28th Jan 2021, 8:05 pm | #301 |
Re: Non-working Commodore PET 3016
Yes, that one I missed - held high by a 1K resistor - and I am not sure we have ever asked Colin to check that for us, so, before anything else just check that the 'SO' pin (38) is at or close to +5V with the power on. We aren't expecting to see a waveform or frequency on that one, just a steady voltage.
If pin 38 has ~5V on it then try running the CPU with only the following pins connected: -5V supply (pin 8) - 5V -0V supply (pins 1 and 21) - 0V -Clock in (Pin 37) - 1MHz clock -RDY (Pin 2) (Held high) -IRQ (pin 4) (Held high) -NMI (Pin 6) (Held high) -SO(Pin 38) (Held high) -Reset (Pin 40) (Momentarily low, then held high. The reset circuit takes care of that.) The main thing we want to see is activity on address pin A0 (pin 9). |
28th Jan 2021, 8:08 pm | #302 |
I bought spare 40 pin sockets so I'll do the doings with that. I'll wait a while to see if others chip in
28th Jan 2021, 8:16 pm | #303 | |
A NOP test would generate a nice progressive count on the address lines but random / unspecified data should still cause activity on the address lines as the CPU will try to execute it anyway. That's all I'm looking for really, any address line activity at all. I think Colin did say he bought both types of socket so a conventional socket would be OK for this and the 'unwanted' socket contacts could perhaps be removed altogether by pushing them out from below, to leave only the ones used for the minimum pin set. |
28th Jan 2021, 8:35 pm | #304 | |
If you are going to try that, do it (and also check the voltage on pin 38 for us) before trying to run the CPU with only essential connections. |
28th Jan 2021, 8:36 pm | #305 | |
Alan Last edited by ajgriff; 28th Jan 2021 at 9:03 pm. Reason: Added question |
28th Jan 2021, 9:40 pm | #306 |
Just so I have this right, first thing is the following:
Turn PET on and measure voltage on pin 38. Then turn PET off Connect pin 36 to 5v by linking pin 36 to pin 2 with a resistor (between 3k and 10k) in the link. Then power on. Then see what frequency and activity there is on pin 9 with my scope. That sound right? |
28th Jan 2021, 10:05 pm | #307 |
Yes please.
28th Jan 2021, 10:31 pm | #308 |
OK - pin 38 with power on is 5.173V
Pin 2 connected to pin 36 with a 10K Ohm resistor Power on Pin 36 measures 5.08V Pin 9 no frequency or wave pattern. https://drive.google.com/file/d/19-w...ew?usp=sharing |
28th Jan 2021, 10:34 pm | #309 |
Again, for confirmation,
1. remove 10k resistor between pins 2 and 36 2. take an ordinary 40 pin socket, remove al pins except the ones listed below: pin 8 pins 1 and 21 pin 37 pin 2 pin 4 pin 6 pin 38 pin 40 Then measure frequency and any wave on pin 9. Have I got that right? |
28th Jan 2021, 10:40 pm | #310 |
Thanks for doing that - if you are up for it can you now try the 'minimal CPU pins connected' check either by clipping the unwanted pins from a conventional socket, or by removing the unwanted contacts from a conventional socket, or by bending out the 'unwanted' pins on the CPU so they fall outside the mainboard socket.
The last way is obviously the simplest way to do it, but offers the greater possibility of damage to the IC. Using a socket requires no modification to or bending of the IC pins but sacrifices a socket - but there are plenty more where that came from. Edit: Just caught your post #309. Yes, that's right. However you do it be sure there is no connection between any of the other pins and the associated contacts on the mainboard socket. In case it's not clear, we mean for you to plug the modified socket into the mainboard socket and then plug the CPU into the modified socket. |
28th Jan 2021, 11:57 pm | #311 |
Right. Progress. See attached file.
I took an ordinary 40 pin socket and pushed through all the pins we didn't want and tested with success on pins 9, 10 and 11. |
29th Jan 2021, 12:03 am | #312 |
Again, I can't view that right now (no office suite of any sort here) but I gather from the positive tone that we finally did get something on the address lines?
29th Jan 2021, 12:08 am | #313 |
Looks really promising.
Alan |
29th Jan 2021, 12:11 am | #314 |
29th Jan 2021, 12:13 am | #315 |
OK. Could you check the voltages on pins 1 and 19 of IC UC3 and pins 1 and 19 of IC UB2 (Both 74LS244). The voltage expected on all four pins is 0V. You can do this either with the CPU plugged in normally or with it still half disconnected, makes no difference.
29th Jan 2021, 12:26 am | #316 |
Pins 1 and 19 of UC3 - 0.102V
Pins 1 and 19 of UB3 (I'm assuming you meant UB3 not UB2) - 0.102V and .2V respectively |
29th Jan 2021, 12:30 am | #317 | |
As the pin1 / pin 19 voltages on those buffers are correct, Power off, CPU removed, please measure... -The resistance between each of the following CPU socket pins (see below) and 0V, with the black lead on 0V. -The resistance between each of the same CPU socket pins and +5V, with the red lead on +5V. Suggest you use your old meter for these resistance measurements. Use whatever range you need to to get a meaningful reading. I would expect the readings from all sixteen pins to 0V to be roughly the same, and the readings from all sixteen pins to +5V to be a different resistance, but again they should all be pretty similar to each other. 9 10 11 12 13 14 15 16 17 18 19 20 ..........Not 21!) 22 23 24 25 Let us know how that goes. |
29th Jan 2021, 12:46 am | #318 |
Ok. I'll get on with those measurements in the morning.
As a matter of interest are these tests part of a process of elimination, or do you suspect we might find something? Just curious. |
29th Jan 2021, 3:35 am | #319 |
Hi Colin, as it looks like the 6502 is working when its address lines are not connected to the pcb, next step Sirius described is to try and find out if something on the board is shorting them to 0v or 5v
29th Jan 2021, 10:02 am | #320 |
Indeed, also to see if there is any significant difference between identical devices UC3 / UB3 which might indicate that one is possibly faulty.
