Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
3rd May 2012, 1:41 pm | #1 |
Hmm. What do I need?!
Ok, just so you know that I'm not a complete dummy.. I'm a former electronics engineer and was once probably one of the biggest collector/restorers of vintage TVs in the UK. The name's Steve Rowley. I sold most of my sets following a divorce in 1991. Quite a few pre-war sets, vision only sets, projection, side by side sets, post war 9'' inch sets etc.
So, fast forwards to now, I have just one (as yet unrestored) very nice condition Bush TV22. I intend to do a restoration and to get the set working as in 'viewing' it again. Right, my question! We're now into digital broadcasting. I want to buy/create a 'set-up' that receives freeview terrestrial RF broadcasts and by way of a standards converter (and whatever else I may need) feed the correct signal into my Bush TV22 and watch programmes 'off air'. Looking at the Aurora stuff, I dont think(?) I need that World converter for my needs? I was looking at the SCRF models. Would they do? So, can someone tell me what I need - in total - to do the job described; I mean EVERYTHING. For example do I need an RF front end? what form would this need to be? make/models etc. So to recap, I need a hardware string to accept an off air RF signal and ultimately feed an RF 405 line one into my Bush TV22. What does that hardware 'black box' comprise? Note! I have a 405 line modulator that I bought from someone associated with BVWS in around the mid/late 80s. It's a largish diecast box and I used to feed it with preprepared '405 line format' video (Steve Ostler prepared the tapes for me) from a Philips 1700 video recorder with video output mod, then hook the output of the modulator up to my vintage sets. This unit has stood for two decades in an outside shed, so not sure how it would work now, anyway.. Thanks! Last edited by stevehertz; 3rd May 2012 at 1:52 pm. |
3rd May 2012, 1:49 pm | #2 |
Re: Hmm. What do I need?!
That's it, all you need is the Aurora, it does it all. Just connect up your Freeview, DVD, Sky box etc to the Aurora and away you go. Comes with in built Test Card C ( you can change this to whatever test card you like) and test tone
SCRF405A PAL(625) to 405/25i with RF System A modulator Chris |
3rd May 2012, 1:56 pm | #3 |
As Chris says, the SCRF405A will do almost the entire job. You will also need:
In the UK it's easiest to order from Crowthorne: http://www.crowthornetubes.com/radios.htm Probably cheaper too, since it will cost about £175 inc carriage from the US at the moment plus £30 -£40 VAT and fees when imported. I offer an informal UK/EU support service for Auroras. I'm glad to say my workload has been minuscule. |
3rd May 2012, 3:00 pm | #4 |
Certainly cheaper from Crowthornetubes.
David |
3rd May 2012, 4:27 pm | #5 |
Thank you so much guys. Appreciated.
7th May 2012, 10:35 am | #6 |
On this front, I need to find a 9v 250mA power supply for my Aurora. One would have thought this should be easy to find, but have drawn a blank with Maplins, etc. Does anyone have any ideas please, or maybe one going begging? Thank-you. Regards, Richard
7th May 2012, 10:45 am | #7 |
Provided it doesn't drop below 7V or rise above 14V and can deliver at least 250mA it will be fine. It's really uncritical. Even if it goes above 14V briefly it won't do any damage until about 30V (subject to checking, don't deliberately inflict voltages above 15V).
Most of us have something in the junkbox that can meet these specs, often a "wall wart". Doesn't even need to be regulated though it's better if it is. Or a small transformer, 4 diodes, a capacitor and a 7812 regulator. Or a 7805 regulator jacked up a bit with 2 resistors. |
7th May 2012, 11:51 am | #8 |
I use an adjustable voltage regulated 300mA supply for mine, think it cost £3 or £4 on eBay. Should be readily available at Maplin?
7th May 2012, 12:01 pm | #9 |
Plenty on sale at Maplin, including this one:-
http://www.maplin.co.uk/12vdc-0.5a-p...1mm-tip-513515
7th May 2012, 5:23 pm | #10 |
I've got kickin around a Panasonic wall wart PS (STM51V1.5A) with an output of 15V/0.66A, would that do it or is the voltage a tad too high for comfort?
7th May 2012, 5:33 pm | #11 |
You could try Wilkinsons, as mine came from there and it's regulated .
7th May 2012, 6:00 pm | #12 |
Maplin part number XX09K springs to mind. But if there's a market nearby, there may well be a stall selling electrical goods who may have a similar item for less money.
7th May 2012, 6:55 pm | #13 |
Thank-you for the assistance. 12v 500mA ones seem much easier to find, so good to know that this will be okay.
9th May 2012, 9:19 am | #14 |
I think my question got lost in the ether, let me put it again:
I've got kickin around a Panasonic wall wart PS (STM51V1.5A) with an output of 15V/0.66A, would that do it or is the voltage a tad too high for comfort? Thanks. |
9th May 2012, 9:29 am | #15 |
15V is a bit high. You won't do any damage but things will get hot and may shut down due to overheating.
10th May 2012, 1:31 pm | #16 |
On a similar note: is there anything readily available which can drive an Aurora from 625 UHF analogue, without being a 'recorder', and thus tending to require a Colour licence?
10th May 2012, 1:34 pm | #17 |
Since analogue 625 UHF will be finished in a few months I don't see the point of your question. A freeview box will do the job for DTT without being a recorder and will not need a colour licence unless connected to a colour display.
10th May 2012, 2:04 pm | #18 |
Brigham,
If you have some source of 625-line, UHF-modulated signals and can't get at the baseband, I have a Maplin NICAM tuner with audio and video outputs, including fallback to FM mono audio. Yours for postage -- PM if you want it.
10th May 2012, 6:01 pm | #19 | |
Which is why I asked. Perhaps I shouldn't have bothered. |
10th May 2012, 6:09 pm | #20 | |
I used one for off-air reception in my lab until recently. I intend to keep it for evaluating modulators. It's nowhere near a proper measuring receiver but it's not bad. I used it to check out the UHF modulator I made from an old Ondigital box. |
