4th Apr 2018, 3:41 pm | #1 |
RCA Victor SHC 888EX Orthophonic Queries
Collected from a forum member this a.m. and already playing away merrily in the background is this wonderful device. Anyone care to expand on the use of Orthophonic to describe the device and possibly what technical enhancement or perhaps product that is incorporated that allows such a definition?
I also note that the sound is particularly good yet there is no baffling whatsoever within the speaker enclosure. Furthermore, I also note that one of the tweeters is actually mounted at an angle which I have not come across before. Cant see any manufacturers names on the item? Finally, does anyone know if there is there a diagram available for the unit? Thanks Joe |
4th Apr 2018, 3:58 pm | #2 |
Re: RCA Victor SHC 888EX Orthophonic Queries
'Orthophonic' is simply a Victor tradename, which was used down the decades for a number of different models. It perhaps had some significance when first used, as that instrument was arguably the first attempt at domestic hi-fi.
I suspect that the angled tweeter is intended to aid sound dispersion, and very likely had its own marketing hype at the time! |
4th Apr 2018, 4:57 pm | #3 |
My dictionary suggests that "Ortho" comes from Greek and means "Straight" or "Level", so possibly it was meant to suggest a high quality level frequency response.
4th Apr 2018, 5:09 pm | #4 |
I didn't know the history of the word 'Orthophonic', but RCA Vinyl Records in the late 1950s/early 1960s' had the slogan 'New Orthophonic High Fidelity' printed on their labels. This was true of both 45s and LPs, and may even have been applied to 78s, though I don't have one handy to confirm this. RCA Victor record players/radiograms( or should I say 'Radio-Phonographs') were rare in this country. Is yours a U.S. import by any chance, Bookman?
4th Apr 2018, 5:20 pm | #5 |
I find Bookman's comments as to "no baffling" somewhat baffling. The photo appears to show a baffle arrangement for the tweeters and the 12" woofer. This unit will sound very warm due to a c. 70 c.p.s. peak in the lower register.
Edward. |
4th Apr 2018, 5:31 pm | #6 |
Exactly that. The original Orthophonic Victrola was designed to have a flat frequency response - as far as I'm aware, the first serious attempt at doing so.
4th Apr 2018, 6:55 pm | #7 | |
4th Apr 2018, 7:11 pm | #8 |
I found on utube some years ago a very interesting film about history of RCA, in which they talk about their various achievements, well worth a visit.
Cheers John |
4th Apr 2018, 7:13 pm | #9 | |
In this particular instance my use of "baffling" takes into consideration how these speakers have virtually nothing to the rear but still respond nicely to the bass control. The rear of the speakers do not have any of that speaker "wool" type material nor do they have solidly fixed backplates, they are the highly perforated rear back plates type that are normally found in radios? |
4th Apr 2018, 7:33 pm | #10 |
The small speakers look completely closed at the back
4th Apr 2018, 9:53 pm | #11 |
Nice item, but the cap in the crossover network?? looks similar to those nasty Plessey electrolytics.
5th Apr 2018, 9:15 am | #12 |
I think what Bookman is referring to is the lack of any wadding and/or a sealed enclosure - and he is calling that "Baffling" as distinct from what is normally known as a Baffle Board. Very few stereograms/radiograms used sealed or vented speaker compartments
Edward. |
5th Apr 2018, 9:32 am | #13 |
I think baffle usually means anything that alters the propagation of sound waves from front to back. With an open back its really a planar baffle thats been conviently folded into a box ! (a guess, I can only see the edge of the bass speaker)
It would be worth replacing the capasitor Graham identified, if it goes short the HF speakers will get fried. If its not a big value look for a film type or failing that a good reversable electrolytic. dc |
5th Apr 2018, 11:21 am | #14 |
RCA Victor started using “Orthophonic” around 1950, according to their film archives on utube.
As Edward said, and as I have understood, if you simply mount a speaker onto a board it is called a “baffle board “. What ever happened to RCA, they developed the first Stereo record and were world leaders in that field? Cheers John |
5th Apr 2018, 11:51 am | #15 | |
https://www.fastcompany.com/3060449/...icensing-deals
Frank |
5th Apr 2018, 1:12 pm | #16 | |
