Old 14th Nov 2018, 10:56 am   #21
Niall76
Default Re: Dynatron Record Player.
Originally Posted by Nuvistor View Post
Will the nozzle of the spray fit in that slot?
Hi no unfortunately it won't, but it's completely sealed off with plastic anyway
Originally Posted by Station X View Post
Is it possible there are protective strips which move linearly with the knobs?
Hi there yes, protective strips underneath the knob, seems to be completely sealed off, no access to the slider pots at all
It is Graham but I seem remember they were strips of cloth with a slit in it. It is a while ago since the 1970’s so my memory could be wrong.
If it can’t be done through the control panel then there is a reasonable amount of dismantling to to do.
Wish it was strips of cloth with a slit Frank, but no it's plastic underneath and sealed off completely. Looks like I will probably have to try take it out of the cabinet then?
Niall76 is offline
Old 14th Nov 2018, 2:14 pm   #22
Niall76
Could I make a little hole in the plastic strip where the knob is so I can get the nozzle of my servisol 10 down and spray down into the slider pots?
Niall76 is offline
Old 14th Nov 2018, 2:43 pm   #23
Nuvistor
Nuvistor's Avatar
Reasonable question, not sure how much damage could be caused though.
Frank
Nuvistor is offline
Old 14th Nov 2018, 3:17 pm   #24
Niall76
Hi all just an update, I managed to wedge a little needle into the plastic strips making a tiny gap for the servisol to soak down into, did this with each of the slider knobs for volume etc left it for a bit, then turned on, and hey presto, no more crackles or hissing or drops in volume, and everything works as.it should, bass treble etc. Thanks again guys for all your info, didn't have a clue beforehand!
Niall76 is offline
Old 14th Nov 2018, 3:19 pm   #25
Station X
Station X's Avatar
Does the plastic strip still cover the track with the knob at the extreme limits of travel?
I'd say making a hole in the strip is fraught with danger. You may damage the track or slider and debris from the drilling or piercing operation with enter the pot and could cause problems.
Graham. Forum Moderator
Station X is online now
Old 14th Nov 2018, 3:20 pm   #26
Station X
Station X's Avatar
I was too late! Pleased to hear it's fixed.
Old 14th Nov 2018, 4:41 pm   #27
Nuvistor
Nuvistor's Avatar
Yes pleased you have it sorted.
Frank
Nuvistor is offline
Old 14th Nov 2018, 4:53 pm   #28
Niall76
Thank you Graham and Frank, much appreciated all the info, I've owned a couple of vintage players before but never had one before with a problem so it was good to get some advice on how to solve the problem as it sounded pretty dire before and I thought I bought a dud!
Niall76 is offline
