8th Apr 2006, 6:37 pm | #1 |
Fm multiplex (stereo) generator.
Does anyone have an fm multiplex generator in their workshop that they no longer use? I hope an item like this comes under the term 'vintage' - they would certainly be mostly obsolete now as all fm stereo decoders in radio sets are in IC form and require no or very little adjustment. I hasten to add that this would help me align discrete component valve decoders that I have in my collection of early stereo radios. If anyone has anything like this I would be most interested in hearing from you. Cheers, Sabaman. |
8th Apr 2006, 9:58 pm | #2 |
Re: Fm multiplex (stereo) generator wanted.
If you fancy building one, I have a copy of an article from TV magazine about three years ago. It gives near-broadcast quality signals at RF and baseband. I've used mine several times for aligning old decoders and repaired my own tuner a couple of years ago using the generator to trace a faulty transistor in the decoder.
Recently I've been using it to transmit a signal from the Sky box to the Hi Fi system so that I can listen to Classic Gold in stereo....much better than having the TV on with a fixed logo on the screen and better quality as well. The design uses easily available IC's and the two main boards are built into die-cast boxes. Most parts including the modulator should be available from Maplin. Probaly cost around £100 if you have to buy everything. Mine worked first time and needed minimal adjustment. You can test each part as you build it. OK it's not as good as a professional instrument but more than adequate for hobby work. Rich.
9th Apr 2006, 12:24 pm | #3 |
Richard, that design from TV magazine sounds interesting.
Unfortunately my subscription ended before it was published. I would be interested to see the article, if you could make it available. Thanks, Roy |
9th Apr 2006, 4:16 pm | #4 |
Hi All,
Thanks for your replies. I am in the same position as Roy in that I have only just restarted my subscription to 'Television' after a long lapse. Rich, if you have a copy of the article available I too would be interested - it sounds like a very useful project. Hi Paul, I had thought about using one of those mini-transmitters, but thought it may be easier to use a device suited to the job - I would also like to have a 'proper' one to add to my small collection of test gear. Best regards, Sabaman. |
9th Apr 2006, 10:37 pm | #5 |
Hi all.
Hmm!! It seems I've started something with this homebuild job! I have had a couple of PM's about it as well. I will have to find the article so please give me a few days to sort it. Perhaps Paul will allow me to post it on the forum as PDF's? It certainly works well considering a professional generator could cost £2000. Richard.
12th Apr 2006, 1:15 pm | #6 |
Well I've found the articles and as there seems to be no objection to posting the copies from TV mag, I've attached them here in two PDF's.
All I can add is that mine worked well first time. I would suggest that you use the specified transistors in the Master Oscillator because I tried subs and couldn't get it to oscillate. I think the ZTX transistors specified have a low input capacity. Also I couldn't guarantee that all specified specialist parts are still available. I'm sure suitable subs are around though. The OP275 IC's were available from RS. This was a very interesting item to build over about two weeks. Have fun ! Rich
12th Apr 2006, 3:20 pm | #7 |
There's nothing very critical in that parts list. BC109, BC549 or any ordinary transistor should work perfectly well in place of the ZTX450. The TL082 is a very ordinary dual opamp while the OPA275 is a more specialised audio opamp. Another TL082 would work (TL072 might be better) but might have slightly higher noise or distortion. Put it in a socket and it's easy to swap since virtually all dual opamps have the same 8 pin arrangement and there will be plenty of modern alternatives.
The silver mica cap can be replaced by a polystyrene part or NPO or COG ceramic. The OA91 can be replaced by any small schottky diode. I can't comment about the RF module. |
12th Apr 2006, 3:38 pm | #8 | |
I wondered about the RF module as well because a lot of the older modules seem to be discontinued. However again it's not a critical item and a simple 'bug' type RF oscillator could probably be made to work just as well. Rich.
12th Apr 2006, 3:42 pm | #9 | |
23rd Apr 2006, 7:03 pm | #10 |
Hi Igranic,
Thanks for the info. I've now bought a Radiometer SMG1 from eBay, but I'll keep a watch on the IG-37. I have seen a few on eBay previously but let them get away. I downloaded a manual for the IG-37 a few days ago. If it's still cheap I might place a bid. Cheers, Sabaman. |
24th Apr 2006, 8:10 pm | #11 | |
Edward |
24th Apr 2006, 10:48 pm | #12 |
The connectors shown in Brased's post were common on 50s/60s/70s American equipment, and can sometimes be found on cheap handheld dynamic microphones as the cable connector. One of my IG-37 units came fitted with these, but it was a simple job to remove them and replace with single-hole BNC connectors, which are a surprisingly good fit in the existing holes.
Purists may decry this modification, but the later model I also have, had BNCs supplied by Heathkit as part of the kit. |
25th Apr 2006, 5:19 pm | #13 |
Thanks Igranic
That does explain why I've also seen similar sockets on the US equivalent of the UK supplied RF-1U signal generator whereas my UK version has standard tv type coaxials. I had wondered about using BNC connectors as I find these are a convenient standard socket fitted on most of my other testgear. It seems that I can now fit these with an almost clear conscience. Edward |
