Old 24th Aug 2018, 10:18 pm   #1
big_trombone
Default Italian Rotary Telephone.
Hi
I'm looking for advice with rewiring an old phone to be usable again. the majority of guides I have found have been with different labelling etc. and as I am new to this (doing this as a project to learn more) I'm struggling. I'll include pictures but was wondering if anyone has any experience with this sort of thing?
Thanks in advance
ID:	168034   Click image for larger version
ID:	168035   Click image for larger version
ID:	168036   Click image for larger version
big_trombone is offline
Old 24th Aug 2018, 10:20 pm   #2
Station X
Station X's Avatar
Default Re: Italian Rotary Telephone.
Hello and welcome to the forums.
Do you have a make and model number for the phone? Is there a circuit diagram inside the case?
Graham. Forum Moderator
Station X is offline
Old 25th Aug 2018, 1:21 pm   #3
mike_newcomb
Hi Trombone,
as Graham advises, the make and full model number could help.
However, also same additionally applies for some decent external photos.
Regards - Mike
Contursi Terme, south of Salerno
mike_newcomb is offline
Old 25th Aug 2018, 4:16 pm   #4
AndiiT
AndiiT's Avatar
Hi and welcome to the forum, have you checked here? If you have had no sucess as a result are you able to identify the 'A' and 'B' wires of the line cord?, if so you may just be able to connect these to the corresponding exchange line (using a suitable connector of course) and the phone may work as a "two - wire" device.
A few more pictures with close ups of the terminal designations on the board may help us in assisting you further too.
Regards
Andrew
AndiiT is offline
Old 27th Aug 2018, 7:53 pm   #5
dagskarlsen
dagskarlsen's Avatar
Not easy to give an answer, but pictures of the other side of the circuit board may be whats needed, an explanation of where the cords ends are even a good idea.
My guess is the 4 white cords ar going to the rotary dial, The 4 wires one one side are to the transmitter (Microphone) and Receiver (T?)
a and b will normally be the line wires in a 2 wire system, this is commonly used in non UK systems.
dagskarlsen is offline
