoying supervisor. As a final (?) question, most of the obvious leaky caps have been found, but in the oscillator section there are some largish brown square "micamoulds" which ground the centre tap on the coils (up to 3900pf). These have an interesting colour code which I have failed to fathom despite the helpful arrows (it includes pink?) and don't look obviously distressed unlike some decoupler, but then they didn't have HT across them. Do they need replacement and if so what with - polystyrene? I'm not totally sure I follow the circuit design topology here, it's basically a shunt Colpitts but why the tapped inductor and the small cap directly across part of the coil? Part of me suspects that some of the capacitors are chosen for temperature compensation so random replacement "in case they leak" might be a bad plan for stability. |
#32 |
Sadly it looks like the wiring insulation is some kind of black natural rubber covered by woven cotton coated in shellac, which I can honestly say is a type of insulation I am too young to be familiar with! Except in the vicinity of the audio output stage where it seems things got hot, it has remained flexible and seems functional. The wiring round the 6V6 and the bias resistors has become brittle and will undoubtedly need replacing.
Last edited by Alan Bain; 1st Apr 2023 at 10:32 pm. Reason: Correct editing to quote |
#33 |
That's what they were all built with.
With the receiver out of its cabinet, you may find modification labels stuck to the outside faces of the gusset plates bracing the front panel to the chassis sides. Mine recorded a rebuild by REME and conversion to R1556 spec. It's a very early serial number with all-yellow tuning background, engraved front panel and an original S-meter. It's actually an AR88 without a suffix letter, from before the D/LF split. David
#34 |
It has come to my attention that the CR88 (single ended not the B) manual has a really useful wiring diagram (Fig 21) which describes the wiring loom of an almost identical receiver (although one has to imagine the bright reds and blues instead of the muted browns one sees today).
I've got a couple of scans of this (including from BAMA) but the scan resolution isn't great and some of the wire numbers are hard to read. Does anyone have a real manual that they could scan at a decent resolution? The corresponding scan of the RF section (Fig 22) is much crisper but still has some puzzles e.g. pin 1 of X1 is connected to something labelled as BASE rather than to the expected convenient ground tag on the chassis. |
#35 |
Thanks to the excellent PCB material suggestion here is a replacement bathtub alonside the original. The board has extra holes because to fit in certain locations it needs shortening. This PCB works in such variants for all but the 0.22uF bathtub next to the audio bias board.
#36 |
Thanks to all the helpful information and photographs here I was able working very slowly to reproduce the missing paxolin board see photo (with modern components since all the original ones either leaked or were the wrong values) and bring the set back to a state in which it could be aligned and is basically a radio.
That now leaves the giant mystery problem of the AF output stage. There seem to have been various design changes as even the valve choice 6K6 or 6V6 seems uncertain. Bias seems to be such as to suggest about 35mA DC bias current and given that the optimal ac load is around 7K, it would seem that a 30:1 output transformer with an 8 ohm speaker might do the trick. I found an old Wharfdale OP-3 which looks like the right ratio although the power handling is probably only 2-3W (and clearly I don't need the 600 ohm output). I couldn't find any specifications of the AR88D OP trans. |
