Reply
Old 21st May 2022, 9:08 pm   #2921
Default Re: AVO Multimeter survey
Originally Posted by Superscope View Post
Thanks Mike,
For those interested, the Database now contains over 3000 serial Numbers.
Ian
Thanks !!
Old 25th May 2022, 2:13 pm   #2922
Superscope
Anyone else seen this style of Magnetic Shunt on an Avometer movement?
I've not seen one like this before.
Definitely an Avo movement, and no reason to think it is not
original to this Meter, a Model 9 Mk IV dated Jan 1970.
Ian
ID:	257761   Click image for larger version
Superscope is offline   Reply With Quote
Old 25th May 2022, 5:06 pm   #2923
The Philpott
The Philpott's Avatar
No, but what a simple solution. Looks like it needs the blu-tak derusting treatment
Dave
The Philpott is offline   Reply With Quote
Old 25th May 2022, 6:49 pm   #2924
Superscope
It's not just the Shunt, the Magnets and pole pieces appear to be
welded together into a single piece construction.
I must have seen more than a Hundred Avo Movements by now, and
I don't remember ever seeing anything like this!
Sadly, it's OC, so is probably scrap, so the rust is the least of it's
problems.
Double sadly, that makes this Mk IV pretty much scrap as well
I might have a bash at repairing it, but I don't hold out much hope
to be honest.
It's a pity there just don't seem to be any Moving Coil repair experts
around any more.
Ian
Old 25th May 2022, 7:29 pm   #2925
pmmunro
That's definitely an unusual magnet assembly Ian. I haven't seen one like it either.
At Januray 1970, and being a Model 9 Mk IV, it comes from a time when there was considerable experimentation in an attempt to save on costs of production. However, it's quite likely that the Mk V design and its centre pole movement were in at least an early design stage at this time.
It might be worth checking where the meter's serial number comes in the Mk IV sequence, if it is decrenable.
PMM
pmmunro is offline   Reply With Quote
Old 25th May 2022, 9:37 pm   #2926
Pamphonica
Pamphonica's Avatar
If it's a 9, then I might have a spare NOS movement, but I'm not sure exactly which mark they are. I have three still in their (battered) plastic protective cases. On test tonight, they are all showing slight signs of sticking when presented with a slow current ramp. If I get a good one after an overnight on my "exerciser", I'll PM you. The exerciser carefully causes the meter to move from end to end of the scale, at about 0.2Hz. A great use of a function generator!
The meter magnets are very conventional, by the way.
-Jeremy
Jeremy, G8MLK, BVWTVM Friend, VMARS, BVWS Secretary.
www.pamphonic.co.uk www.bttt.org.uk
Pamphonica is offline   Reply With Quote
Old 26th May 2022, 10:02 am   #2927
The Philpott
My 'meter movement exerciser' is the top part of one of the old type (filament) road lamps, around 1Hz. Another member tucked a meter away in the boot of his car, linked it to one of the indicator lamps and drove to work and back for a couple of weeks!
Dave
Old 26th May 2022, 10:15 am   #2928
Sinewave
Sinewave's Avatar
I've got lots to add - on another note, is there another survey due? Hopefully later I'll get a load more added, I'll likely need to do an audit to see if I'm missing any entries.
Avometer, vintage Fluke and Marconi collector. Also interested in vintage Yaesu and KW.
Sinewave is offline   Reply With Quote
Old 26th May 2022, 10:23 am   #2929
Pamphonica
Pamphonica's Avatar
Ian (Superscope), PM me - I have a good smooth replacement movement if you think it will fit. The other two are still not right. One is smooth but sticks just below zero. The other is still jerky.
Photos show my meter exercising lash-up and the best movement.
-Jeremy
ID:	257796   Click image for larger version
Old 26th May 2022, 10:27 am   #2930
Hybrid tellies
Hybrid tellies's Avatar
Just added my Multiminor 4 to the list. Sadly no serial number found.
Simon
BVWS member
Hybrid tellies is offline   Reply With Quote
Old 26th May 2022, 5:25 pm   #2931
barrymagrec
I am now the owner of my Dad`s old Universal AvoMinor, serial U.62645-1243, sadly not in great nick as it was dropped from a high shelf circa 1970.
barrymagrec is offline   Reply With Quote
Old 26th May 2022, 5:58 pm   #2932
Superscope
PMM,
Nothing particularly special with the Serial Number unfortunately.
