23rd Oct 2018, 4:15 pm | #1 |
Measuring current, Class D ?
How can I measure the battery drain on a class D amp ? it uses 2x 1.5V batteries.
John. |
23rd Oct 2018, 5:34 pm | #2 |
Re: Measuring current, Class D ?
Measure the current being drawn? I must be missing something.
23rd Oct 2018, 5:58 pm | #3 |
Hi Paul, its described as a 3w amp, IIRC should draw around 10 ma at 5.5v
I am running it at 3v. Inserting a 100ma then 1ma analog meters then a digital meter in the + battery lead, (one at a time) the amp stops working and just clicks. John. |
23rd Oct 2018, 6:04 pm | #4 |
They do that with a 'loose' power supply, try decoupling with a 1000uF (or so) capacitor after the meter.
23rd Oct 2018, 6:06 pm | #5 |
Sounds as if it's pulling a lot more than 10mA then. The meter resistance is dropping enough voltage to stop the chip working. 3V is already low - these are usually strictly 5V devices. It should be a lot happier with a 4.5V supply.
23rd Oct 2018, 6:16 pm | #6 |
2.5v is min on this chip. With 3v there less output but he distortion is very small. I will try the 1000uf cap tomorrow.
John. |
23rd Oct 2018, 6:42 pm | #7 | |
23rd Oct 2018, 6:57 pm | #8 |
To dismiss the sceptics that a digital amp is rubbish I bought one of these https://www.ebay.co.uk/itm/Nobsound-...696640809?var= it is very good indeed, it will "go away" for my workshop amplifier, bluetooth is handy for podcasts from a tablet etc..
23rd Oct 2018, 7:45 pm | #9 |
This is a bit smaller than the cased amp pictured above. A stereo version of this chip is available it's only slightly bigger then a penny. Pictured, mono 3W version with a one pence piece for scale.
John. |
23rd Oct 2018, 8:04 pm | #10 |
It does need a "bulk cap" no room for one on that PCB. The bulk cap is the two cells in your case.
23rd Oct 2018, 10:48 pm | #11 |
If the amp is delivering 3W output and the dc supply current at 5V is less than 600mA someone's finally made a perpetual motion machine.......... hide, quick!
Presumably we're talking about the amp's quiescent current draw here? Also, what exactly is a "digital" amplifier? Class D isn't- it's a linear analog amplifier that happens to use HF switching techniques to get the efficiency up.
....__________ ....|____||__|__\_____ .=.| _---\__|__|_---_|. .........O..Chris....O Last edited by Herald1360; 23rd Oct 2018 at 10:54 pm. |
24th Oct 2018, 8:45 am | #12 |
AFAIK, all class D amplifiers require a low impedance power supply to function properly. In this one, there is no supply decoupling on the board, as there is no board space. It relies on the low impedance of the battery to keep things stable (and keep the price down to a minimum!).
I would put a low E.S.R. cap. of at least 220uf across the supply at the board. Then introduce whatever measuring devices you wish between the board (with cap. attached), and the power source. This should keep things stable, and enable accurate measurements to be made. Tony. |
24th Oct 2018, 11:04 am | #13 |
No success to report yet. More experimenting called for.
John. |
24th Oct 2018, 1:06 pm | #14 |
Where have they hidden the output filter?
24th Oct 2018, 2:53 pm | #15 |
That's left as an exercise for the user....... use short wires to the speaker and it won't radiate (that) much!
24th Oct 2018, 3:35 pm | #16 | |
25th Oct 2018, 7:51 pm | #17 |
Is it oscillating maybe? Can you put a 0.1uF ceramic cap right across Vcc and ground pins?
Al |
25th Oct 2018, 9:58 pm | #18 |
I would not say its oscillating, just clicking about 2 or 3 three times a second. When I used the 1ma meter needle flicked up to 0.9ma.
John. |
25th Oct 2018, 10:12 pm | #19 | |
It might be oscillating at RF...I'd still decouple it as described. Can you post a pic of the whole set-up including your wiring to the board, battery and speaker? What are you putting into it?
Al |
25th Oct 2018, 10:50 pm | #20 |
It could be, seems to change speed depending on music or speech input. I will take a photo tomorrow evening. Its just a breadboard lash-up, input being taken from either a Crystal set or a working RDA5807M.
John. |
