1st Mar 2024, 12:40 am | #61 |
Re: SC/MP programming chat.
This is one of those crude 'quickie programs' written for a one-off task, but might on occasion be handy:
Neither Kitbug nor KitbugPlus have a means of saving programs as binaries, so this process converts the output of the Kitbug or KitbugPlus "T" type command into a binary file, permitting NIBL or binary programs to be subsequently fast-loaded with no serial delays. Its crude, and probably only worthwhile for demo programs that you might load frequently but dont change, such as "CALENDAR.BAS". T2BIN is written using lccwin32 so runs in a Windows command window. With the typically required serial delays, a 'conventional' load of CALENDAR.BAS takes about 1 minute 44 seconds. CALENDAR.BIN, produced by T2BIN, takes only 8 seconds as the KitbugPlus fastloader needs no serial delays. Using NIBL-E as an example, to save a current NIBL program in page-2: Type PRINT TOP, convert this to hex and make a note of this value. enter LINK 0 to re-enter KitbugPlus Open a log file in Teraterm issue the Kitbug command T2000 which will scroll until interrupted. Watch the address column, when the TOP hex value you noted earlier is exceeded, issue a BREAK (ALT-B) and then close the log file. Depending where you started the log, and how quick your reactions are, the log file will need editing with Windows Notepad so it consists ONLY of the address & data values required, no header or spurious text at the start or end. Note there is a space after the data immediately before the CR/LF. It should look similar to this, each line ending in space, CR/LF: Code:
2000 08 2001 C4 2002 28 2003 33 2004 C4 2005 00 ...etc To create the BIN file, run T2BIN mylogfile.txt mybinfile.bin Thereafter, the saved program can be loaded using S2000 with no delays, followed by G1970 (NIBL-E warm start) Always save from the page start address to TOP of the required NIBL page. Page 2 starts at 2000h, page 6 at 6000h etc. PRINT TOP reports in decimal so you'll have to convert it As always the process is much quicker and easier to do than to describe... again its a bit laborious so only really worthwhile for demos that are frequently loaded but dont change, like 'calender.bas'. I havent tested this with a Linux-edited logfile, it probably wont work with Linux line endings. The file is at the bottom of the list: https://www.mccrash-racing.co.uk/phi...scmp.htm#links Cheers Phil_G |
20th Mar 2024, 1:46 am | #62 |
Another trivial NIBL demo to leave running at a show - looks best from a distance
https://www.mccrash-racing.co.uk/philg/scmp/INSIDE.BAS |
26th Apr 2024, 12:05 pm | #63 | |
I've just noticed that San Bergman's page about his SC/MP 'cross' for SBASM3 was last updated on 31st Dec 2023, which is more recently than the date we were discussing and trying to solve the matter of out-of range jumps not being caught by the assembler. (posts #23 - #51 approx). Of course he may just have been doing some end of year maintenance on the site.
I wonder if he changed anything in the discussion of the 'cross' which might shed light on why his version was allowing out of range jumps to pass. In particular, Quote:
26th Apr 2024, 2:23 pm | #64 |
I'm a frequent user G and with your amended cross file I have no problems whatsoever, so I will continue using yours, I've no inclination to 'upgrade' a perfect setup
26th Apr 2024, 2:36 pm | #65 |
OK, I'll continue to assume no news is good news, cheers.
26th Apr 2024, 7:25 pm | #66 |
26th Apr 2024, 9:10 pm | #67 |
I havent checked yet but I expect San has adopted your edit G.
26th Apr 2024, 10:23 pm | #68 | |
He doesn't seem to have changed the version in the main download, dated 31-12-2015, although the date stamp on the file in the download is 28/09/2021. If I remember correctly there was a newer version of San's cross which for some reason had never made it into the main 'distro'.
For the moment, I think we may be the guardians of the most up to date version of the CRSCMP.PY 'cross', although I would prefer that we weren't. Quote:
26th Apr 2024, 11:54 pm | #69 |
San's Github still has the old version too. I kept a copy of his original datestamped 19/07/2021, I just did a compare and its identical to his current github cross and also identical to the one on his website within current download file sbasm30307.zip
So, sadly, neither source of Sans "latest" (his words!) crscmp.py cross file has changed since we first noticed the problems. You're still the man, G |
