Old 4th Sep 2018, 2:15 pm   #1
Singlofty
Default 1S105 diode information.
Looking to start my next guitar amp build and came across the attached circuit for a Selmer amp. It contains a 1s105 diode and I've been unable to unearth much information on it although I believe it is a tunnel diode. Can anyone explain the reason for its use and the significance of the 17v note beneath it.?
Dave.
Mods, the schematic is in the public domain on the Selmer users site.
File Type: pdf selmer-constellation-20w-amp-schematic-diagram.pdf (1,007.8 KB, 130 views)
Singlofty is offline
Old 4th Sep 2018, 2:21 pm   #2
TonyDuell
Default Re: 1S105 diode information.
From the position in the circuit, I would think it's just a normal rectifier diode. It half-wave rectifies half of the HT secondary winding on the mains transformer to give a -ve supply rail.
I wonder if the '-17V' is actually '-170'. That would make more sense to me, it's the sort of voltage I could believe getting by half-wave rectifying that winding.
TonyDuell is offline
Old 4th Sep 2018, 2:24 pm   #3
Ambientnoise
Looks like it is just a rectifier producing a negative rail. Googling suggests a 1A, 600v rating.
HTH
Ken
Ambientnoise is offline
Old 4th Sep 2018, 2:28 pm   #4
AC/HL
AC/HL's Avatar
I think 1S could be Texas Instruments
AC/HL is offline
Old 4th Sep 2018, 2:45 pm   #5
Singlofty
Thanks for the replies, googling it returned nothing for me. I managed to find a Toshiba nos one on ebay.
Old 4th Sep 2018, 3:02 pm   #6
julie_m
That looks like a nothing-special rectifier diode. A 1N4007 probably would do the business.
julie_m is offline
Old 4th Sep 2018, 6:22 pm   #7
buggies
buggies's Avatar
600V PIV 750mA 1Vf Silicon according to 1969 Diode & SCR D.A.T.A.Book
George
buggies is offline
Old 5th Sep 2018, 10:12 am   #8
TrevorG3VLF
TrevorG3VLF's Avatar
R37 and R39 form a voltage divider. The -17V could well be correct. R39 will have a large effect since it is passing pulses.
TrevorG3VLF is offline
Old 21st Sep 2018, 9:24 pm   #9
Philips210
Hi.
In my ECA data books, the 1S105 is listed as a 600V 0.75A general purpose rectifier. Suggested equivalents, BY126, BY127, BY133, BY134, 1N4005, 1N4006 and 1N4007.
Regards
Symon.
Philips210 is offline
Old 21st Sep 2018, 10:00 pm   #10
Maarten
1S is the JEDEC prefix for single junction semiconductors such as diodes, just as 2S is used for transistors. In the US 1N and 2N were used, though I'm sure TI may have used in house codes which may be similar.
Maarten is offline
Old 22nd Sep 2018, 5:50 pm   #11
Trevor
very simple -17 volts is about correct grid bias for an El84 1n4007 will work well
Trev
Trevor is offline
Old 22nd Sep 2018, 8:59 pm   #12
Singlofty
Once again thank you for the replies and observations, I've started to build this now and will post again as it progresses.
Dave
Old 22nd Sep 2018, 10:56 pm   #13
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
If it's any help, the Marshall JTM45 uses a similar circuit to provide the grid bias for it's output valves (2 x 5881 or equivalent in that case), and that amp uses a 1N4007 as the rectifier.
'LIVEWIRE?' is offline
Old 23rd Sep 2018, 7:52 am   #14
Singlofty
Yes, I've seen the same sort of circuit in other amp schematics, but being unable to find any data on that diode and the -17v reference being the only voltage marked on the drawing I thought I'd better clarify it.
I'm building this for my niece who's a music student and would like to optimise one of the input channels for bass. The original unit had twin 12" speakers but I'll be fitting a pair of 10" . Are there any pro's, con's for series or parallel wiring, I have a multi tap output transformer so can match either output impedances.
Dave
Old 23rd Sep 2018, 11:16 am   #15
ronbryan
Dave
A bit late to the party, but I've found the full 1S105 data in Texas Instruments Data Book 5. I've taken photos of the pages as the binding of the book is a bit too fragile to go in my scannner.
Ron
ID:	169738   Click image for larger version
ronbryan is offline
Old 23rd Sep 2018, 4:25 pm   #16
Singlofty
Thank you for that Ron
Dave
