30th Oct 2012, 4:03 pm | #1 |
Finish for black 150 phone dial
I have a No.10 dial with a solid copper finger plate. It looks as if it was originally chemically blacked and has subsequently been painted. What was the original finish?
Nigel |
24th Nov 2012, 9:33 pm | #2 |
Re: Finish for black 150 phone dial
It was some form of electro-chemical 'flashing' - nearest you'll get is the sort of blackening that gunsmiths use - see eBay item 120605280212
http://www.ebay.co.uk/itm/Birchwood-...item1c14a287d4 for one type which can be applied cold. I've not tried it myself but it seems to be the sort of thing required. |
28th Nov 2012, 9:04 pm | #3 |
I have had to restore all the brass parts on a Peel-Conner version of the 150 Candlestick. Thanks to advice from the forum, I discovered Curator antiquing fluid black from Relics of Witney. 150 ml costs about £18 including postage, but makes up to 1.5 litres.
Having polished off all the old damaged finish, I followed the instructions and immersed the parts in the solution for 2 minutes or more. Then I washed off the loose blackish slime on the parts and was rewarded by a finish very like the original shiny blue-black. I protected it with a coat of clear car lacquer. The finger plate is copper and, for the moment painted black. However, when I have the phone fully working, I will apply the same treatment to the dial. There were traces of the familiar blue-black finish on the back. Although the instructions on the bottle say you can apply the fluid neat with a swab, I found this very hit and miss and do not recommend it. Nigel |
