Old 8th Jul 2021, 8:25 am   #1
Sparks
Default Telephone with Mercury button
I recently bought an old Philips Pacephone which has a blue Mercury button. I guess its purpose was to press it before dialling the number in order to connect the phone to the Mercury network. How did the button work ? Did it send a tone or signal down the line or something else ? Thankyou.
Sparks is offline
Old 8th Jul 2021, 9:01 am   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: Telephone with Mercury button
I think it dialled 131.
Nickthedentist is online now
Old 8th Jul 2021, 10:00 am   #3
Sparks
Thanks Nick. Sounds likely. I assume the facility is obsolete now!
Sparks is offline
Old 8th Jul 2021, 1:38 pm   #4
Nicola_Jayne
sounds something about right the first efforts at local loop unbundling were access codes to alternative trunk suppliers
Nicola_Jayne is offline
Old 8th Jul 2021, 3:10 pm   #5
Aub
Aub's Avatar
Yes I was there ( as Max Boyce used to say ). The 131 would then allow you to input your authorisation code, which would then give a secondary dial tone. This was 30 years ago.
Aub
Life's a long song, but the tune ends too soon for us all.
Aub is online now
Old 8th Jul 2021, 5:09 pm   #6
M0FYA Andy
I remember having a little Mercury box which the phone plugged in to.
Andy
M0FYA Andy is offline
Old 8th Jul 2021, 8:22 pm   #7
Graham G3ZVT
Graham G3ZVT's Avatar
You weren't expected to remember your 10 digit PIN.
The blue button was typically programmed thus:
131[pause][10 digit PIN]
The PIN was sent as DTMF but very often the local exchange was yet to be "modernised" so the initial 131 had to be sent as LD followed by the appropriate command (*) to switch the remaining digits to DTMF.
Some businesses opted for cost-centre codes, these were any arbitrary 2 or 3 digit code appended after the PIN, and Mercury would separate out each unique code on their itemised bill.
Later came the Mercury 132 service which worked the same as all the other indirect carriers we all got to know.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 8th Jul 2021, 8:37 pm   #8
Sparks
Interesting stuff although it seems like a faff to connect to a rival telecoms operator. I didn't buy the phone for its past Mercury capabilities - I just liked the look of it and it was cheaper than an Interquartz 9825 'footprint'.
Sparks is offline
Old 8th Jul 2021, 10:11 pm   #9
Richard_FM
Richard_FM's Avatar
I've noticed a few manhole covers with the Mercury logo on the road where my current job is based.
Richard_FM is offline
Old 9th Jul 2021, 12:18 am   #10
mark_in_manc
Not only businesses - that feature was really useful in a shared house, to try to work out who owed what when paying the phone bill!
"The best dBs, come in 3s" - Woody Brown
mark_in_manc is offline
Old 9th Jul 2021, 8:08 am   #11
Nickthedentist
I think Mercury became One2One then T-mobile
Old 9th Jul 2021, 8:52 am   #12
Aub
Aub's Avatar
Mercury was initially owned by Cable & Wireless 80% and Bell Canada 20%. Then became fully owned by C&W, then bought by Vodafone.
Aub
Aub is online now
Old 9th Jul 2021, 8:55 am   #13
cmjones01
For a while this sort of thing was very common. When I was a student in the early 1990s a company called "ACC Long Distance UK" set themselves up on the university's telephone system so that individual students could dial a huge long number on a phone on the internal network (most of which couldn't make outgoing calls) and make outgoing calls charged to their own account. This was quite an innovation and we made use of it a lot. It was much better than queuing for the payphone!
Chris
cmjones01 is online now
Old 9th Jul 2021, 12:36 pm   #14
AC/HL
AC/HL's Avatar
Quite a convoluted chain of events. It was still the Mercury Project when I joined! https://en.wikipedia.org/wiki/Mercury_Communications
All history now.
AC/HL is offline
Old 9th Jul 2021, 4:25 pm   #15
yesnaby
yesnaby's Avatar
I'm still using this one every day.
yesnaby is offline
Old 9th Jul 2021, 5:33 pm   #16
Sparks
Mine has begun to turn yellow as so many white plastics do. The phone itself is still otherwise in reasonable shape. I haven't pressed the Mercury button.
Sparks is offline
Old 9th Jul 2021, 7:02 pm   #17
"Lowest cost routing" was a big sales-point for the first alternative-to-BT telcos to emerge in the 1980s - I remember several of my clients had contracts with Mercury which included 'smart dialers' which basically recognised when someone at site A was calling someone at site B and prefixed the called number with the code to 'use Mercury not BT' - which essentially gave them free calls between the sites.
I used this to my advantage as a way to get [1200-baud] data-communications between the sites rather than renting EPS8/EPS25 circuits from BT.
Some of these 'data' calls stayed up for weeks!
Old 9th Jul 2021, 7:48 pm   #18
duncanlowe
Chris
When I was at college we found an alternative. The phones in the halls of residence ( a very old LD only system) couldn't make outside calls at all, only connect to the main university system and call uni numbers or of course numbers within the halls. Outgoing calls were also not possible on the main uni system for any phones that students could access. I still don't remember why, but we wondered if from the halls of residence phones, we could dial the number to connect to the uni system, then the code for an outside line, then an outside number. And it worked. From the old 'hall' system we could dial any outside number, including international. We did make a point of letting the uni know as soon as we found out (maybe by ordering a telegram?), but it took them weeks to get round to looking into it. In the meantime I'm sure some of the international students ran up a 'bit' of a bill.
duncanlowe is offline
Old 9th Jul 2021, 10:44 pm   #19
Richard_FM
Richard_FM's Avatar
I remember they had Harry Enfield in their adverts, with his Mr Grayson & Mr Chumley-Warner characters.
Old 10th Jul 2021, 8:44 am   #20
bluepilot
I don't know about England but in Germany the alternative operators didn't provide billing pulses. The company I worked for allowed people to make personal calls which they were then charged for. It worked OK for Deutsche Telekom buy if you used an alternative operator the call apparently cost nothing although the company still had to pay the true cost. As the company had no way of working out what the call had really cost the only solution was to block everything except Deutsche Telekom.
Stuart
bluepilot is offline
