Old 27th Jul 2018, 11:28 pm   #1
dragonser
dragonser's Avatar
Default Conar 683 pattern generator question
I have recently got this nice small unit. ( rainbow pattern generator ) Yes it is an ntsc - M standard one.
it only have an rf output on a vhf channel. the only set I had to hand ( pal Uk standard ) only has Uhf, so I thought I might be able to pick up a harmonic of the vhf signal.
I can, but the video seems to be inverted ?
so is this likely to be due to trying to resolve a harmonic of the vhf signal ?
Regards Peter B
dragonser is offline
Old 18th Aug 2018, 8:11 pm   #2
dragonser
dragonser's Avatar
Default Re: Conar 683 pattern generator question
well after getting a small mtec at0424 B and W portable which has vhf coverage, ( but no 405 line ). the pattern generator does produce reasonable patterns. so the problem was down to trying to resolve things on the uhf band....
I will post a couple of pictures here..
Regards Peter B
Old 19th Aug 2018, 10:43 am   #3
dragonser
dragonser's Avatar
Some pictures, in case they are of any use.
ID:	167814   Click image for larger version
ID:	167815   Click image for larger version
ID:	167816   Click image for larger version
Regards Peter B