Apart from me needing a trip to Specsavers. It has Two "1's" not One.
So it's actually a November 1970 Mk IV.
There is another 9 Mk IV logged in the Survey with the same Date
and a very close number, posted about 10 Years ago, but it looks like
the Forum Member never posted or logged in again so it's not possible
to check if it was a Batch thing going on.
Pamphonica,
Thanks for the offer Jeremy.
PM sent.
barrymagrec,
Thanks for posting the Serial Number of the poor old Minor.
What parts are broken?
I might have some Spare parts for a Minor if I can lay my
Hands on them.
FOC just postage if I have the right bits.
Ian
Old 26th May 2022, 8:53 pm   #2933
The Philpott
Post 2931, 2932
Likewise Barry, if you want to try and resurrect it post a photo of the damage.
(Not sure i have the bakelite casing though, i would have to check)
Dave
Old 27th May 2022, 8:33 am   #2934
Superscope
Regarding the unusual Meter Movement, there is a comment
in the Model 8/9 Mk IV Service Manual on page 18 which states:
"If magnet is solid grey type, Coil Assy. is 45469"
Solid Grey pretty much describes the movement here, so the fact
that a different Coil assembly was clearly available as a spare part
suggests that this type of movement was widespread enough in the
Mk IV for mention of it in the Manual.
Anyone willing to peak inside their Mk IV's I wonder?
Ian
Old 27th May 2022, 10:53 am   #2935
barrymagrec
Universal AvoMinor
Thanks for your offers of help, I was moved to give it a quick check,the main obvious thing is that the glass is cracked and a piece has dropped and may foul the needle. Surprisingly a quick check on the 25 and 100 volt DC ranges came out somewhere close, I didn`t do any more as I`d really need to find wander plugs (I have them....somewhere).
I also had a look inside, looks O.K., battery contacts are in poor shape - always were from memory
My Dad wouldn`t have used this much after he got his 8 mkII in 1958 and I only used it a little in the sixties.
I may sort it out one day but not for a while, far too much other stuff to sort.
Old 27th May 2022, 10:31 pm   #2936
Sinewave
Sinewave's Avatar
Some more for the log
Model 7 Mk1, Serial No. 7943-11771
Model 40 Mk2, Serial 2490-B-767-M
Model 8 Mk7, Serial 8060 1027 1193
Model 8 Mk7, Serial 1010 M534500
Model 8 Mk7, Serial M1396501016000601
Old 28th May 2022, 10:32 pm   #2937
Riccardo Grillo
Model 8 MkII, S/N 2XXX-C-563T
Already added this to the Google Doc, but it won't let me see the results due to 'file error'.
Riccardo Grillo is offline   Reply With Quote
Old 28th May 2022, 11:45 pm   #2938
Riccardo Grillo
Originally Posted by Pamphonica View Post
I will publish a link to an online summary spreadsheet once I have a few contributions.
Any news on that?
Old 30th May 2022, 8:57 pm   #2939
sparkymike
My daughter, who lives 240 miles from me rang me when she was at a car boot sale near Weston Super mare and asked me if I would like an Avo meter. Price was only £5.00 and I will not see it until father's day.
She sent photos on which can be seen the serial number etc.
Would this be 11/59 date ?
Mike.
ID:	258097   Click image for larger version
ID:	258098   Click image for larger version
ID:	258099   Click image for larger version
sparkymike is offline   Reply With Quote
Old 31st May 2022, 10:47 am   #2940
Superscope
Indeed it is Mike. November 1959.
It will be a Mk II.
It will most likely have a Bakelite Case, but if by chance
it has an Alloy one, please let us know and the Colour it's
painted.
I now record those details.
Also the Battery Cover type.
£5 is a pretty good result even for a Model 40.
It looks in pretty good cosmetic condition.
Usual story, if the Movement is Ok, it should be straightforward
to fix if it doesn't work.
Still a very useful Device, just not on electronics.
More power orientated.
I tend to use Model 40's for monitoring Charge Voltage and Current
when playing around with Batteries.
Ian
Reply
