Old 6th Dec 2017, 8:20 pm   #1
Nukeybrown
Default Unknown speaker
Just wondering if anyone has ever seen a speaker like this.
The 10” bass speaker in the bottom is a seas unit.
Looks like something was wrapped around the black sides , but what?
Anyone with any info on this ?
ID:	153512   Click image for larger version
ID:	153513   Click image for larger version
ID:	153514   Click image for larger version
ID:	153515   Click image for larger version
Nukeybrown is offline
Old 6th Dec 2017, 8:31 pm   #2
GrimJosef
Default Re: Unknown speaker
It looks like the subwoofer which went with the Rogers JR149s, I think. If the 10" driver is modern it may be a replacement.
Some details on the second row here http://www.mcmullon.com/icollect/hi_..._rogers/jr.htm and also at the bottom of the same page.
GJ
http://www.ampregen.com
GrimJosef is offline
Old 6th Dec 2017, 8:35 pm   #3
RojDW48
RojDW48's Avatar
Looks a bit like the KB omni from 1960 but that had a 6" driver mounted at the top
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan)
RojDW48 is offline
Old 6th Dec 2017, 8:38 pm   #4
Nukeybrown
You could be correct on the rogers as there is whats left of foam on the bottom.
Old 6th Dec 2017, 8:40 pm   #5
Nukeybrown
Heres the speaker as its being re foamed
ID:	153523   Click image for larger version
Old 6th Dec 2017, 8:46 pm   #6
Nukeybrown
The base looks different than Rogers
The speaker inside i think would be original due to its age
Rogers base has buttons etc on it. Mine only has the 2 speaker terminals and no internal crossover
Old 6th Dec 2017, 9:49 pm   #7
Trevor
i have got one of these its a sub-woofer and it came with a amplifier -x over i forget the name at the moment i have this in the garage and will look it out over the weekend to be fair it was quite good when used the very bottom end coming through
i used this with a pair of Wharfedale diamonds at the time
Trev
Trevor is online now
Old 6th Dec 2017, 9:51 pm   #8
Nukeybrown
Very interesting Trevor. Can't wait to hear.
Old 7th Dec 2017, 12:18 pm   #9
Edward Huggins
The Norweigen label might suggest SEAS as the local manufacturer.
Edward.
Edward Huggins is offline
Old 24th Dec 2017, 3:04 pm   #10
Trevor
I have been into the garage and found the X over sub bass amplifier it is a Jim Rogers device. I have not used this in about 10 years. When my sub woofer failed I fitted it with a Kef B139. Sounded OK.
Trev
Old 24th Dec 2017, 3:24 pm   #11
Nukeybrown
Is it the same as mine trevor?
Old 24th Dec 2017, 3:28 pm   #12
Nukeybrown
Does the base look the same?
Just finished renewing mine , covered with zero acoustic foam, not cheap @ £40 for 1.5metres.
ID:	154411   Click image for larger version
ID:	154412   Click image for larger version
Old 25th Dec 2017, 10:05 am   #13
nutteronthebus
nutteronthebus's Avatar
I use as my main speakers a set of JR150 with the stands , one of the best sounds I have heard ( now trying to get SWMBO to let them in to the house from my shed )
Dave
Any tool can be used as a hammer but a screwdriver makes the best chisel
nutteronthebus is offline
Old 25th Dec 2017, 10:30 am   #14
Trevor
yes its the same as your
trev
Old 25th Dec 2017, 11:30 am   #15
Nukeybrown
Thanks trev. At least now i know. Sounds really good now speaker been refoamed etc
Old 25th Dec 2017, 2:56 pm   #16
Diabolical Artificer
Diabolical Artificer's Avatar
That's definitely a Seas driver. There used to be datasheet's on the Seas website for most if not all of their vintage speakers.
Andy.
Old 25th Dec 2017, 4:20 pm   #17
Nukeybrown
Like this one
Old 26th Dec 2017, 5:05 pm   #18
Nukeybrown
Now up for sale.
