14th Sep 2021, 3:58 pm | #1 |
Tape Recording Cable for Kenwood R1000
Hi guys,
I recently aquired a lovely Kenwood R-1000 and it has a function to activate a tape recorder on power up. Does anyone know where I can get one? Its a DIN 7 at one end and standard audio 3.5 I think at the other end. I currently use a Roberts quarter speed cassette with voice activation, but I'd like to use it on my Sangean DAR-101 SD card recorder. Many thanks Steve
Tecsuns PL-310, PL-330, PL-600, PL-880, Yaesu FRG-7700, Kenwood R-1000 and a Yaesu FRG-7 |
14th Sep 2021, 4:06 pm | #2 |
Re: Tape Recording Cable for Kenwood R1000
Apparently according to the manual, pins 1 & 4 on the DIN connect to the 3.5 jack, wonder if I could get one made?
16th Sep 2021, 8:15 pm | #3 |
Unlikely to find a 7 pin DIN to 3.5 jack cable to purchase but by getting the connectors would be easy to wire yourself.
A little surprised about the 3.5 jack, it would depend upon what type of connector is on the tape recorder and would have to be a compatible Remote signal interface, many Remote connectors at the tape recorder would be multi pin. David |
17th Sep 2021, 9:47 am | #4 |
Have now seen the information referenced in the R-1000 Instruction Manual.
It does not reference a 3.5 jack, it says "connect the external control terminal of the tape recorder to the R-1000 Remote connector, pin 1 and pin 4". David |
17th Sep 2021, 5:37 pm | #5 |
Theres a picture of it I've seen somewhere, anyway my DAR101 SD recorder definitely has a 3.5 connection for remote control, and thats what Im wanting to use it on.
Steve
17th Sep 2021, 7:51 pm | #6 |
The Sangean DAR-101 looks an interesting product, unfortunately the User Manual download link from their website does not work.
David |
17th Sep 2021, 7:57 pm | #7 |
Now found the manual from a different link to their site via a Google search.
David |
19th Sep 2021, 11:52 am | #8 |
Note that there are least 3 different 7 pin DIN connectors:-
1. 2 horizontal rows of 3 and 4 pins. 2. Circular array of 6 pins with a 7th centre pin. 3. Circular (270 degrees) array of 7 pins, this is the one in question. David |
19th Sep 2021, 9:05 pm | #9 |
...and the tricky part is the pin numbering sequence seems illogical until you see that you can plug a three-pin plug into a five or seven pin socket - then the pin numbers line up!
Cheers - Martin ZL2MC |
20th Sep 2021, 9:30 am | #10 |
Yes and this also means that if Steve has a 5 pin DIN plug (180 degrees version) or a spare 5 pin DIN plug cable he could use that to make the required cable, i.e. then no need to purchase a 7 pin DIN plug.
David |
4th Oct 2021, 7:38 pm | #11 |
I found a din 7 plug at work and my son soldered it up for me, works a treat! one pin to either audio connection and one to the centre earth pin.
4th Oct 2021, 8:10 pm | #12 |
